The ToyTec BOSS Lift Thread
Discussion in 'Suspension' started by peppinoss, Mar 29, 2016.
  1. Nov 6, 2019 at 6:57 AM
    #721
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    We definitely recommend for every lift at 3 inches but the Aluma series are extended travel which most extended traveled coilovers will require aftermarket ucas
    Kolter45 and knightacoma[QUOTED] like this.
  2. Nov 9, 2019 at 8:42 PM
    #722
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
  3. Nov 23, 2019 at 6:09 AM
    #723
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    After rocking this kit for a few thousand miles it is a stiff ride, I have the 650lb coils with a 170lb steel bumper on the front end. Thing rides pretty damn stiff and makes a loud thud/slam coming off speed bumps ( I've changed and double checked my whole front end, bushings and all). It is seeming to be impossible to get a smooth ride with any set up, which makes no since because I've been in other trucks with the same set ups suspension wise and they are SOOOO smooth and nice
    Chipi3s likes this.
  4. Nov 23, 2019 at 7:25 AM
    #724
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    Maybe running to much preload and the shocks are topping out? I didn't have ext travel so I put a .25" spacer on top to reduce my preload for the lift I wanted, unconventional and probably ill advised, but worked for me
  5. Nov 23, 2019 at 8:56 AM
    #725
    757yotas
    Virginia
    2007 TRD Sport
    I may give that a try, I dont see how it would hurt and I could take preload off
  6. Nov 25, 2019 at 6:57 AM
    #726
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Could be a over adjustment on the coilover. If you want, shoot me a pm and we can chat more in detail about the setup you have along with specifics.
    Thanks
    David
  7. Nov 25, 2019 at 9:35 AM
    #727
    dondecontente
    dondecontente Member
    Seattle WA
    2017 DCSB
    Anyone have tips for adjusting the collars? I cant get these budge
    I soaked these overnight w/ WD-40, then hit em again in the morning. Even tried Dumondtech chain lube to get some lubricity.
    Truck jacked, wheels off, bent the spanner and broke it. Put a 5/16" rod in with a 2' extended breaker, didnt budge either.
    I have the old style coilovers on '17 DCSB - Center of wheel<>fender dims are 23.5 (driver) 23.75 (passenger)
    It rides stiff as hell and is too raked, I'd like to get back down to 23" or 22.75"
  8. Nov 26, 2019 at 3:08 AM
    #728
    karatescotty
    karatescotty Well-Known Member
    Beaverton, OR
    2019 TRD Pro
    Saw that Toytec is doing 15% off on all Boss kits, might be pulling the trigger on an Aluma setup.
    :spending:
    Kolter45 and Ctupton like this.
  9. Nov 26, 2019 at 6:02 AM
    #729
    TVH475
    Montrose CO
    Try a spring compressor, may help to get the tension off?
    Kolter45 likes this.
  10. Nov 26, 2019 at 6:36 AM
    #730
    Ctupton
    Ctupton Well-Known Member
    It definite influenced me. Parts should start showing up today. Woohoo
  11. Nov 26, 2019 at 6:44 AM
    #731
    Kolter45
    Denver, CO
    same. picked up my kit yesterday. Big snow today in Denver so I’m sure that will effect some things
  12. Dec 4, 2019 at 10:09 AM
    #732
    dondecontente
    Seattle WA
    2017 DCSB
    How rough do your trucks ride? Is there a break in period?
    Boss coilovers w/ red #650, hub to fender is 23" both sides. Road cracks and bumps are jarring, with potholes and ruts the wheel drop rebound is fast and harsh.
    Compared to my last truck; '11 Sierra leveled with 5100's and that felt great. Thought I would step it up and go coilovers with the new truck, but it rides worse than a cheap spacer kit.
    Anyone have the same issue?
  13. Dec 4, 2019 at 11:02 AM
    #733
    Wippa411
    Wippa411 Member
    2013 Blue Tacoma SR5
    3” Toytec Lift
    Nice!! I have the Boss Kit w The Dakar/ Arms. Spend the extra money to get the arms if you want to do more than 1.5” lift. Itll save your Ride
  14. Dec 4, 2019 at 11:32 AM
    #734
    Ctupton
    I got the AAL instead of the block, and they are fabricated by Deaver. my Boss kit has the 700lb springs, but I got the 2.5s for the front. I haven't had a chance to install yet. Hoping to do it this weekend.
  15. Dec 4, 2019 at 11:34 AM
    #735
    Kolter45
    Denver, CO
    Can you provide us some pics? Got any weight on those 650s & plus other details about your truck?
    did you ever get them to budge?
    Ctupton likes this.
  16. Dec 4, 2019 at 2:15 PM
    #736
    dondecontente
    Seattle WA
    2017 DCSB
    Truck is a 2017 DCSB 4WD V6. Changes from stock; coilovers and rear shocks. (No bumper, winch, armor etc)
    I did get the coilovers to move, backed off 2(Driv) 3(Pass) rotations down to get 23" center of hub to fender. Nearly yanked the truck off the stands pulling on the breaker bar!
    I can take some pics when I get off work.
  17. Dec 21, 2019 at 7:29 PM
    #737
    757yotas
    Virginia
    2007 TRD Sport
    Can you get replacement 700lb coils for the 2.0 boss coilovers? I have the 650 but think I may need the 700s to reduce my preload since my front bumper alone is 170lbs @Toytec Lifts
  18. Dec 23, 2019 at 7:23 AM
    #738
    757yotas
    Virginia
    2007 TRD Sport
    To those of you that have the boss set up, how many inches of thread do you have showing? I have 650lb coils and 2" showing. Trying to see if I need to get the 700lb coils and swap them. My truck is riding like a dumb truck still and toytec said they can send me just the coils to swap out.
  19. Jan 7, 2020 at 3:51 PM
    #739
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Did you ever get a smoother ride?
  20. Jan 8, 2020 at 4:29 AM
    #740
    Ctupton
    I have the boss aluma 2.5’s up front with 700lb. Been on there for only couple hundred miles. But compared to the factory bilsteins with my readilift it rides a little better now, but does feel better planted and takes bumps a lot better. The rear I’m running. Their boss 2.0’s and the AAL
    Superhulk LB likes this.
