The Tranny Flush I paid for...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N919HJ, Jan 25, 2018.
  1. Jan 25, 2018 at 4:09 PM
    N919HJ
    N919HJ [OP] Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    So... While my frame was being swapped out I asked them to do a transmission fluid change. The service rep called it a flush and fill and explained that they had a machine they just hook up and it just does it. My question to all the smart people here is, where do they hook it up? I can’t find any indication that anything was pulled apart. The fill plug/bolt is untouch. The bolts on the pan are untouched. The tranny cooler lines coming out of the tranny are untouched. The hose clamps by the transmission cooler have zero indication that they were moved. I have yet to put the truck on jacks and follow the lines from the cooler to the transmission but I’m not expecting much. I bought this truck new and it now has 71k on it. I took it to the same dealer with 60k to have this same service done, left it there for 4 days while on a fishing trip, they found holes in the frame and never did the transmission service. I was . I would love for a Toyota Service Tech to explain the process to me. If you don’t want to share knowledge on this thread for privacy concerns, a pm would be greatly appreciated.
  2. Jan 25, 2018 at 4:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    The one and only flush I ever had done (an old GM) the shop used the cooling lines.
    There was no way to visually tell the hoses had been removed/replaced, other than they were wiped clean.
    Of course I could use the dipstick to confirm clean fresh fluid, especially compared to the previous fluid.
  3. Jan 25, 2018 at 4:40 PM
    N919HJ
    Ohio
    There is no dipsticks on our trucks. In my opinion you can tell if a hose clamp has been moved. Whether it be scratches on the hose clamp from pliers or scratches on the hose from the clamp being moved by hand. Just picture a 11 year old truck from the rust belt. If a wrench gets put on a bolt, you see it. If a clamp or any other part gets moved, you can see it.
  4. Jan 25, 2018 at 5:14 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Only other spot would be the hard line hookups on the trans by the neutral switch
  5. Jan 25, 2018 at 6:09 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    When I flushed my tranny via the coolant line, I pulled the rubber hose (return line) that went into the bottom of the radiator - seemed the easiest to access.
  6. Jan 25, 2018 at 6:38 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    I have asked my teacher about this flush machine, it screws into the transmission internally behind the fluid pan (i cant recall the exact name)
  7. Jan 25, 2018 at 6:41 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Also, when they swap frames they just kind of take out the tranny and engine together and move them out of the way so i don't doubt that they took out a tranny line somewhere or something to do it easier.
  8. Jan 25, 2018 at 6:45 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    trust me, if they don't check the fluid level per proper procedures after the flush the fluid level will be low. The logic of "put back in the same amount that was drawn out" will inevitably show up soon after with signs of low trans fluid. Have had my trans flushed three times since I bought it new, each time had to go back and have then actually check the fluid properly and get the level correct, each time having to add 1-2 quarts.
    N919HJ[OP] likes this.
  9. Jan 26, 2018 at 7:02 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Had dealer flush tranny at 50,000miles when the supercharger was installed.My friend has a tranny shop and pulled the pan and filter then refilled at 78,0000miles.they said looked like brand new and filter was clean!When you are a beaten remember your drive line is Getting Beat!!!Take care of it and u know the rest!
  10. Jan 26, 2018 at 1:56 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Mine has one.
    Jimmyh likes this.
  11. Jan 26, 2018 at 2:06 PM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    The flush machine is installed inline with one of the cooler lines. I did mine myself and the easiest spot was the auxiliary cooler. I would hope they actually did it. and yes they should have still double checked it was at the proper level by using the plug on the bottom of the pan.
  12. Jan 26, 2018 at 2:48 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Well, maybe they flushed the Tranny and left your transmission alone
    N919HJ[OP] and Fitz235 like this.
  13. Jan 26, 2018 at 2:49 PM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C, Rivian R1T
    My local dealer tried to rip me off on a machine flush. I don't think even half the service managers know the difference (mine was looking for a transmission dip stick :rofl:).
  14. Jan 26, 2018 at 3:19 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    :rimshot:
    No transmission thread would be complete without a pic of Caitlyn.
  15. Jan 26, 2018 at 3:50 PM
    N919HJ
    Ohio
    4 cylinder? Let’s see a picture. Purdy please!
  16. Jan 26, 2018 at 4:09 PM
    Canufixit
    New England
    You want a picture of my dipstick?? :rofl:
    CurtB and Jimmyh like this.
  17. Jan 26, 2018 at 4:11 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    no
  18. Jan 26, 2018 at 8:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You mean Bruce.
  19. Jan 27, 2018 at 8:15 PM
    DANGERMONEY
    DANGERMONEY Well-Known Member
    Go back and have a tech show u how the did it. Don't be shy about it. I learn a ton by saying..I don't get it...show me. I even went back periodically during my frame swap and learned a great deal.
