The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Feb 1, 2016 at 1:40 PM
    #301
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I left mine originally, I think there is enough grease on there to prevent anything. Others have wrapped it in electrical tape. I'll probably get around to wrapping it next weekend when working on the truck.
    EDDO[QUOTED] likes this.
  2. Feb 1, 2016 at 2:12 PM
    #302
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    ^can you post pics of how you are going to seal it up?
    mahaloTaco likes this.
  3. Feb 1, 2016 at 2:21 PM
    #303
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Just wrapping electrical tape over it to cover the female plug face, nothing fancy.
  4. Feb 1, 2016 at 2:24 PM
    #304
    99TacoDriver
    South Louisiana
    ahh gotcha. i didnt do this mod but id like to do it in the future. there is no way of cutting the old rubber boot to make the new harness fit?
  5. Feb 1, 2016 at 2:36 PM
    #305
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The rubber boots fit perfectly, like stock. Because they are used in the exact same way as stock. They remain completely sealed. There is no cutting whatsoever.
    What EDDO was referring to above was the passenger side female electrical connector plug, which is not used since the standalone harness replaces it. On the driver side the plug plugs into the harness to control the relays. On the passenger side the plug is not needed or used. Since nothing is plugged into it, some people like to cover the face of the plug to prevent anything getting into the unused electrical connectors.
    timbobzimbob and EDDO like this.
  6. Feb 1, 2016 at 2:40 PM
    #306
    99TacoDriver
    South Louisiana
    gotcha, was thinking of something totally wrong
  7. Feb 2, 2016 at 7:12 AM
    #307
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Just lost my first 85/80w osram this morning. Lasted a whole 2 months! I've got a set on the way.... Small chance bulb had a fingerprint or something.
    Mush Mouse likes this.
  8. Feb 2, 2016 at 7:28 AM
    #308
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is really short. You can wear latex gloves on the install as an extra precaution. Ones in my gf truck are going on 14 months so far.
  9. Feb 4, 2016 at 4:56 PM
    #309
    jaredc2306
    jaredc2306 Well-Known Member
    Jared
    San Antonio, Tx
    2016 ACLB TRD OR Quicksand
    Has anyone done this in a sport with the turn signal mirrors? I just noticed today that my turn signals do not work on my mirrors anymore. Not sure if it is related to this mod, but this is the only electrical mod I've done.
  10. Feb 4, 2016 at 6:12 PM
    #310
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This mod has zero effect on turn signals. It is isolated to the headlight circuit only.
  11. Feb 4, 2016 at 6:22 PM
    #311
    jaredc2306
    Jared
    San Antonio, Tx
    That's what I was thinking/hoped. But now I need to figure out what else caused this now.... Hmmm.
  12. Feb 7, 2016 at 10:12 PM
    #312
    minimeg
    minimeg Old enough to know better, just wish I knew better
    AZ 85203
    2015 Access Cab w/ manual
    18x8 alloys, modified susp. w/ mis mods.
    I have read this tread and didn't read of anyone having troubles / issues with the extra heat hurting rubber boots / seals.
    I have read about the rubber going bad from the extra heat from the higher wattage bulbs, but none here.
    Any feedback about this or any issues?
    I did have 90/130w bulbs in my old 78 280Z on stock wiring! Talk about lighting up the road!
    Thanks for any feedback.
    MM
  13. Feb 8, 2016 at 12:48 AM
    #313
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I wholeheartedly agree with the use of non-powdered latex gloves to handle lightbulbs (or glass or anything clear for that matter). However, for folks who do not have latex gloves, a sparing amount of isopropyl alcohol will displace the oil left behind from finger prints with no ill effect. Acetone could also be used on glass only, but acetone may leave behind residue.
  14. Feb 8, 2016 at 7:18 AM
    #314
    Kyle01
    Kyle
    Chicago
    Now that I've done it a few times- I can get the bulb in the housing without touching anything in about 30 seconds... Not so good on my first attempts.
    My suggestion- unplug the old bulb, pull the rubber boot off, carefully unclip the retaining spring (so it stays in place) then pop the new bulb in, clip the retainer, slide the rubber boot on, plug it in. I tried doing it with the boot on. Difficult...
    Biscuits[QUOTED] likes this.
  15. Feb 9, 2016 at 10:29 AM
    #315
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I could to an IR temp scan of the boot when hot, but even with the 85w bulbs it isn't going to get hot enough to worry about degrading the rubber.
  16. Feb 9, 2016 at 1:13 PM
    #316
    minimeg
    AZ 85203
    Crash n burn (damn autocorrect)
    Thanks so much for all your work and feedback. I ordered 6 bulbs from a different vendor and I'm still on the fence about the wiring being the vendor I ordered my lights from didn't think there should be an issue. Plus just the wiring kit you used is over a $115 shipped. Not saying it's not worth that but there are so many other kits for half to one third a $115. (Sorry just trying to get the best bang for our buck) That's why we dumped the POS 2015 V6 manual Frontier and own a Tacoma. The Frontier ran great but it's cheaply built and it had issues that Nissan would not correct! (Done venting)
    Again Thanks so much for all your time and feedback!
    MM
    Edit; I / we should just pony up the $115 + for the wiring kit. I wish I could see it in person and installed.
  17. Feb 9, 2016 at 2:43 PM
    #317
    yonah
    yonah Well-Known Member
    Calling-in from east of the Rockies
    I did this modification to my last two Jeeps (before giving up the Jeep thing and getting a Taco). It is a worthwhile modification and the bulb/wiring upgrade makes a huge difference in light output.
    crashnburn80[OP] and jaredc2306 like this.
  18. Feb 16, 2016 at 8:49 AM
    #318
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Installed the new wiring harness on lunch break yesterday. Put the new bulbs in last night. I love the new lights. Lots more visibility all around.
    I've had the originals since I bought the truck in '12, and even changing these out yearly wouldn't bother me at all. Would say this is the most functional on road driving mod I have made, but most mods weren't done for on road either.
    crashnburn80[OP], ToyTacoNM and G.T. like this.
  19. Feb 16, 2016 at 7:52 PM
    #319
    Kyle01
    Kyle
    Chicago
    Grrrr... Lost my second 85/80 (other side) tonight. Hopefully my second set lasts longer.
  20. Feb 16, 2016 at 10:32 PM
    #320
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    While you may be able to get away with running higher wattage bulbs on the factory wiring, it will reduce your light output. This was discussed in depth way earlier in the thread. You gain a significant bump in efficiency by using the harness which causes the bulbs to burn brighter and produce greater output than if run on stock wiring.
    There are definitely cheaper harnesses available. But the harness I used is all Hella components, ultra heavy gauge wiring and assembled in the USA. I've seen others use off brand relays on harnesses built in China, and they work. But personally I'd rather pay for high quality components one time.
    Norton likes this.
