The Tour
Discussion in 'North West' started by Blackdawg, Jul 18, 2017.
  1. Aug 31, 2017 at 3:55 PM
    #301
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, I'll figure out a way to make it work. Was going to bring the propane tank anyway as I now have an extension/adapter to make it work with the stove.
    I would be great if someone else were to bring along another 20 lb propane tank too so we have backup fuel.
  2. Aug 31, 2017 at 4:01 PM
    #302
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'll see if I can. Not sure yet. Swapping bed racks this weekend to get our packing dialed in with the 6 foot bed.
  3. Aug 31, 2017 at 5:32 PM
    #303
    Digiratus
    Roaming the PNW
    The RedHead
    Are you going to have 3 passengers?
    And it looks like I get to see the grey truck (frankenjr) in a little bit. I'm hoping its running.
  4. Aug 31, 2017 at 6:56 PM
    #304
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty wishful at this rate. Fires are still raging hard. Tend to keep them in place till Nov.
  5. Aug 31, 2017 at 6:57 PM
    #305
    Blackdawg
    Monte
    Wyoming/St. Louis
    Zane "new" truck.
    Kristen got her time approved?
  6. Aug 31, 2017 at 8:26 PM
    #306
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good to hear!
  7. Aug 31, 2017 at 9:37 PM
    #307
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, good to hear about Kirsten.
    Yes, frankenjr is Zane's grey truck.
    And no, it isn't running yet. Tho I am convinced it will and in time to make the tour.
    And, yeah, MT plans to keep the camp fire ban until there is a significant reason to lower the elevated fire danger. Which I read to mean significant rainfal. Which is not in the forecast before October.
  8. Aug 31, 2017 at 9:38 PM
    #308
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah i doubt it'll change.
    Wyo is all good though!
  9. Sep 2, 2017 at 10:06 PM
    #309
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    So, I have 31's. Could I make it with a bit of extra spotting? If so, and if you guys will have me, I'm in for the full two weeks.
  10. Sep 2, 2017 at 10:17 PM
    #310
    Blackdawg
    Monte
    Wyoming/St. Louis
    noooooo!!! Really?! Sweet!
    Do you have sliders?
  11. Sep 2, 2017 at 10:21 PM
    #311
    turbodb
    Dan
    PNW
    AdventureTaco
    Yup.
    HAM radio only right now though, and not sure I have time to install a CB. May grab a hand-held, which will suck, but will be a short term stop gap if we're all using CB. (or can I get away with HAM?)
  12. Sep 2, 2017 at 10:22 PM
    #312
    Blackdawg
    Monte
    Wyoming/St. Louis
    went to your build. You've got skids and sliders.
    We can get you through it all. You won't be the only dude on 31s. @Speedytech7 will be as well.
    3 trails will have fun spots.
    Goose has a spot on it, but it isn't that bad. Worse then the last time everyone else was there.
    Boulder basin we will be going up. Will be fun for you. But you have a winch :p you have a locker?
    Shoshone lake and Christina lake in Lander will be the most painful for you. Not unpassable, just slow and may be stressful. Otherwise, you'll be good.
  13. Sep 2, 2017 at 10:23 PM
    #313
    Blackdawg
    Monte
    Wyoming/St. Louis
    See above.
    And sadly no. Only three of us will have Ham. 4 with you there. Everyone else has CBs. Not a lot of decent handheld CBs. But we will be using the Hams at times so you should be good. We will keep you in the middle of the group so won't be a problem.
  14. Sep 2, 2017 at 10:32 PM
    #314
    turbodb
    Dan
    PNW
    AdventureTaco
    Rear locker, yup. Not the front though.
    Hmm, OK - so if I don't get a CB, staying in the middle will be great and maybe you or @Digiratus can keep me in the loop. Any good antenna hood mounts on Amazon (haha, right!); that's probably my only way of getting it in time.
  15. Sep 2, 2017 at 10:35 PM
    #315
    Blackdawg
    Monte
    Wyoming/St. Louis
    Both Mike and Ben run their CBs off the hood. Its a great location for it. If you get a full radio, go for the uinden 520xlpro. It'll fit in the ash tray.
    Rear locker, perfect. You won't have any problems then! Won't need a front on this trip.
    Insane you got time off so late and so much time off. But welcome!
    You'll be the last person we can let join.
  16. Sep 2, 2017 at 10:41 PM
    #316
    turbodb
    Dan
    PNW
    AdventureTaco
    Sweet, will be great to tag along with you guys. The work situation was pretty crazy, but that's a story for in-person. I'd mentioned to Ben that I'd be in next year for any time, but then this year worked itself out! :yay:
    What antenna do you recommend with the Uniden, and I assume I'll need some coax as well. Even if I can't get it installed before the trip, I might as well get it all ordered.
  17. Sep 2, 2017 at 10:44 PM
    #317
    Blackdawg
    Monte
    Wyoming/St. Louis
    hey, if i can fab a new jerry can mount. Swap leafs. Wire in my lockers and new bed socket. Swap bed racks and tents in 3 days..
    You can get a CB installed :D
    Yeah get a 18' coax and i think ben has a 2' firestik and mike has a 4'. Both work good. I mean they are CBs. Nothing special about them anyways. Wire it to the battery direct and you'll be good to go. We can tune it for you on the trip.
  18. Sep 2, 2017 at 10:47 PM
    #318
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You're a local right? Seattle area. If you order the CB stuff I'll help you get it all installed and tuned if you come over.
  19. Sep 2, 2017 at 10:51 PM
    #319
    Speedytech7
    I'm still building a whole fuckin truck and installing a CB haha, he can install a CB in two weeks
    Blackdawg[QUOTED][OP] likes this.
  20. Sep 2, 2017 at 10:52 PM
    #320
    Blackdawg
    Monte
    Wyoming/St. Louis
    your time line going to work out?? haha
    And yeah, where are you coming from generally @turbodb
    If it is seattle, you'll be #4 from there haha
