The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. May 6, 2018 at 4:30 PM
    #1581
    MightyNeb
    MightyNeb Member
    Taco 4 cylinder, extended cab, long bed 2000
    Pretty easy to scoot the boat boat on that trailer, but the last thing I want is to have the tongue be to light. He said that he thinks its about 400 lbs.
  2. May 6, 2018 at 4:59 PM
    #1582
    MightyNeb
    MightyNeb Member
  3. May 6, 2018 at 5:35 PM
    #1583
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    another thing I found really helped my tacoma with a heavier trailer is the firestone ride-rite airbag kit. in fact, I stopped using my WDH entirely
  4. May 6, 2018 at 5:53 PM
    #1584
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Air bags do not completely replace weight distribution.
    jpereira2 likes this.
  5. May 6, 2018 at 6:36 PM
    #1585
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    no, they don't, but they help a softly sprung vehicle ride better with 400-ish lbs on its hitch. his boat trailer has a single beam frame so there's nowhere to put dual stirrups for a conventional WDH. I've heard of single arm WDH but not seen them
    also, not sure WDH is compatible with surge brakes, since the master cylinder is usually right at the hitch tongue. here's a single arm WDH for a 400-600 lb hitch weight...
    https://www.amazon.com/gp/product/B00W919GLM/
  6. May 6, 2018 at 8:01 PM
    #1586
    MightyNeb
    MightyNeb Member
    Huh... I think its time to give in and borrow a truck for the long haul. Makes sense that WDH wouldn't work with surge breaks, anything that limits that trailer tongue from loading up would be counterproductive.
    DoorDing likes this.
  7. May 7, 2018 at 5:37 PM
    #1587
    MightyNeb
    MightyNeb Member
    Thanks for everyone's input. Planning to borrow someone else's larger truck. I put the receiver on the tacoma today... We will see how she sits once the trailer & boat are here, then I will consider something like this. Though I am hesitant to put to much money into the current truck. Probably going to sell it this summer when I get the offer for the new job.
    Mister Blue likes this.
  8. May 7, 2018 at 6:48 PM
    #1588
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    So does an aal. And you don't have to worry about them losing air. Although non adjustable. Aren't boats normally pretty good with tongue weights and distribution?
  9. May 7, 2018 at 10:23 PM
    #1589
    MightyNeb
    MightyNeb Member
  10. May 8, 2018 at 9:00 AM
    #1590
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    I put sumo springs on my 06 SR5 with the TSB leaf pack and almost no squat with 450lbs on the hitch before engaging the WD hitch. They do ride a little rougher around town but I prefer the hard "truck" ride over the stock squishy ride.
  11. May 8, 2018 at 5:43 PM
    #1591
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Honestly I've had mine on so long I don't remember who mine are from. 5 yrs, and still kicking. I had the stock 3 leaf, and then did the aal. I have a topper and about 100# of tools in the bed, but mine has always rode decent, and takes a load well (insert dirty comment here). I'm resisting taking it in for the leaf spring recall, cause I don't want to argue or have them screw everything up.
  12. May 10, 2018 at 1:28 PM
    #1592
    StormShadow
    StormShadow Well-Known Member
    Anaheim, CA
    2008 White Tacoma TRD Sport Going Off-Road
    Demello Front Bumper, Superwinch 9500 SR, PIAA 510 Fog, Relentless CB Hood Mount, Cobra 75 WX CB, CBI Ditch Light Mount with Rigid HyperBeams, Throttle Body Riser, K&N Intake, Flowmaster Super 50 Dual Exhaust, BacFlip Bed Cover, Custom Fab (Jack, Shovel and Axe Mount), TechDeck Base for Ram Mounts, Custom fab aluminum tailgate panel, Pelfrey Built aluminum skids, Demello sliders, twin ARB compressor, Custom fab camp light, HAM antenna with handheld, Custom Fab traction pads and bed mount, VTX Rogue 16's in bronze, 18 gallon onboard water storage and DC pump, 12v additional pusher radiator fan, ABS kill switch, Wilco tire carrier, . . . . . . .
    Excellent thread tow guru! Great job Maverick491.
  13. May 15, 2018 at 7:51 PM
    #1593
    mxjagracer
    mxjagracer Well-Known Member
    Asheville NC
    2000 Tacoma 4x4
    I can't find sumo springs that will fit my 2000 4x4?? Does this sound right? If not, what are my other options (keeping it $300 or less)? I just put brand new leaf springs with an aal in there and I'm still squatting with my 5x10 enclosed trailer loaded with tools.
  14. May 16, 2018 at 10:07 PM
    #1594
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    airbag ? firestone ride-rite, you can adjust your ride height with an air pump after loading so its the same as empty, and the truck rides way better. you can get fancy and hard wire it to an onboard compressor so you can adjust it from the drivers seat.
  15. May 17, 2018 at 11:38 AM
    #1595
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    1000 miles, at max tow capacity? Without tow package add one like oil and tranny cooler?
    I think that's way too much strain on that little motor and tranny. For preservation of your vehicle I would just rent a bigger truck to haul it that far. It will make the drive much better, and with a full size you wont need to invest in all the extras like a WD Hitch
  16. May 17, 2018 at 11:51 AM
    #1596
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    if he stays in lower gears and keeps his RPMs up to mid range and takes it slow and easy, I'd not be too worried about the engine+tranny (although I'd be happier if it was a stick shift).
  17. May 18, 2018 at 10:20 PM
    #1597
    MightyNeb
    MightyNeb Member
    Borrowed a bigger truck for the long haul home. Uneventful trip.
  18. May 18, 2018 at 10:57 PM
    #1598
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    ++ for uneventful. I'm getting too old for excess drama in my life.
  19. May 20, 2018 at 3:45 PM
    #1599
    Katahdin
    Katahdin New Member
    2017 Tacoma DCLB OR 4x4
    Alright guys I need some of you to check my math. I have a 17' Toyota Tacoma DCLB OR with factory tow package. I went and looked at RV's the past couple weekends and the wife and I like the Winnebago Micro Minnie 2100BH the best at this moment. We have negotiated a price that seems fair but I want to make sure I'm not going to overload my truck (especially pin weight and payload). They are going to mount two 30lb LP bottles and one battery on the tongue (110lbs???) I will be using a WDH which if I understand it correctly I don't need to calculate for my pin weight but I do add to the payload on the truck? When I run the math it appears I will be at or very near max pin weight (640lbs) and within approximately 100lbs or so near max payload (1120lbs). Here are the numbers:
    Tacoma:
    GCVWR: 11,320
    GVWR: 5,600
    Curb weight: 4,480
    Payload: 1,120
    Tow rating: 6,400
    Pin weight: 640
    Winnebago 2100BH:
    GVWR: 7,000 (it's a tandem axle unit and I know I will not be loading it to capacity.)
    Dry weight: 3,760
    Tongue weight dry: 430
    Passengers: 400
    Cargo: 400-800 (not sure exactly and depends on if I'm dry camping or not)
    Tank capacity:
    31 gal fresh
    25 gal grey
    25 gal black
    When I run the numbers it appears I can not put much cargo in the bed of my truck and it will have to go inside the trailer while traveling.
  20. May 21, 2018 at 1:08 PM
    #1600
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    and don't rely on published tongue weights, they assume things are optimally balanced for 10% tongue weight... its best to actually WEIGH your trailer tongue as loaded, if you're anywhere close to the limits. ideally, get axle weights for your tow vehicle while hitched, too.
    oh, and don't forget, those truck specs, thats for the stock truck as shipped. anything you've added to it, like a camper shell, nerf bar steps, fancy bumper and underside armor, all thats added to the curb weight, hence subtracted from the available payload. typical fiberglass camper shell is close to 200 lbs, etcetc.
