The "Tire inflation" light came on , but....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2012_Prerunner_man, Nov 24, 2015.
  1. Nov 24, 2015 at 10:48 PM
    2012_Prerunner_man
    2012_Prerunner_man [OP] Active Member
    J.
    2012 Prerunner Crew Cab
    I checked my tires with an accurate gauge , and they are all at exactly 30p.s.i. , which is what the owners manual in my 2012 Prerunner say they should be ( with the 2.7L motor , and the tires being size P245/75R/16's , which they are that size )... I drove it around to see if the light would go off , but no luck yet . Any ideas ?
  2. Nov 24, 2015 at 10:51 PM
    BotoSlap808
    BotoSlap808 JAHblessed
    Kaneohe,HI
    2015 sport DCSB
    Spare tire or could be a tpms sensor gone bad
    QChawks and jdg like this.
  3. Nov 24, 2015 at 10:55 PM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    If spare is aired up that means bad tpms
  4. Nov 24, 2015 at 11:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The light comes on after a certain percentage is lost, they could have been overinflated when it was set and now the system sees 30 psi as under now, you also want to check the spare as mentioned above.
  5. Nov 24, 2015 at 11:12 PM
    2012_Prerunner_man
    J.
    Well, that was it... the spare tire was down on inflation... Thanks fellow owners !!
  6. Nov 24, 2015 at 11:27 PM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
  7. Nov 25, 2015 at 4:33 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    My opinion: people survived the past 100 years of cars without tire pressure gauges. We can too. If it's broken, who cares. Get out and look regularly.
    I only listen to my spedometer, fuel gauge, and RPM gauge. Anything else is white noise.
    1buzzbait likes this.
  8. Nov 25, 2015 at 2:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    2012 doesn't have a TPMS in the spare when stock from the factory.
    Just reset the TPMS to the pressure you have now if it is at the sticker pressure.
  9. Nov 25, 2015 at 2:18 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    BotoSlap808 likes this.
  10. Nov 25, 2015 at 3:06 PM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    My work truck is a 2012 and it has tpms in the spare straight from factory
  11. Nov 25, 2015 at 3:15 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Let's assume one has a bad sensor. How does one isolate it to the particular wheel and what's the avverage cost, is it a dealer-only job?
    Wife's Rav4 is the one, 05..already checked spare and no sensor.
  12. Nov 25, 2015 at 3:30 PM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    Only way to test is a tpms diagnostic tool that scans and tells you if it's a dead battery, weak signal or functional
  13. Nov 25, 2015 at 4:40 PM
    ABA180
    East Bridgewater MA
    I'd presume that's a general tool, not toyota specific?
  14. Nov 25, 2015 at 4:59 PM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    I believe it's general tool
  15. Nov 25, 2015 at 5:00 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    There hasn't been a TPMS in the spare since 2011 IIRC.
  16. Nov 25, 2015 at 5:03 PM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    Just serviced my 2012 work truck 3 weeks ago and there is a tpms in the spare idk maybe just a Hawaii dealer thing but it's got one fact
  17. Nov 25, 2015 at 5:05 PM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    Also like op said he aired up spare and it fixed the light which means his has tpms
  18. Nov 26, 2015 at 6:37 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is odd!
  19. Nov 26, 2015 at 6:46 AM
    htgreen3
    htgreen3 Well-Known Member
    Central Virginia
    2015 TRD OR
    I had the same problem, aired all up to 35 psi, still had the dreaded TPMS light, call the dealer, they said if the light is blinking, bad TPMS sensor, otherwise air the spare to about 38 and my problem should be solved, if not bring it in for a $100 TPMS diagnosic test. Aired up the spare to 38 and problem solved
  20. Nov 26, 2015 at 7:01 AM
    nine2nine
    nine2nine Well-Known Member
    Greensboro N.C.
    06 TRD Tocoma Sport 4wd
    I bought a kit that is used for the Dually trucks rear wheels.It has two steal braided hoses that are about 12 inches long and 2 clamps to hold it to the wheel like the one from Amazon link above but is at half the price.It makes it a lot easer to air up spare tire.
