The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Oct 30, 2019 at 12:08 PM
    #2441
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    It is a very small shop run by a lighting enthusiast on evenings and weekends. If you left a message or sent an email I’m sure you’ll get a response soon.
    raskal likes this.
  2. Nov 1, 2019 at 8:03 AM
    #2442
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    @crashnburn80 Thanks for putting this whole thread together. I'm using the Osram bulbs and they work great, but unfortunately I decided to use eBay headlight housing and one of them is leaking. I want to get the 05-11 OEM Smoked housings but I'm finding two different sets of PN's quoted around the board. Can you clarify for me what the difference is between the two below? I definitely like the lower price of the 2nd set listed. Thanks in advance.
    EDIT: So far, only difference I see is the first I quoted is 05-08 and the 2nd set is 09-11.
    OEM 2005-2011 smoked headlights:
    These are like the Pro lights, but came on select Sport models. These are the updated TSB version of the lights that do not have the melting DRL issue. TSB is available here.
    Right: 81110-04210
    Left: 81150-04210
    Smoke OEM (like the Pro lights) for about $170/ea.
    These are like the Pro lights, but came on select Sport models. These are available loaded with bulbs, and unloaded w/o bulbs, saving $60 off the set . These part numbers are for the unloaded housings. These are the updated TSB version of the lights that do not have the melting DRL issue.
    Right #81130-04173
    Left #81170-04173
  3. Nov 1, 2019 at 11:07 AM
    #2443
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks for pointing that out! This is the correct info, which is updated in the original post of this thread.
    Right: 81110-04210
    Left: 81150-04210
    Tag me where you see that other information and I will fix it. The other part numbers were mistakenly the pre-TSB lights that had the melting DRL issue. You want the updated parts which have the fixed the melting DRL issue, often referred to as the TSB lights.
    slow_divers likes this.
  4. Nov 1, 2019 at 12:14 PM
    #2444
    boostedka
    James
    NM
    Awesome! Thanks for that updated info. I'm also tagging and quoting you in the thread I found the other PN's in.
  5. Nov 1, 2019 at 5:11 PM
    #2445
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    question about theses headlights. I will be needing to buy a pair myself. I want the 2011 smoked headlights oem like I have now but my truck is an off road. not sure what you mean by select sport models. are these different than the off road? not a color picture so I cant tell
  6. Nov 1, 2019 at 6:21 PM
    #2446
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is the color difference (shown in the 2012+ configuration):
    I am not aware of any off road models that came with the smoked headlights from the factory, only later generation sport models that did. Did you own the truck since new? Either way you can see the difference and have the smoked part numbers to order.
  7. Nov 1, 2019 at 6:24 PM
    #2447
    williams63
    chili
    nh
    2011 dblcb
    yes I have a 2011 O/R that I bought brand new. has the smoked headlights. the dtrl are melting and cracking.
    crashnburn80[OP] likes this.
  8. Nov 1, 2019 at 6:26 PM
    #2448
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Hmm, maybe my info about it only being sold as stock on the sport is inaccurate, this would be the first I've heard of that. Regardless the info in the original post of this thread with the smoke assemblies for your year include the TSB fix in the listed part number to resolve the melting DRL issue. I would recommend ordering those.
    williams63[QUOTED] likes this.
  9. Nov 1, 2019 at 6:27 PM
    #2449
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ive seen a few offroads come with them from the factory. what package added them? i havent a clue
  10. Nov 2, 2019 at 6:12 PM
    #2450
    Biblebuilt4x4
    Biblebuilt4x4 Well-Known Member
    Bill
    2014 Reg. cab 4x4 automatic
    Did the upgrade to the headlights today. Used the Headlight Services harness with the Osram Superbrights. Now my headlights are on all the time and I can't turn on the high beams (except to flash). I had read thru every post on here so I thought it sounded easy. Hadn't read where anyone had this problem before. Any help would be appreciated.
  11. Nov 2, 2019 at 6:17 PM
    #2451
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Try swapping the relays and see what you get.
  12. Nov 2, 2019 at 6:24 PM
    #2452
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It should be plug and play, haven't had anyone else run into that issue. Agreed on try swapping the relays, it is possible one is defective. You don’t have headlight DRLs, correct (where you cannot turn the headlights off)?
  13. Nov 2, 2019 at 7:16 PM
    #2453
    Biblebuilt4x4
    Bill
    No, I don't have the headlight DRLs. It uses the amber turn signal bulbs for DRLs.
    Just tried swapping relays. Still the same.
  14. Nov 2, 2019 at 7:20 PM
    #2454
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Look in the OEM fuse box under the hood, try swapping the high and low headlight relays in there. The harness is super low tech, it gets a signal and activates the appropriate relay for high or low, there isn’t much to go wrong.
  15. Nov 2, 2019 at 7:43 PM
    #2455
    Biblebuilt4x4
    Bill
    I looked the fuse box. Couldn't find relays for headlights in there. There is one that says Head but I was looking for High and Low. I'll try again tomorrow.
    I did add some dielectric grease to the connectors at the bulbs. Would that cause a problem?
    I sent Mike an email but I know it will probably take some time to get a response.
  16. Nov 2, 2019 at 8:43 PM
    #2456
    Biblebuilt4x4
    Bill
    I
    I put the grease in the socket, not on the bulb. And I was wearing gloves when I installed the bulbs.
    MotoMoose68 likes this.
  17. Nov 3, 2019 at 7:24 AM
    #2457
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    At first, it was a Sport only thing for 2009-2011, and then the 2015 Pro. In between that, I know some base SR5s and Sport came with them as an option. Not sure about other trims.
  18. Nov 3, 2019 at 7:49 AM
    #2458
    MotoMoose68
    MotoMoose68 Well-Known Member
    Ed
    Southwestern Colorado
    2014 Tacoma TRD Sport
    Strut Spacer and block lift, w/33" tires on custom wheels.
    I'm not real familiar with the thread or procedure, but did you check for the Ground Switched part mentioned? If not that, then seems like a harness/relay issue.
  19. Nov 3, 2019 at 10:58 AM
    #2459
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Dielectric grease is non-conductive, only small amounts should be used but I haven’t heard of that being a problem in the past.
    I double checked the OEM fuse box, you are correct on the relay. To limit the problem to the harness, try unplugging the harness on the driver side and plugging just the driver side bulb into the stock harness. Just test the low beam briefly. Those bulbs will get hot quickly and I would not try the high beam. If it works then the issue is something is wrong with the harness.
  20. Nov 3, 2019 at 4:59 PM
    #2460
    Biblebuilt4x4
    Bill
    Yes, I checked the Ground Switched part mentioned. My 2014 is power switched. Thanks for the idea though.
    MotoMoose68[QUOTED] likes this.
