The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Jan 1, 2020 at 8:17 PM
    #2721
    rb9228
    rb9228 Well-Known Member
    Yuma, AZ
    2014 Tacoma TRD OR
    Actually no. I just looked at my order and found I got what I thought was the 85/80's.
  2. Jan 1, 2020 at 8:19 PM
    #2722
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I figured, I’d be really surprised if anyone found them for commercial sale at this point.
  3. Jan 2, 2020 at 5:45 AM
    #2723
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I think I'm going to deposit my spare stash of these in my 401k account.
  4. Jan 2, 2020 at 1:37 PM
    #2724
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    After several days to go through all 137 pages of posts, I've narrowed my selections to upgrade my US Spec 2008 Toyota Tacoma X-Runner (without DRLs - don't think that was an option)
    - a conventionally switched version of the Headlight Services harness:
    http://www.headlightservices.com/Wiring.html
    - the best bulb option with this harness, that is still available for retail sale without needing a secret handshake with the manufacturer is the Osram 100/90 Super Bright Premium bulbs:
    https://www.amazon.com/Osram-Premium-Off-Road-Headlight-62204SBPQTY/dp/B00NRA91XM
    - Until I purchase the above harness, the best bulb option for my stock Tacoma wiring is the Philips Racing Vision 9003:
    https://www.powerbulbs.com/us/product/philips-racingvision-h4-twin
    Is this correct? Did I miss anything? Would prefer not having to return any merchandise...lol
    Thanks!
  5. Jan 3, 2020 at 6:18 AM
    #2725
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    Want to throw out a huge thanks to crashnburn80 for bringing us this thread. I jumped out with my DVOM this morning to confirmed I have a "conventionally switched" headlight circuit. I just placed my order with Headlight Services for a harness.
    One question though, how the heck to you remove your driver's side headlight bulb without removing the battery...lol. Crap that's a tight squeeze! My truck is officially 12 years old, and I just lost my first headlight bulb (low beam filament). I'm thinking I won't get off that easy again, but the improved headlight performance is well worth the tradeoff.
    One thing that would be nice in this thread is to list the years and options of 2nd gen Tacomas that have conventionally switched headlight harnesses, and the ones that have negatively switched harnesses. My 2008 (non-DRL) Tacoma has a conventionally switched harness. Definitely keep the steps on how to perform a DVOM check, because that removes all doubt.
    Thanks again crashnburn80!
    crashnburn80[OP] likes this.
  6. Jan 3, 2020 at 6:49 AM
    #2726
    Too Stroked
    Tom
    If you think the driver side is bad, wait till you try the passenger side! Most people - me included - use more bad words there. In fact when you do remove the passenger side bulb, you'll find it easier to remove the Windshield Washer Reservoir (two 10mm bolts) and even the Power Steering Reservoir (three 10 mm bolts) to give you some room to work. (Most folks just remove the Windshield Washer Reservoir.)
  7. Jan 3, 2020 at 7:13 AM
    #2727
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    @crashnburn80
    Is there any interest in testing a H19 bulb and seeing how one performs in comparison to a +100 or better h4/9003? From what I've read it seems to be designed for use in small format lamps, so it should be highly precise. I'm wondering if this increased precision would carry over to higher peak intensity readings in larger h4 lamps, like the 2nd gen tacomas.
  8. Jan 3, 2020 at 8:22 AM
    #2728
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    After pulling the plug to check the power type with my DVOM, pretty sure I'll pull the battery to swap the driver's side bulb. I'll most definitely pull the washer bottle to swap the passenger's side bulb. When I first looked at the back of the headlight assembly, I thought "wow this is going to be easy"...then I noticed I was looking at the plug for the parking light...lol
  9. Jan 3, 2020 at 8:24 AM
    #2729
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    I'm currently running the Philips +130 I bought probably about 2 years ago. I may upgrade to the Racing Vision +150 for now. But I'm not sure how much improvement I'll see.
  10. Jan 3, 2020 at 1:57 PM
    #2730
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Mostly correct. Depends on how you define best for the Philips.
    -Philips Racing Vision +150 provides the highest intensity low beam at stock wattage, but reduced high beam due to to the coating.
    -GE Xenon +120 produces the highest intensity low beam at stock wattage without reducing the high beam.
    -IPF Fatboy60/80w bulbs produce the highest intensity low beam and stock performing high beam at above stock wattage, but capable running without a harness.
    Most 2nd Gens are conventionally switched, 1st Gen and earlier are ground switched. But I believe there have been exceptions.
    As @Too Stroked mentioned the side with the battery is actually easier! Just don't knock the clip off or things turn into a real headache.
    That is interesting. Check out this comparison from Lumileds, they test performance comparing a small format vs a large format and side by side in the same format lamps:
    https://www.lumileds.com/uploads/499/9-H18-demo-leaflet-pdf
    The only place I can seem to find the H19 is from Amazon UK, with an estimated ship date of 1-2 months.
    https://www.amazon.co.uk/Original-H...lb+halogen&qid=1578072856&s=automotive&sr=1-3
  11. Jan 3, 2020 at 4:23 PM
    #2731
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    from what i understand is the h19 sheild for the low beam is smaller... even at low its like having highs on in a h4 reflector
    im surprised HIR coatings havent found their way onto non 9012/9011 bulbs
  12. Jan 3, 2020 at 4:31 PM
    #2732
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Ive read the H18 bulbs are a suitable replacement for H7, but H19 might not be for an H4. But haven’t been able to find out why, so that would make sense.
  13. Jan 3, 2020 at 4:35 PM
    #2733
    Empty_Lord
    Dan
    heres the links i saved
    H4: https://imgur.com/a/Hx599R9
    H19: https://imgur.com/a/EFgh7Ba
  14. Jan 5, 2020 at 5:48 PM
    #2734
    Griffin26
    Griffin26 Active Member
    Virginia
    '19 Tacoma TRD OR DCSB
    Quick question...which bulb in the headlight is supposed to be the turn signal?
    I just installed the tinted oem headlights recommended in the OP and I was testing it out and only the inner Amber bulbs blink. I never paid attention to it before but I would think the outer amber would make more sense....or just both ambers
  15. Jan 5, 2020 at 6:12 PM
    #2735
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is correct. The inner bulbs are your DRLs and signals, the outer bulbs are your running lights. The behavior would not change with a headlight assembly swap.
  16. Jan 5, 2020 at 6:47 PM
    #2736
    Griffin26
    Virginia
    Ok thanks. I still think something is wrong though. When I turn on the headlights all three illuminate. Inner is turn signal which I still think is odd because if its outer you can see it from the front and the side. But I just double checked and nothing comes on when I'm in DRL mode
  17. Jan 6, 2020 at 5:17 AM
    #2737
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    Just wish I could find those GEs on Amazon. A pair of Philips Racing Vision +150s are only $25 on Amazon, so they are the best deal I could find.
    pinktaco808 likes this.
  18. Jan 6, 2020 at 6:38 AM
    #2738
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They are on Amazon. The Racing Vision are great bulbs though if you don’t heavily utilize your high beam, they outperform the GE low beam.
    GE Lighting H4 NHX/BP2 Nighthawk Xenon Replacement Bulb, 2-Pack https://www.amazon.com/dp/B00GZHC2DU/ref=cm_sw_r_cp_api_i_gy0eEbP1FP097
  19. Jan 6, 2020 at 7:21 AM
    #2739
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    Good to know! Thanks!
    Guess people can decide if they're 2X as good as the Racing Vision bulbs, since they cost 2X as much.
  20. Jan 6, 2020 at 10:46 AM
    #2740
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    Watched the YouTube video on how to release the clip, so I did the bulb change without moving anything out of the way. It's tight, but really not a problem if you've seen it done before (thanks YouTube!). Almost psyched myself out there...lol
    My only advice is to watch the video where they swap both bulbs, so you know exactly what to expect.
