The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Dec 8, 2015 at 9:17 AM
    #201
    Doc Jr 8156
    Doc Jr 8156 Well-Known Member
    Rancho Cucamonga
    2013 DCLB Pyrite Mica 4X4 TRD Sport
    King 2.5 Shocks w/ resi front and rears Total Chaos UCA Icon AALeafs SCS SR8 Wheels BF Goodrich TA KO2 tires All Pro Apex Sliders K&N Air Filter TRD Seatbelt Straps TRD Hubs DeZee Bed mat Extang Trifecta Viper 5904 Alarm Antenna X Ultra Gauge AFE Stage 2 Intake TRD Exhaust OEM Roof Rack HID Headlights and Fogs Weather tech laser mats Alpine CDE 149BT Headunit HAT Clarus 6.5 components front and JL Audio C2 650x for rear 2 Alpine SWP T-10 shallow 10-inch subwoofers Alpine PDX V9 main amp, Alpine PDX M-6 mono sub amp Dual 10 inch sub box Pop-Lock Anytime fog mod Differential breather mod KB Vodoo Bed Brackets KB Vodoo Tailgate protector Midland Portable CB Firestick CB Antenna Osram Headlight Bulbs and Rallyelights harness
    I did this upgrade and it was great. However, my left side headlight has more scatter than the right and the cut-off is not well defined on the left than on the right. Is this because of the bulb? Godspeed.
  2. Dec 8, 2015 at 9:31 AM
    #202
    wedgemoose
    wedgemoose Well-Known Member
    Wedge
    Worcester,MA
    2014 TRD Sport
    I had the same problem Doc. But it was just me. My eyes were all confused trying to adjust the lights for a long time. I just couldn't get them right. And I thought the same thing as you. Next day I pulled up to a building at night and the horizons were perfect. So in my case it was just me. I could even see a "Z" shaped image against the building(it's lite and goes a little above the horizon). My problem was I was too far away from the wall when trying to adjust. And the wall was white. Pull up to a different wall and see if it changes for you(like it did for me). I thought I was nuts or something
  3. Dec 8, 2015 at 9:44 AM
    #203
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    If the bulb is seated and clamped correctly there should be no additional scatter and the clean cutoff lines should match up.
    Did you replace the headlight housings or just the bulbs? How far are you from the wall, 20-25'? You may try wedgemoose's suggestion, reflective white walls like a white steel garage door will make it difficult to align.
  4. Dec 8, 2015 at 11:46 AM
    #204
    Doc Jr 8156
    Rancho Cucamonga
    Thanks for responding guys. Wedgemoose mentioned exactly my problem.
    Crashnburn80, I just did the harness and bulbs upgrade and not the headlight assembly. I was testing mine on my white garage door at 20 feet distance. I'll find a white concrete wall next time. Godspeed.
  5. Dec 9, 2015 at 4:18 AM
    #205
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Nice to see a proper upgrade. I'm getting tired of seeing all the ass-hats with LED's and HID's incorrectly installed......it's annoying/blinding as hell when they're coming towards you or behind you.
  6. Dec 9, 2015 at 9:24 AM
    #206
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    @crashnburn80 or others - Looking for ideas. Where did you guys mount the 2 relays and the fuse holder of the harness? I saw the post #135 by @klavender1 using plexiglass, but looking for other ideas.
  7. Dec 9, 2015 at 9:34 AM
    #207
    wedgemoose
    Wedge
    Worcester,MA
    2014 TRD Sport
    Mine was kind of tough Subway. don't know if you want to do it or not. But I took my battery out and found a nice spot to the right of it(looking from the front of the vehicle). Drilled a hole and had a real hard reach to get a nut on the other side of the bolt. But here is where they ended up(pic). It's a perfect location for wire length and to be hidden and out of the way. But again a little tricky to get the nut and bolt tightened up. But you can get your hand up to where the nut ends up being if you really try and stretch for arm. Or you could use a self tapper instead?
  8. Dec 9, 2015 at 9:55 AM
    #208
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I've hard mounted mine in previous Toyota trucks, but the last 2 I did not. I tucked the relay with the extra bit of wire in-between the battery and fender. It fits snugly with the wiring and doesn't rattle around. Was never an issue on my 1st gen Tacoma, and I don't anticipate it being an issue on this one either. Wedgemoose has the cleanest mount I've seen so far.
  9. Dec 9, 2015 at 12:47 PM
    #209
    Doc Jr 8156
    Rancho Cucamonga
    Mine was almost at the same place where Wedgemoose placed his but inside the opening to the right of the pic Wedgemoose posted and a little bit towards the radiator mount. There was a small thru hole that accommodated a 10 mm 2-inch bolt and nut I used for mounting. Wdgemoose, how come the light plug in your picture still looks stock (brown)? Godspeed.
  10. Dec 9, 2015 at 12:53 PM
    #210
    wedgemoose
    Wedge
    Worcester,MA
    2014 TRD Sport
    Did I miss a hole!!!!!! I searched and searched and couldn't find anything!! I found one I could of used but it was too far away from the battery so I couldn't connect the wire(too short).
    And I did the relay mounting first before plugging in the new light socket. Good eyes. And Good catch. any way you could get a pic? to help other and I'm curious. If not, that's OK.
  11. Dec 9, 2015 at 2:34 PM
    #211
    Doc Jr 8156
    Rancho Cucamonga
    Wedgemoose,
    On my truck, a 2013, there was a hole along the radiator mounting bracket battery side. I will try to take a pic but I always get home from work late (I work 60 miles from home). Godspeed.
    AlCapwn likes this.
  12. Dec 9, 2015 at 9:24 PM
    #212
    Subway4X4
    Lloyd
    NY/NJ
    Done!!! Test drove it and there is definitely a significant change in light output IMO. Did an eyeball "headlight aim" check against my closed garage door and it appears to be same "cut-off line" as my OEM lights. BTW, the bulbs that I removed and replaced were OEM originals (10 years old.)
    @wedgemoose - your relay location looks nice and appears solid and @Doc Jr 8156 I couldn't find the phantom hole that you described. Plus I'm tired of scraped knuckles trying to get into these small spaces with drills, wrenches, etc.
    So I went with @crashnburn80 's method of neatly stuffing the extra length wiring and relays into the space between the battery and fender well and zip-tying into place. I mounted the fuse holder onto the inner fender with hi strength double stick mounting tape. It's mounted little higher for easy access, in case I need to change a fuse.
    Another great mod!
    Thanks TW!
    crashnburn80[OP] likes this.
  13. Dec 10, 2015 at 12:11 AM
    #213
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I just drilled 2 little holes and used self tapping screws. I mounted the relay about 5" away from the battery ground closer to the cab.
  14. Dec 10, 2015 at 7:16 AM
    #214
    wedgemoose
    Wedge
    Worcester,MA
    2014 TRD Sport
    Crash Definitely had the right idea. I asked him about mounting the relays after it was already too late. Just sitting there is fine(especially being zip tied). I wasted too much time doing my mount. I would recommend Crashnburns(and your) method. But yes another "great mod". It's been a couple months for me now and don't know how I lived without this before!!
  15. Dec 10, 2015 at 8:07 AM
    #215
    Doc Jr 8156
    Rancho Cucamonga
    I was not able to take a pic last night but I will try again tonight.
  16. Dec 10, 2015 at 8:27 AM
    #216
    sivart7208
    sivart7208 Well-Known Member
    NH
    18 DCLB TRD Off Road
    @Subway4X4 do you have any pictures of output on your 2005? So far I have only seen the newer 2nd gens
  17. Dec 10, 2015 at 2:20 PM
    #217
    Subway4X4
    Lloyd
    NY/NJ
    Not sure if you can see the differences between the two bulbs in pics. I can definitely tell the significant difference in-person.
    Truck headlights were 17 feet from garage door:
    First pic is Low Beam, OEM Osram 55W
    Second is Low Beam, Osram Hyper 65W
    Osram Hyper 70W High Beams (I forgot to take the OEM pics)
  18. Dec 10, 2015 at 3:20 PM
    #218
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Garage doors or walls do not provide the best test pics, but you can clearly see the first pic has smaller focused areas of light where as that second picture is more of a continuous flood. And those are the lower powered 70/65w bulbs. :)
  19. Dec 10, 2015 at 4:04 PM
    #219
    sivart7208
    NH
    @Subway4X4 looks good.. now to decide between the 70/65 or the 85/80.. I work in Boston about 6 months out of the year so I dont want to be blinding people from behind!
  20. Dec 10, 2015 at 5:47 PM
    #220
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You won't with either option. The cut off is maintained like stock. Does a stock halogen car blind you from behind? No, because the beam cut off keeps the light angled down to the road and below the horizon. The reason to choose the 70/65w is longevity. My 85/80w last about 12-15mo. The 70/65w will last much longer, though put out less light.
