The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Nov 25, 2020 at 9:40 PM
    #3181
    SouthernWild
    SouthernWild Member
    Middle Georgia
    08 TRD Off-Road
    2017 Suspension (except leafs), Caliraised Ditch Lights, Leer Shell w/custom bed drawers, Black headlights
    Do we have any data directly comparing the best performing stock-wattage bulb against the best performing increased-wattage bulb?
  2. Nov 25, 2020 at 10:12 PM
    #3182
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    All the output charts in the original post. Philips Racing Vision +150 have yet to be beat for stock wattage, and the Osram 100/90w Superbrights are the current best high wattage bulb presently available. While the peak output looks close in these charts, the overall output of the Osram's will be greater, that is to say they will offer more light through the pattern. The high beams on the Philips will have reduced output due to blue coatings over the high beam filament. The 100W high beam on the Osram's are the nuclear option that will exceed HID output when combined with the HD harness.
    Chris(NJ) and Norton like this.
  3. Nov 26, 2020 at 7:29 AM
    #3183
    SouthernWild
    SouthernWild Member
    Middle Georgia
    08 TRD Off-Road
    Ah yes duh, thank you. Do you happen to have any data on the lux increase in stock-wattage bulbs when a conventional harness is added?
  4. Nov 26, 2020 at 7:35 AM
    #3184
    SouthernWild
    SouthernWild Member
    Middle Georgia
    08 TRD Off-Road
    Time for some DD SS3s then!??
    Edit: Ugh, I just watched the SS3 MAX go from $500 to $520 on their website.
  5. Nov 26, 2020 at 2:30 PM
    #3185
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Mathematically in theory I believe it comes out to roughly a 10% increase, but when I tested it I recall it being slightly higher. I did a post somewhere in here on it.
    The high power headlight upgrade will overpower the fogs, especially the 05-11 fogs which are very weak to start with. The SS3 is definitely the way to go, remarkably impressive products. I don't ever recall seeing the Max at $500, but they do have 15% off for black Friday going on now.
    Norton likes this.
  6. Nov 26, 2020 at 2:37 PM
    #3186
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I didn't think they were that bad. They were at least much better than previous vehicle's foglights :notsure:. Are they worse than the 12-15 foglights?
  7. Nov 26, 2020 at 2:56 PM
    #3187
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    12-15 and 16-19 TRD are nearly 3x the output of 05-11, however the pattern is also much wider as they are Toyota's 'wide angle TRD' fogs. So even though the output is 3x higher the peak intensity is not 3x higher.
    replica9000[QUOTED] likes this.
  8. Nov 26, 2020 at 3:03 PM
    #3188
    replica9000
    2019 T4R ORP
    I had 9005 bulbs in mine vs the original 9145. When I bought the 4Runner, the fogs with H16s almost seemed non-existent.
  9. Nov 26, 2020 at 3:16 PM
    #3189
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Definitely higher output then compared to the H16s, but the 9005s lack a forward glare cap on the bulb for use in an open reflector.
  10. Nov 26, 2020 at 5:56 PM
    #3190
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    9011 HIR bulbs for the win (but not with oncoming traffic)
    crashnburn80[OP] likes this.
  11. Nov 26, 2020 at 6:14 PM
    #3191
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Why is that? HIR bulbs put the filament in exactly the same place as halogens.
  12. Nov 26, 2020 at 6:23 PM
    #3192
    65skyturbo
    Mesa, AZ
    wdb[QUOTED] and crashnburn80[OP] like this.
  13. Nov 26, 2020 at 11:17 PM
    #3193
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
  14. Nov 26, 2020 at 11:18 PM
    #3194
    Beer-toe
    Berto
    Menifee
    Dad Mobile
    Stickers
  15. Nov 26, 2020 at 11:29 PM
    #3195
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    As listed in the first post, no and yes, respectively. These are the brightest bulbs currently available.
  16. Nov 26, 2020 at 11:46 PM
    #3196
    Beer-toe
    Berto
    Menifee
    Dad Mobile
    Stickers
    1st bulb listed as discontinued.
    2nd bulb I just copied and pasted to Amazon and that is what came up but thank you for sending right link
  17. Nov 27, 2020 at 4:41 AM
    #3197
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Common tactic. Friday/Monday sale wouldn't generate as much income if they didn't raise the "MSRP" before offering a discount.
    TegoTaco likes this.
  18. Nov 27, 2020 at 8:55 AM
    #3198
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If you haven’t ordered yet, “BLACK25” gets you 25% off at PowerBulbs for Black Friday.
    The Wolves and Boco10 like this.
  19. Nov 27, 2020 at 9:44 AM
    #3199
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
  20. Nov 27, 2020 at 12:27 PM
    #3200
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
    Thanks for this... Finally doing this upgrade now. Harness and bulbs purchased. Ordered some DD SS3 Pro fogs in selective yellow as well. Curtesy, @memario1214.
    Ready to light up the night!
