The Tour
Discussion in 'North West' started by Blackdawg, Jul 18, 2017.
  1. Sep 6, 2017 at 1:23 PM
    #401
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That's true...i mean it goes even stiffer, can get like, 360/85 or something like that. I'll see what dsm says when I talk to em.
    Throwing away more money!!!! Yay!
    It's ok the truck will be much better set up and I can not throw hundreds of dollars at it for a few years...
  2. Sep 6, 2017 at 2:25 PM
    #402
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah. Bet you could fit the short body 12s still.
    Go out a measure though first.
  3. Sep 6, 2017 at 8:43 PM
    #403
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    31ish extended eye to eye, 19.5-20 compressed. I messaged micah about getting some 12s. lets see if he has em in stock in time
    Blackdawg[OP] likes this.
  4. Sep 6, 2017 at 8:46 PM
    #404
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    m3bassman and Blackdawg[OP] like this.
  5. Sep 6, 2017 at 9:04 PM
    #405
    Blackdawg
    Monte
    Wyoming/St. Louis
    normal 12s i think then.
    well shit haha
    Glad you have a replacement coming.
  6. Sep 6, 2017 at 9:42 PM
    #406
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I luv my squelch control. 520>510. :D
    edit: Ooops! I was thinking 505 I guess. It has no squelch knob. Confused now, what is the diff between 510 and 520?
    edit: edit: Ah NVM. The 510 is missing RF Gain control.
    Yetimetchkangmi likes this.
  7. Sep 7, 2017 at 7:53 AM
    #407
    Digiratus
    Roaming the PNW
    The RedHead
    :rofl:
    Its funny how those things go isn't it. What started as, they just seem to work better with other 520s, became the TW 'goto' for CB radios.
    It is true though, they do seem to work better than other brands and models. But then, that is true for Toyotas and 1st gens too. :stirthepot:
    BossFoss and jubei like this.
  8. Sep 7, 2017 at 8:02 AM
    #408
    Blackdawg
    Monte
    Wyoming/St. Louis
    probably better sensitivity and microphone. is the best radio though that i've heard. Even compared to the big bad cobras the truckers use or galaxies.
  9. Sep 7, 2017 at 8:20 AM
    #409
    Blackdawg
    Monte
    Wyoming/St. Louis
    idk if its 6w haha would be funny though.
  10. Sep 7, 2017 at 8:31 AM
    #410
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    A day late and a dollar short again...my shocks will probably show up the week we get back from this trip
  11. Sep 7, 2017 at 8:35 AM
    #411
    Digiratus
    Roaming the PNW
    The RedHead
    I'm not sure why but I have always suspected that the way they are tuned they work better with other, identically tuned radios.
    We think of 40 CB channels as sharply defined frequencies but I suspect that there is some variation among brands as to how the radio actually utilizes the frequency. It would obviously be the portion to the right of the decimal point. For example, is ch. 19 always exactly 27.185 Mhz on all brands? Or perhaps on Uniden's, or 520s in particular, ch. 19 is actually 27.1849 or 27.1851.
    This type of variation could be caused by the design of the radio's components and could contribute to the 'clarity' issue you referred to.
  12. Sep 7, 2017 at 9:28 AM
    #412
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    My rear shocks are getting rebuilt...sure hope they show up by next Friday haha
  13. Sep 7, 2017 at 1:39 PM
    #413
    Digiratus
    Roaming the PNW
    The RedHead
    Based on what I recall from the gpx track he made, I think mid-day Saturday we will be heading into the Big Horns on highway 14 (alt). Will be coming from the north on highway 37 which joins 14a just east of Lovell.
    You could split from there. Take 14a west thru Powell (wave at Meagan, Sue and Steve as you go by) and on to Cody and then into the park. IIRC, there is some dispersed camping along the north fork of the shoshone river before you get to the park entrance. For sure there are some big 'pull-outs' along there.
    [​IMG]IMG_8400 by mike digirat, on Flickr
    [​IMG]IMG_8387 by mike digirat, on Flickr
    [​IMG]IMG_8389 by mike digirat, on Flickr
    [​IMG]IMG_8396 by mike digirat, on Flickr
    jubei and 90yota like this.
  14. Sep 7, 2017 at 2:41 PM
    #414
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I get it.
    pretty dificult to predict this from here.
  15. Sep 7, 2017 at 8:07 PM
    #415
    Blackdawg
    Monte
    Wyoming/St. Louis
    well..shit haha
    Me too. That would suck..
    ThisVV BUT see below..
    @m3bassman if you take 14 into yellowstone camping is VERY limited. ALL private until the forest line. Then there is basically just camp grounds until quite a ways back. Then you'll have roads that go to cabins and such like where we stayed last time. No other options really besides just camp grounds.
    I do agree with Mike, leaving at where we connect on 14a is probably your best bet. Sucks you won't be able to come wheel in the actual Big horns. My favorite mountains and have wanted to show you guys forever. We will be doing a hike in there as well.
    Again though, who knows on the actual timing of events.
    I just found out today that we are doing multiple location recordings on the 17th. So already..i am going to be late. Not super late i hope but probably 6-6:30 at the earliest.
    As for the rest of the trip, hit and miss. If we are headed up the big horns before 2-3pm, we will shoot for Copeman's Tomb for camping. About 28 miles of dirt over the big horns though. Could be ambitious. Camping is also something I am very worried about in the Big Horns as it'll be prime archery season and the weekend..so it'll be busier than normal. We MAY end up camping just across the bridge that 14a crosses and down by the river/lake. If we are running late. Plus might be warmer down below. Not sure.
    I know we have lots of options though so be easy to wing it.
    I really need to update my GPS data with the tracks i preran earlier.
  16. Sep 7, 2017 at 8:14 PM
    #416
    turbodb
    Dan
    PNW
    AdventureTaco
    Oooo - So do I get to sleep an extra hour on Sunday morning, or are the rest of us still meeting at ~5 for pizza?
  17. Sep 7, 2017 at 8:31 PM
    #417
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes..but its like a 50 yard "hike" haha
    Yeah i know. Just not a lot of dispersed camping up the north fork. You'd have to pay more anyways in yellowstone for camping then at one of the camp grounds in the northfork.
    and screw you! If everyone can keep up with Frank we will do just fine :D
    Totally up to the group. No need to wait on me though. I just know i'll be late now due to work.
    Hey..i was freaking EARLY last time mutha fucka! lol
  18. Sep 7, 2017 at 8:38 PM
    #418
    Blackdawg
    Monte
    Wyoming/St. Louis
    twice? Really? What was the second time? hahaha...oh thats bad..
    Actually until today was going to be super chill. Only just over an hour away from Tippet and we were going to have Frank done next Tuesday and Id drive him up here for the last week of work. Then just gonna leave from here. Was planning on leaving by 2..get some shopping done. Be early again.
    Not any more though..
  19. Sep 7, 2017 at 8:51 PM
    #419
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh..ha! that is true. I always forget that one.
    yeah. It'll be fine. Devin is not gonna be happy..but she'll get over it.
  20. Sep 7, 2017 at 9:08 PM
    #420
    Digiratus
    Roaming the PNW
    The RedHead
    Don't forget there is a time zone change too. You lose an hour crossing into Montana.
    Are you running an APRS rig along with your HAM?
