The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Sep 18, 2019 at 9:12 AM
    #2321
    Fly Skids Up!
    Fly Skids Up! Well-Known Member
    Marc
    Fleming Island, Florida
    2014 regular cab, 4x4, 5 speed manual
    Fog lights, Weather tech floor liners, rear window tint, Gator pro tri fold cover and bed liner, Fuel Anza 16x8 wheels, Cooper Discoverer 265/70-16 AT3 4s, N-Fab nerf bar steps, The ultimate headlight upgrade, Pioneer speakers and amp, sound deadening, Bilstein shocks, Back-up camera, Class III trailer hitch,
    That's good to know. My harness is capable of supporting a Hella 90/130 watt H4 bulbs.
    I'm okay with the low beam output. It's the high beam output that I was looking to improve so stepping up to a higher wattage bulb sounds like a plan.
    Norton[QUOTED] likes this.
  2. Sep 18, 2019 at 10:20 AM
    #2322
    Fly Skids Up!
    Marc
    One issue that I'll mention. My Tacoma didn't come with fog lights. I installed the Toyota fog light kit p/n 00016-35220 exactly as per the kit instructions. After I did the headlight modification, the low beams would stay on whenever the key is on. I found that the low/high beam interlock relay from the fog light kit was causing a feedback to the low beam relay. I just simply modify the fog light kit wiring for anytime operation by disconnecting the orange/black low beam and the green/black interlock wires.
  3. Sep 18, 2019 at 8:03 PM
    #2323
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Be sure to check out the chart in the original post, the Hella 90/130 have very poor low beam performance, lower than a stock wattage performance bulb.
  4. Sep 19, 2019 at 2:24 PM
    #2324
    Fly Skids Up!
    Marc
    Crash, I just looked at the chart. Interesting that wattage doesn't always equate to brightness. Thanks
  5. Sep 19, 2019 at 3:36 PM
    #2325
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Keep in mind the chart numbers are peak lux, that is peak brightness at a single point in the beam. The higher wattage bulbs may produce more raw light, but that doesn’t necessarily mean that it will be as focused to concentrate and project that light as effectively as a lower wattage bulb. It really comes down to output and focus. If you turn up the output, but lose some of the focus, the beam may not project as well depending on how much focus was lost. Higher wattage bulbs use heavier filaments which are inherently less focused, so the gains in output need to outweigh the losses in focus if you will. Vs a high efficiency bulb that keeps the output roughly constant but turns up the focus for achieving projection gains. And the ultimate is of course increasing the output and increasing the focus, which is what the discontinued Osram Hypers did.
    Norton likes this.
  6. Sep 20, 2019 at 7:16 AM
    #2326
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  7. Sep 20, 2019 at 8:58 AM
    #2327
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I did see a few 85/80w all seasons on eBay out of China for outrageous pricing, although there is one negative review stating the product is not as advertised with no additional info.
  8. Sep 20, 2019 at 8:59 AM
    #2328
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Love my Superbrights
    Norton and crashnburn80[OP] like this.
  9. Sep 20, 2019 at 9:28 AM
    #2329
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You finally get them installed?
  10. Sep 20, 2019 at 9:29 AM
    #2330
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hell yeah, and got all 4 Hella Lights with Nightbreaker Laser bulbs in them.
  11. Sep 20, 2019 at 9:31 AM
    #2331
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    New Pro Headlights in the box to waiting to go on
    303tacoma likes this.
  12. Sep 20, 2019 at 11:11 AM
    #2332
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Nice!!!
    I just ordered mine yesterday local pickup and they had 10% off!!:bananadance:
    crashnburn80[OP] likes this.
  13. Sep 20, 2019 at 11:48 AM
    #2333
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Then I looked at how to install them and said FUCKKKKKKKKKK
  14. Sep 20, 2019 at 12:44 PM
    #2334
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The lower bolt is a bit of a pain to get to but it isn’t as awful as everyone makes it out to be, just undo the side bumper skin clips which will allow enough play to get them in and out as I covered in the thread.
  15. Sep 20, 2019 at 3:23 PM
    #2335
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Having long arms, I just reached under the headlights and removed the bolt that way. Didn't replace them after, no issues.
  16. Sep 20, 2019 at 3:26 PM
    #2336
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You're Coming over when
  17. Sep 20, 2019 at 4:05 PM
    #2337
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Getting the bolt off is easy from underneath, not sure why people make a big deal about that. It is getting the bolts mounting arm out that requires loosening the bumper skin for clearance that is a bit of a pain.
  18. Sep 20, 2019 at 4:44 PM
    #2338
    303tacoma
    Rebecca
    Rick it’s not that bad
    You can do it :)
  19. Sep 20, 2019 at 4:46 PM
    #2339
    replica9000
    2019 T4R ORP
    I didn't have to do that my way :D
  20. Sep 21, 2019 at 5:45 AM
    #2340
    303tacoma
    Rebecca
    @crashnburn80
    When you installed your new OEM headlights did you have to adjust the hotspot on them or were they good to go?
