The Truck / SUV Club (Vehicle Security) Question
Discussion in 'Law Enforcement Officers' started by USArchangels, Dec 22, 2013.
  1. Dec 22, 2013 at 3:15 PM
    USArchangels
    USArchangels [OP] Well-Known Member
    Max
    Houston, TX
    '12 TX Pro Baja
    Stock BAJA: bfg ta ko 16's 60mm racing Bilstein & TRD coil springs up front 50mm remote resevior race Bilsteins in back 71/21 mpg MODS: AeroTurbine 2525XL Muffler on all stainless TRD exhaust. Chopped and dumped TRD Tailpipe. Now 90 degrees. Cut just after axle. aFe ProDry S drop-in air filter Secondary (wire mesh) Filter delete Wilson 4ft Flex Silver Load CB antenna Midland 75-822 CB - hardwired Passport Escort 8500x60 & TomTom GPS unit wired to interior fuse panel with add a fuse BAMF antenna mount (front for CB) Relentless Fab antenna mount (tailgate) Fake Bead Lock delete reversed white wall tires All mudflaps delete Predator Tube Step delete TX Baja decal delete debadged Avid bars front and back SnugTop Rebel Rear Diff Breather mod to bed storage compartment STANT locking gas cap with fishing wire. Interior Map lights - Green LED Interior Dome Light - Red LED ConsoleVault
    As a result of my friend's truck being stolen from his driveway, I decided to get a Truck / SUV Club security device that you lock onto the steering wheel in order to prevent / deter theft.
    I recently found out that a professional car thief actually seeks out cars with these security devices (The Club) as they use the metal bar in lieu of a crowbar / shim.
    Should / should I not use this item? Thank you all for your service.
  2. Dec 22, 2013 at 8:00 PM
    DelRioTaco
    DelRioTaco Well-Known Member
    Deep South TX
    Went to the dark side (GMC Canyon)
    The dirtbags will figure out a way to defeat anything, but using some type of security device will slow them down at least. I would guess that most thieves will pass up a vehicle with a security device vs. one without it if they have a choice. They want to get the deed done as fast as possible. I use the Masterlock version of "The Club" when I park in questionable areas. No problems yet.
