The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. May 19, 2020 at 1:06 PM
    #2941
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    Yep plug and play. You will have to find something to cover up the passenger side plug so it’s not just open to the elements if you care. I’m using Osram 100/90 bulbs. Super bright and you can find them pretty easy. The link at the bottom of the page says 4 dollars a piece but in my Amazon App they turn into 17 dollars a piece probably due to my location. (Kodiak, AK)
  2. May 19, 2020 at 1:16 PM
    #2942
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    Open to the elements you have a pic for reference?
  3. May 19, 2020 at 1:26 PM
    #2943
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    You have 2 OEM headlight plugs, one on each side. The harness plugs into the driver one, nothing plugs into the passenger one when using the harness as the bulbs plug into the harness. Since nothing is plugged in, it is ‘exposed’. Most just wrap the front of the plug with electrical tape to keep any debris out.
    I recommend ordering the bulbs from PowerBulbs. They have no tax and free shipping, and a 20-25% off code on their site, they are out of the U.K. They will properly package headlight bulbs with care, unlike Amazon who often throws them loose in an oversized box.
    https://www.powerbulbs.com/us/product/osram-super-bright-premium-h4
    GonzoQuick, sheld, Regnar and 2 others like this.
  4. May 19, 2020 at 2:39 PM
    #2944
    Beer-toe
    Berto
    Menifee
    Dad Mobile
    Stickers
    thanks man
  5. Jun 12, 2020 at 7:15 AM
    #2945
    ToyTacoNM
    ToyTacoNM Member
    2010 Silver Tacoma TRD Sport
    Front: bilstein 6112, Rear: bilstein 5160, OME dakar springs, wheeler's offroad bump stops
    Lucky7th likes this.
  6. Jun 12, 2020 at 7:49 AM
    #2946
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Looks like a great deal to me.
  7. Jun 12, 2020 at 10:22 AM
    #2947
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The Hella 130/90w bulbs were tested in the output charts posted in the original thread. They were the lowest performers in the chart above stock. The focus of the bulbs are poor. Vs the 85/80w being the best performers on the market with higher power and increased focus. The reason for the All Season was that there were no more standard 85/80w bulbs left, only All Season. While the color is easy on the eyes, they diffraction coating does cause increased glare as the high color temp light is diffracted above the pattern cut off.
  8. Jun 12, 2020 at 1:18 PM
    #2948
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    Just an FYI,
    I have a set of the clear 100/80w Hella’s I haven’t tried in the Tacoma yet if you are interested?
    One of the Hella’s is over 20 years old and from Germany the other is from Hungry I think. They are what I used in my 78 280Z and could light up overhead freeway signs from a mile away. Also if you tape off the end (the gray part) then use 0000 steel wool to polish off the yellow coating it works great. I do this to all my All Season 85/80w bulbs. Make sure you clean the bulbs with lots of rubbing alcohol and cotton balls to remove any oil that might be on the glass!
    ToyTacoNM likes this.
  9. Jul 4, 2020 at 4:06 AM
    #2949
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Anyone know the part number for OEM HEAD relay? I know it's early and I didn't sleep a lot last night, but I can't find this in search function. :pccoffee:
    Beer-toe likes this.
  10. Jul 4, 2020 at 6:29 AM
    #2950
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Relay - Toyota (90080-87026)
    Genuine OEM Toyota Parts | 2003-2020 Toyota
  11. Jul 21, 2020 at 12:53 PM
    #2951
    LAHSO
    LAHSO Well-Known Member
    Jonathan
    2014 Super White Tacoma Prerunner
  12. Jul 21, 2020 at 1:40 PM
    #2952
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is designed to convert a ground switched system like a Gen 1 uses to a conventional power switched system like a Gen 2 uses. I don't think it would work correctly in a conventional power switched vehicle. There are much cheaper harness out there, but most that are cheap are very low quality, using failure prone low quality relays and localized grounding with smaller wires and some without ceramic connectors. There are many inexpensive options on Amazon. While it is more expensive the Headlight Services harness quality is really top notch and I highly recommend it.
    GonzoQuick likes this.
  13. Jul 26, 2020 at 6:18 PM
    #2953
    Willyummk
    Willyummk Well-Known Member
    Will
    HA TO CA
    2011 DCSB TRD Sport
    Curious if anyone has any experience with the Alpha Rex Headlights?
  14. Jul 26, 2020 at 6:31 PM
    #2954
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They release their 2nd Gen model?
    Willyummk[QUOTED] likes this.
  15. Jul 26, 2020 at 7:08 PM
    #2955
    Willyummk
    Will
    HA TO CA
    2011 DCSB TRD Sport
    Just seen someone post in the daily thread about installing them
  16. Jul 26, 2020 at 7:24 PM
    #2956
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  17. Jul 26, 2020 at 7:34 PM
    #2957
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  18. Jul 26, 2020 at 7:35 PM
    #2958
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    I dunno....Under Spec is says bulbs..
    Willyummk likes this.
  19. Jul 26, 2020 at 7:37 PM
    #2959
    Willyummk
    Will
    HA TO CA
    2011 DCSB TRD Sport
    Philrab likes this.
  20. Jul 26, 2020 at 7:51 PM
    #2960
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Wonder how the performance is with the projectors using H7 vs H4 in stock lens ..... hmm.
