The ultimate foglight upgrade H11 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jun 4, 2016.
  1. May 26, 2017 at 9:34 PM
    #161
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
  2. May 26, 2017 at 9:44 PM
    #162
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Its 3rd gen...
    Norton and airwhen[QUOTED] like this.
  3. May 26, 2017 at 9:44 PM
    #163
    airwhen
    Seattle, WA
    Too much to list!
    Say no more!
  4. May 26, 2017 at 10:01 PM
    #164
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    It sure made me want to post another modification thread.
    airwhen and crashnburn80[OP] like this.
  5. May 26, 2017 at 10:09 PM
    #165
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    3rd gen is a strange place. You post a unique useful upgrade and get ~30 replies, mostly critical. Someone in 3rd gen posts their mpg and gets 1500 replies and the thread takes off. I just don't understand.
  6. May 26, 2017 at 10:12 PM
    #166
    airwhen
    Seattle, WA
    Too much to list!
    I wonder if the early 2nd gens owners were the same way and the crowd changes as the model matures?
  7. May 26, 2017 at 10:14 PM
    #167
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Seems likely. But rather than complaining about drivetrain they were probably complaining about the larger body vs 1st gen.
    airwhen[QUOTED] likes this.
  8. May 26, 2017 at 10:20 PM
    #168
    airwhen
    Seattle, WA
    Too much to list!
    Your post was great, it's just a strange audience.
    Norton and crashnburn80[OP] like this.
  9. May 26, 2017 at 10:25 PM
    #169
    airwhen
    Seattle, WA
    Too much to list!
    No doubt!
  10. May 29, 2017 at 4:34 AM
    #170
    Haany4x4
    Haany4x4 Well-Known Member
    Calgary, Canada
    2016 Blue TRD Sport 4x4
    Excellent post man i thank you all for doing the work and yes its sad that the 3rd gen virus hit your hard work. Im gonna be doing your upgrade soon once i got all my parts and my design. Keep you posted
  11. Jun 1, 2017 at 8:36 PM
    #171
    DonEBeasley
    DonEBeasley Member
    Any update on this regarding bulb life in real life
    crashnburn80[OP] and airwhen like this.
  12. Jun 1, 2017 at 9:23 PM
    #172
    airwhen
    Seattle, WA
    Too much to list!
    I cannot give you the life duration until one has failed. It's 10 months now and likely 100-150 hours at the moment. I suspect I may get another couple hundred hours or more from Flosser 90W bulbs.
    I did have the Osram 85W bulbs in my headlights. I got 14 months and about 220 hours out of them.
    crashnburn80[OP] likes this.
  13. Jun 1, 2017 at 9:50 PM
    #173
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Same boat, I cannot give a life report on something that hasn't failed yet. Still going strong a year later. H11 is a long life bulb, as a point of comparison high wattage Optilux H11s are rated at 500 hrs I believe.
  14. Jun 1, 2017 at 9:58 PM
    #174
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    I'm familiar with your ultimate headlight posts.. you talked a little about the extra heat that gets generated and the dangers inherent.. my question is how are the housing holding up over time? Any melting issues? I've been close to pulling the trigger on the whole setup inc the smoked oem housings. I'm just a little nervous about cooking them!
  15. Jun 1, 2017 at 9:59 PM
    #175
    airwhen
    Seattle, WA
    Too much to list!
    Wow, those Optilux do last a while. I bought a set and I can honestly say it was a big downgrade from the Flossers. The color was a higher Kelvin, but the output was not as good. Having the headlights at about 4300K (50W ballasts on OSRAM Nightbreaker D2S HID bulbs) and the Flossers att about 3900K gives a nice light array and mix of color to drive with.
  16. Jun 1, 2017 at 10:12 PM
    #176
    airwhen
    Seattle, WA
    Too much to list!
    There is an increase in temp, but it causes no changes to the headlight and/or foglight's physical condition.
    I had the Ultimate Headlight Upgrade in for 13 months until I changed my stock housings for TRD Pro housings. My original housings I then retrofitted with projectors and BHLM. When I had them apart, they showed no signs of excessive heat.
    Zero physical changes in my foglight either. I have not taken them apart, but from the outside, they still look stock and fresh.
  17. Jun 1, 2017 at 10:20 PM
    #177
    b_r_o
    Alex
    WA
    2015 DCLB
    Thanx.. like i said, I'm really close to buying.. the smoked lenses are the right amount of tint and they arent too obvious.. I don't want a spaceship / retrofit look.
  18. Jun 2, 2017 at 5:43 AM
    #178
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Heat isn't an issue for the headlights, the large housings handle it plenty well. I've run this setup across several Toyotas for many years. For the small housing fogs it could be boarder line if you lived somewhere that was very hot and ran them in the extreme heat. I have had zero issues and my fogs still look like new from the outside.
    Good info, I figured they wouldn't perform as well as the Flossers but first hand experience is great. I always recommend the non-coated performance bulbs for output and bulb life, but many people always request something whiter/less stock looking. I expect the Flossers to have similar 500hr bulb life.
    And they are OEM. :)
  19. Jun 2, 2017 at 8:32 AM
    #179
    airwhen
    Seattle, WA
    Too much to list!
    Smoked lenses? I would really hope you aren't speaking of the actual outer lens being tinted. That pretty much ruins the output of any light. Maybe you are speaking of the TRD Pro assemblies? Those only have the internal bezel in a darker grey chrome (smoked if you will) where the outer lens and reflective bowl are identical and OEM.
    If you are to get ones with a darker bezel, be sure to get the actual Toyota ones and not like the Depo or others. Many of the aftermarket ones just are not up to par with quality.
    Yes, the projectors with the halo lights in any color do look like space ships. I omitted those for my lights.
  20. Jun 2, 2017 at 8:39 AM
    #180
    airwhen
    Seattle, WA
    Too much to list!
    Nice! I guess we will have to wait and see the actual, but at 500 hours, that will take a while.
