The Tour
Discussion in 'North West' started by Blackdawg, Jul 18, 2017.
  1. Sep 15, 2017 at 9:24 PM
    #561
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i wish i had ordered a new 18-135 this week. Mine is fucked up again. Zoom is all weird and isn't as sharp in spots any more.
    Not so cold here today. Kinda nice. Still raining though. Devin hit snow on Dun Raven Pass pretty good. All clear elsewhere. Said it was sticking was up high. Hoping not bad though.
  2. Sep 15, 2017 at 9:32 PM
    #562
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Excellent point that I hadn't put together. Thank you.
  3. Sep 15, 2017 at 9:35 PM
    #563
    Blackdawg
    Monte
    Wyoming/St. Louis
    beartooth pass is closed..shit
  4. Sep 15, 2017 at 9:44 PM
    #564
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    We could get to Cooke City by going thru the park via the Gardiner entrance....
  5. Sep 15, 2017 at 9:51 PM
    #565
    turbodb
    Dan
    PNW
    AdventureTaco
    Thanks for that edit @m3bassman. Clearly what I deserved! :luvya: hahaha
  6. Sep 15, 2017 at 10:01 PM
    #566
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep or over chief Joseph
    We won't do that cell service at Cooke city and I'll text you via aprs if not.
    Why wouldn't it? It's open and goes to Cooke city
  7. Sep 15, 2017 at 10:02 PM
    #567
    Blackdawg
    Monte
    Wyoming/St. Louis
    Here is GPS data. It's not 100% but pretty decent
  8. Sep 15, 2017 at 10:04 PM
    #568
    Blackdawg
    Monte
    Wyoming/St. Louis
    WYDOT doesn't have the stretch from 196 to Cooke City closed.
  9. Sep 15, 2017 at 10:39 PM
    #569
    Digiratus
    Roaming the PNW
    The RedHead
    two questions, why is this file 20x larger than the the one it replaces? Also, why is it a .gpx file type instead of .kmz file type? Keep in mind, I have no idea which file type BCN prefers.
  10. Sep 15, 2017 at 10:43 PM
    #570
    Blackdawg
    Monte
    Wyoming/St. Louis
    No idea on the size. Perhaps its due to the GPX file type..
    BCN reads GPX just fine. I exported it from BCN. There are only 2 areas different from the first one i sent you and thats the Kirwin area and the pryors. I didn't have the GPS when i rerouted the big horns with Frank or when i went up sunlight in Frank.
  11. Sep 15, 2017 at 10:46 PM
    #571
    Digiratus
    Roaming the PNW
    The RedHead
    Ok, as long as BCN can use it, that is what matters. FWIW, I was unable to open it with Google Earth. It looks like GE can't open this gpx file.
  12. Sep 15, 2017 at 10:49 PM
    #572
    Blackdawg
    Monte
    Wyoming/St. Louis
    worked for me just fine.
    I forgot the Killpecker dunes track though so hang on while i add that and i'll post another.
  13. Sep 15, 2017 at 10:57 PM
    #573
    Blackdawg
    Monte
    Wyoming/St. Louis
    Here is all tracks I have. Everything else I just know where to go so you'll just have to follow haha
  14. Sep 15, 2017 at 11:02 PM
    #574
    Digiratus
    Roaming the PNW
    The RedHead
    Like Shoshone lake? Thanks... I know the way. :luvya:
    Win 7 has no idea what a .gpx file is and I can't get GE Pro to recognizes it.
  15. Sep 15, 2017 at 11:05 PM
    #575
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im on win7 right now lol
    Go to GE. Open. Then at the bottom right of the file browser, change file type from KMZ KML to GPS(gpx, ect ect ect)
    Should see it. Open it fine. Have it generate KML tracks.
    Id just move it directly over to BCN as is though. Will keep the color coding i bet.
    Yes, lander, like shoshone and christina. Not that i need any of these for any of this trip anyways haha
  16. Sep 15, 2017 at 11:23 PM
    #576
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, figured it out, thanks. FWIW, all the tracks are baby blue in color.
  17. Sep 16, 2017 at 6:53 AM
    #577
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's due to the kml render. Of you import direct into bcn it'll be colored and have way points
  18. Sep 16, 2017 at 8:02 AM
    #578
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah. I explored literally every road off of it i could when we went there. Most are very short dead ends to trail heads. Only way up high does it get interesting and if there is lots of snow, we aren't going. Cliff hanger shale stuff. Had a sketchy moment in Frank on one of them being super narrow. Thought the road was going to give out. there was another longer one, but it got too narrow for Frank and i think any truck really. Had to back out of a super tight S turn and down the trail a half mile. Was interesting. Then another had an entire tree down the middle of it. Not like across. But down the middle. Was huge. So didn't find out where that went. Again had to back down over half a mile of road.
    Sadly, like i said. If the snow looks heavy up high, im not sure we will bother. Its a narrow one lane road and just climbs straight up and only two spots that i can remember where you could turn around at. Not sure it'll be worth the risk. There was snow at the pass when i was there this summer that kept us from crossing the pass.
  19. Sep 16, 2017 at 8:11 AM
    #579
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn even the east entrance is closed. We had snow this morning at my place. Just at the snow line so was a dusting.
    web cams show snow dusting on the mountains. doesn't look thick though. Could mostly melt on sunday. But supposed to be light snow again when we are there. Would count on rain for sure.
  20. Sep 16, 2017 at 9:28 AM
    #580
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    wait what? Fuck! Think itll reopen?! That ads another 1.5 hours of driving if i cant get through the east entrance
