The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. May 14, 2017 at 9:07 AM
    #1381
    erik530195
    erik530195 Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    Wasn't sure where to ask this, but can I turn overdrive on on a flat surface, as long as it doesn't keep shifting up and down, or should it always stay off? Reason being having overdrive off decreases gas mileage.
  2. May 14, 2017 at 2:20 PM
    #1382
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    OD is your weakest gear.
    what does your owners manual say about towing?
  3. May 14, 2017 at 5:20 PM
    #1383
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I'm with LeftCoast, check your manual. In my experience, even if not hunting for gears, OD shoots trans temps up even on a flat. I'd rather pay a little more in gas periodically when towing, then have to buy a new tranny. Just a couple pennies from me.
    erik530195[QUOTED] likes this.
  4. May 19, 2017 at 7:18 PM
    #1384
    jezblayzd
    jezblayzd Member
    erv
    14 mag gray
    roadrunner roof rack side steps kn filter firestone ride-rite air bags tekonsha P3 brake controller Scan gauge temp monitor leer camper shell fab side steps
    sup guys i had a minor prob trying to park my TT. one of my trunion bar "came off" when i did a kinda sharp turn with a bit of a slope. i dont know if my brackets may be too far set back or if my air bags had too much air or if the turn was what made it come off. can someone explain how this can happen and if this is common
  5. May 20, 2017 at 12:33 AM
    #1385
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    not even sure what a trunion bar is.
  6. May 20, 2017 at 5:38 AM
    #1386
    jezblayzd
    jezblayzd Member
    erv
    14 mag gray
    My mistake, still learning the vocabs of these parts. Its the sway bar
  7. May 20, 2017 at 12:49 PM
    #1387
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    front or rear anti-sway bar? (actually, I don't even know if these trucks HAVE a rear antisway)
    I thought the front sway bars ends were bolted to sway bar links, and the other end of these links were bolted to the front control arm? the middle of the sway bar pivots in "D" shaped bushings that are strapped to the frame crossbeam. not sure how any of that could come out of its brackets, unless the hardware broke or wasn't sufficiently torqued?
  8. May 21, 2017 at 12:37 PM
    #1388
    nurseboy
    nurseboy Well-Known Member
    Jan
    Riverside, Ca
    Tried my best searching before I asked this. I'm new to towing and never realized there are so many different drop down and length options for ball mounts. Is there a suggested drop down and length size for what you are towing, like depending on height of vehicle and what you are towing? Long story short, I want to pull a motorcycle trailer with my truck that has a 3 inch lift (2009 double cab/V6, extended bed model). How big or a drop down and length should I get?
    Edit: NM I found my answer
    https://www.youtube.com/watch?v=iIZElaU6Js8
  9. May 21, 2017 at 4:04 PM
    #1389
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    approximately level the trailer frame, measure how how its hitch is, thats about where you want your ball. its ok if the trailer frame is leaning slightly down in front, but not ok if its high in front and sloping down in back, thats much less stable when towing.
  10. May 22, 2017 at 5:08 PM
    #1390
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Pictures of your set up may help. I have never had one come off, and can't even imagine how it can, with the amount of force it takes to get it "locked" in. Maybe set too loose?
  11. May 22, 2017 at 5:10 PM
    #1391
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
  12. May 22, 2017 at 5:22 PM
    #1392
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    OH, weight distributing hitch... I was thinking antisway bar in the truck suspension. hah hah.
    yeah, if the chain popped off the stirrup, my guess is, you don't have enough grease on the pivots of the trunion, and/or not enough tension on the WDH... inflate your airbags *before* you setup the WDH. I hook my chains up before I fully raise the nose jack... my current setup, I'm using the 4th link on the chain hooked up the stirrup, I really should crank down on the hitch tilt adjustment a bit more.
  13. May 23, 2017 at 5:11 AM
    #1393
    Riverpirate
    Riverpirate Well-Known Member
    Rich
    Pennsylvania
    2015 Toyota Tacoma double cab 6 cylinder 4 liter TRD Sport
    I towed my Camper this weekend with the new truck for the first time. Had quite a bit of bounce on smaller roads. Do you guys think Air bags will help with this? Towing on the open road was great. Just really bouncy going down smaller roads and over train tracks.
  14. May 23, 2017 at 5:22 AM
    #1394
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    I have never towed a camper however I have towed around 3k and I find the airbags to be excellent. They firm up the ride quite a bit making the truck feel planted and stable. Highly recommend in my experience with towing...
    TheMuffinMan likes this.
  15. May 23, 2017 at 10:41 AM
    #1395
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    river; a WDH (Weight Distributing Hitch) might help MORE than airbags.
    lynyrd3 likes this.
  16. May 23, 2017 at 11:22 AM
    #1396
    Riverpirate
    Rich
    Pennsylvania
    I have one, along with a anti sway bar. Im probably making more of it than I should. I mean I am towing a 3500lb camper, there is going always be a little bounce, lol.
  17. May 23, 2017 at 11:27 AM
    #1397
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    I'm towing a 3500 lb max casita (2200 lbs dry, usually under 3000 lbs as I load it) and it wsa quite bouncy w/o the WDH, when I setup the WDH properly, the pitching went away entirely. you might need to somewhat increase the force on the WDH
    I found that when I'm using the WDH, the swaybar is superfluous, I haven't used it on my last 3-4 trips, and never missed it.
  18. May 23, 2017 at 11:33 AM
    #1398
    Riverpirate
    Rich
    Pennsylvania
    So raise the chains up a link on the WDH? Otherwise make them tighter?
    lynyrd3 likes this.
  19. May 23, 2017 at 11:49 AM
    #1399
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    or adjust the angle of the hitch so the bars are lower, whichever works.
  20. May 23, 2017 at 11:55 AM
    #1400
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Could it just be an issue of single axle vs double axle trailer?
