The truth about rev hang in the Manual Transmission.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kamille.bidan, Jun 28, 2017.
  1. Jun 29, 2017 at 7:37 PM
    su.b.rat
    su.b.rat broken truck
    yeah mine hangs the same as ever at 10k+ miles. what's up with this?
  2. Jun 29, 2017 at 8:02 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    It has been explained in several previous posts. If the people claiming to have cracked the Toyota ECU are correct it should be a relatively easy thing to fix--we fixed it 10+ years ago on the "New-Edge"4.6 L V8 Mustangs...
  3. Jun 29, 2017 at 8:05 PM
    su.b.rat
    thanks. I've already bought the OV tune, if that's what you're referring to. so it was just out of curiosity anyway. I'll be glad to see the hang go. it's basically driving in slow motion on my commute.
  4. Jun 29, 2017 at 9:04 PM
    aquasurf
    aquasurf Member
    Chazmann wrote: "...to make the (fuel mixture) richer", meaning more rich than lean and I understood he meant it as close to stoichiometric.
    He did not write "to make it rich".
  5. Sep 16, 2017 at 11:14 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I find the function of rev hang to be potentially dangerous. Shifting from 1st to second and waiting for the RPMs to drop leaves you vulnerable to being rear ended. Also going up a hill it costs you speed and momentum waiting for the correct RPM for a smooth shift. I frequently bog shifting to second up small inclines unless I rev ludicrously high or press the clutch pedal fast which causes the whole truck to jerk.
