The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Dec 31, 2015 at 7:47 PM
    #241
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I THINK someone else posted a similar experience but, FWIW, I ran 70/65 bulbs on stock harnesses with NO problems. Light output was better than stock, but not much better. I recommend upgrading your harnesses if you want to go with 85/80 bulbs.
    The biggest issue I see with DRLs is shorter bulb lifespan.
  2. Dec 31, 2015 at 8:05 PM
    #242
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Thanks! I saw some pictures in this thread of the 70/65, and it looked decent, but for the same price I would rather the brighter ones for our long winters here.
    Our dtrl's are actually the Amber turn signal/parking lights not the actual headlights. I was mostly wondering if the harness would affect those or if they are part of a different circuit (probably are now that I think about it)
  3. Dec 31, 2015 at 11:06 PM
    #243
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Most of the folks here asking about the Daytime running light, are first gen Tacoma folks. Your 2006 is a 2nd gen, and does not use the headlights as its daytime running light, therefore there is no impact on the DTRL operation by using these bulbs / harness. Do treat your headlight receptacle connections with an antioxidant. (NO-OX) This will prevent corrosion, keeping voltage drops at the headlight connector to a minimum, and keep the connector from overheating.
  4. Dec 31, 2015 at 11:32 PM
    #244
    WormSquirts
    Braeden
    BC
    Awesome! Thanks for the info! That's exactly what I wanted to know. Should have figured, but thought I'd ask to make sure!
  5. Jan 1, 2016 at 8:10 AM
    #245
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    My 2015 runs the high beams as DTRL... And as stated above, with the SMS harness I've got no DTRL's any more.
  6. Jan 10, 2016 at 6:28 PM
    #246
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    True they are the best led upgrade overstock, but per their spec page has 1000 lumen low and 1250 lumen high beam, which is no comparison for the nuclear option of 1750 lumens low and 2400 lumens high beam.
    Norton likes this.
  7. Jan 10, 2016 at 6:32 PM
    #247
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct, but the reduction in voltage drop plays just as much a part of this upgrade as the increased power by the upgraded bulbs do. You can do one or the other, but the full extent of the upgrade will not be realized till you do both.
  8. Jan 10, 2016 at 6:38 PM
    #248
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Apologies for the super delayed response. Vacation during a product release equates to no life when getting back from vacation in order to make up.
    Another member ran into a similar issue and we suspect there may be a connection to lack of DRLs. All my trucks w/o DRLs were actually conventionally switched. Did you test yours? My truck with DRL work as expected. I was not previously aware second gens were available without.
  9. Jan 10, 2016 at 8:05 PM
    #249
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Where did you get those numbers? They appear a lot brighter than 1000 lumens for the low.
  10. Jan 10, 2016 at 8:10 PM
    #250
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  11. Jan 10, 2016 at 8:33 PM
    #251
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Notice the specs indicate + or -15% additional lumens. There is no way these things are 1000 lumens on the lows, as they are easily twice the brightness of every other LED bulb claiming higher than that (lumens) on their CREE chips.
  12. Jan 10, 2016 at 8:51 PM
    #252
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I did notice. Even at 1150 lumens low, does not compare to 1750 lumens. I think Philips is a respectable brand and would not shall we say embellish lumen output as other questionable brands may do.
    Would be interesting to have a side-by-side comparison. To bad I was staying about 30 minutes away from you week before last, in Livermore CA. Drove down in the Taco.
    Edit: Will probably repeat the trip next year. Could be an interesting experiment.
  13. Jan 10, 2016 at 9:08 PM
    #253
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Damn. I stay not too far away from there. That would had been an interesting light off.
    Correct me if I'm wrong, but isn't more halogen lumens required in order to compare itself to the same lumens that LED throws out?
  14. Jan 11, 2016 at 12:56 PM
    #254
    Kyle01
    Kyle
    Chicago
    I think what me and others are trying to say when we say "no DTRL's" is that we lost our DTRL's when going to this harness. Yes, I'm conventionally switched. And when I plug my stock harness back into my headlight bulbs it does use the headlight as a DTRL...
  15. Jan 11, 2016 at 11:49 PM
    #255
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Ohhh, ok, so you are saying your truck uses the actual headlight as the DTRL? Now that makes so much more sense. I realized something didn't make sense after my last reply and was hoping to beat you back here, but have been swamped. My truck uses the amber indicators as the DTRL which is why I was so confused. I was unaware of 2nd gens that use the headlight for the DTRL, I could see where this would cause an issue. If so, is your truck by chance from Canada?
  16. Jan 11, 2016 at 11:54 PM
    #256
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Maybe later this year I'll be down again and we can have a light-off.
    No, your LEDs will be noticeably higher in kelvin temp, and the whiter color will make them seem brighter but in fact lumen is the true measure of light output.
  17. Jan 12, 2016 at 12:31 AM
    #257
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Canadian 2nd Gens use the Indicator lights as the Daytime running light. We do not get a switch position on the stalk to turn off the DTRL; they are on when the engine is running, and the headlights are not on. With the headlights On, the DTRLs are off.
  18. Jan 12, 2016 at 12:34 AM
    #258
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    I worry these high wattage bulbs will melt the plastic headlight lens.
  19. Jan 12, 2016 at 1:00 AM
    #259
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No he has specifically stated it is on a 2015.
    This has already been disproven not only through myself running these bulbs on several toyota pickups over many many years, but also using infrared temp gun readings to measure the lens temp.
    Norton likes this.
  20. Jan 12, 2016 at 7:05 AM
    #260
    Kyle01
    Kyle
    Chicago
    2nd gen (2015) US spec (Texas built)
    SMS tells me the second gens (at least the later ones) burn the high beams at reduced voltage for the DTRL's. My Amber marker lights also come on, but are way off on the side, not in the center anywhere. Like I said, if I plug in the standard harness they work. It doesn't bother me enough to do anything about it… At least now – it's 10 below zero with the wind-chill today. Another double pole relay could solve the issue if anyone is interested in doing it.
