The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Jan 20, 2019 at 8:57 AM
    #1661
    Rickybobby083
    Rickybobby083 Member
    Richard
    2018 Tacoma sport upgrade
    What weight distribution hitch would you recommend?
  2. Jan 28, 2019 at 10:14 AM
    #1662
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Probably lack of tow package features such as a engine oil cooler, power steering cooler, transmission cooler (AT Only), frame mounted hitch, larger alternator. Just these at the top of my head.
    BatteredTaco[QUOTED] likes this.
  3. Jan 31, 2019 at 3:42 PM
    #1663
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    2nd gen with tow package here. Plan on hauling around a 2,500lbs trailer and 3,500lbs car. Will be taking it from San Diego to Sacramento.
    When driving on flat roads, 5th or "D" is good or do I need to stay in 4th?
    4th going uphill?
    4th going downhill?
    Thank guys!
  4. Jan 31, 2019 at 3:44 PM
    #1664
    specter208
    California
    I would use 4 and drive 55-65mph. Better torque advantage and less chance of gear hunting. Drive no more than 65mph to keep your engine from screaming and decrease drag.
  5. Jan 31, 2019 at 3:57 PM
    #1665
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    So this would apply regardless going uphill, downhill or on flat roads?
    If it matters, it's a supercharged taco with 285s.
  6. Jan 31, 2019 at 4:01 PM
    #1666
    specter208
    California
    For all possible scenarios. 4th gear will also help keep your RPMs high enough to allow your water pump to spin fast enough for better cooling, aswell as provide better engine braking and battery charging advantages.
    ItsRichieRich[QUOTED] likes this.
  7. Jan 31, 2019 at 6:19 PM
    #1667
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Agreed on both accounts. I tow our camper, about 5200# loaded. I added a second trans cooler and highly recommend it. While watching temps after, to make sure everything was up to par, 4th was the only way to go. In 5th/OD, the temps climb significantly and quickly, regardless of terrain.
  8. Jan 31, 2019 at 10:03 PM
    #1668
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    Awesome, I appreciate you guys giving me these pointers. First time hauling something this big and far. Hopefully I can borrow the work truck but if not, the taco is going to be the work horse.
  9. Feb 5, 2019 at 8:58 AM
    #1669
    Trebla62
    Trebla62 Member
    Albert
    2013 pre runner, at, 2wd
    Adding trans cooler , leaf spring stabs
    Wow, this site and you members are so helpful and knowledgeable. It’s awesome! I belong to an Airstream group and the amount of knowledge and help people offer is incredible. Thank you!
    My situation is...
    I have 2013 prerunner, 2wd, without factory tow. I am adding a tow hitch and will be using a weight distribution hitch to tow a loaded 1957 airstream from one side of Mexico to another. I don’t know the empty weight of the airstream, since I gutted it, I’m guessing 1500-1900lbs; but I want to load 1000-1500lbs in it, and pull it with my Tacoma. I will be adding leaf stiffeners and a trans cooler, but that’s it.
    Can you guys tell me how this might go for me? FYI, the trailer does not have brakes installed.
  10. Feb 5, 2019 at 10:05 AM
    #1670
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    you need brakes installed other than that you should be fine. I tow around 5k
    Trebla62[QUOTED] likes this.
  11. Feb 24, 2019 at 7:01 AM
    #1671
    Chimpo
    Chimpo Member
    2014 TRD Off Road, white
    Febreeze Air Freshener
    2014 TRD Offroad, V6, 4X2
    Factory Tow package
    Truck is Stock w/a 6500# tow capacity
    Towing
    2019 Key West 239
    Dual Axle Trailer w/ surge brakes
    I am picking the boat up from the dealership in a week. I figure the boat and trailer, empty, will be at or just under 6000#. I told the dealer not to put any fuel in it.
    I'm considering a set of helper Hellwig or Sumo springs to adjust the ride attitude. Will those increase the safety of the tow, or am I wasting money with them?
  12. Feb 24, 2019 at 10:07 AM
    #1672
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    You can do what you want to beef up the springs, but you're going to feel that load back there. Hopefully you're not towing far, you'll notice that weight at any real speeds
  13. Feb 24, 2019 at 10:24 AM
    #1673
    bigbear1612
    bigbear1612 Well-Known Member
    Gary
    2018 Toyota Tacoma TRD 4X4 silver sky metallic
    Ride Rite airbags with onboard compressor, Trail Ridge towing mirrors, 28,000 gwv external transmission cooler, Roll n Lock bed cover.
    I am going to be towing a 4400 lb (wet) TT with my 2018 Taco TRD off road with tow package. I have a WD hitch with built in sway control and will be adding Firestone airbags soon. I also have a scan gauge 2 for trans temp monitoring. I am hoping that the OEM trans cooler is enough to keep the trans in range. Although it looks awfully small, Toyota thinks I can tow 6800 lbs with it. Does anyone have any suggestions?
  14. Feb 24, 2019 at 10:32 AM
    #1674
    Chimpo
    Chimpo Member
    So, your saying that some helper springs won't turn my Tacoma into an F-250?
  15. Feb 24, 2019 at 10:41 AM
    #1675
    bigbear1612
    Gary
    I wouldn't want an F250, Found on the Road Dead. Have you looked at some of the big ass TT's some of these guys are towing with a Taco? I think my TT at 4400 lbs loaded is very conservative. That is the GVWR for the trailer I haven't weighed it yet but when I load it I think it will be closer to 4000 lbs. Check out the show me what you tow thread.
  16. Feb 24, 2019 at 11:06 AM
    #1676
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Excellent post. I need to have it weighed sometime. Can you just pull into any truck scale on the hwy? I've been away from this site for a while. As far as towing in OD I do it whenever I can but I'm watching the rpm's and listening / feeling hows she's running. BUT our trailer is basically a glorified popup (Trailmanor 2720 FTW) and comes in around 3000 to 3200 lbs loaded. It's does okay on flat if there's no headwind but the slightest uphill and I'm in 5th or lower accordingly and always manually shifting when towing. I've gotten 17mpg towing that baby. :)
    SilverJack likes this.
  17. Feb 24, 2019 at 11:10 AM
    #1677
    Chimpo
    Chimpo Member
    That thread reassured me that I am not the only lunatic on the road! Thanks.
  18. Feb 24, 2019 at 11:30 AM
    #1678
    bigbear1612
    Gary
    I plan on getting my rig weighed. My TT's sticker says GVWR is 4400 lbs, I will be under that. It's a single axle with a hitch weight of 440 lbs. My Taco has a load capacity of 1294 lbs. I will be adding some airbags just to prevent any porpoising.
  19. Feb 24, 2019 at 11:32 AM
    #1679
    snowmanwithahat
    Scales like the ones at a truck-stop are the ones you'll want to hit up.
  20. Feb 26, 2019 at 11:03 PM
    #1680
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    Hauled my M3 from San Diego to Sacramento for a track day at Thunderhill. Was worried about transmission fluid temp so I got a bluetooth OBD2 reader. Trailer was 1,500lbs and car was 3,500lbs plus about 500lbs of tools, gear and etc.
    Even going up 6%, the temp never got passed 215°F. Pretty happy with how the truck hauled the car and trailer.20190223_163528.jpg
