The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Feb 16, 2016 at 10:37 PM
    #321
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
  2. Feb 17, 2016 at 1:19 AM
    #322
    mahaloTaco
    Max
    Los Angeles
    I finally installed my harness and lights. I got the 85w and the upgraded harness. Not very bright at all.
    Mush Mouse likes this.
  3. Feb 17, 2016 at 7:52 AM
    #323
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Then you've done something wrong... Or you're not getting out where it's DARK?? When I lost my drivers side 85w I popped a stock bulb back in- and it looked completely dim in comparison.
    I think if you're expecting a big color change or pattern change this may disappoint you, it's the same color light, same exact pattern... But a shit-ton more light on the road.
    Norton and crashnburn80[OP] like this.
  4. Feb 17, 2016 at 9:13 AM
    #324
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I agree with this. The goal is to improve brightness, improve safety margin (to not fry OEM wiring, with higher output bulbs) and most importantly(IMO) to keep same light pattern, especially the same cut-off pattern in order to not blind oncoming drivers. This mod accomplishes all of that.
  5. Feb 17, 2016 at 9:24 AM
    #325
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    You would be the first person in 17 pages on this thread, and 3 pages on the gen 1 spin off thread to not be impressed by it.
    Looking at the before and after photos, it is very clearly much brighter.
    While admittedly my side-by-side photo isn't great, it also clearly also shows the light output is much brighter.
    The lumen output of the bulbs exceeds HIDs and is almost double that of stock, so I am not sure what you were expecting. As others mentioned, this upgrade doesn't give your lights a 'cool' looking HID color. Color does not equate to brightness. This upgrade is about pure functional performance.
    Norton likes this.
  6. Feb 17, 2016 at 9:25 AM
    #326
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Subed
    Still no issues OP?
  7. Feb 17, 2016 at 9:30 AM
    #327
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Question 4 you.
    Did you just change the fog lamp bulbs or did you upgrade the wire harness as well?
  8. Feb 17, 2016 at 11:43 AM
    #328
    mahaloTaco
    Max
    Los Angeles
    Never expected a color change. The light output from these headlights and wiring harness is not worth the money imo.
    I plugged the harness into the existing brown headlight plug and the battery and ground
  9. Feb 17, 2016 at 1:19 PM
    #329
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Can you put your stock back on and do a sidexside left light stock, right side with new harness and bulb.?
    I would like to see a second comparison plz?
  10. Feb 17, 2016 at 1:28 PM
    #330
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    Everyone running conventionally switched harnesses for 05-15? I've been running just the upgraded bulbs (with no ill effects) but I want to get the harness for added protection. I want to make sure I get the right harness and I don't have the knowledge to test for it :)
  11. Feb 17, 2016 at 1:39 PM
    #331
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    At least one Tacoma with daytime running lights that run on the headlights (not amber indicators) was ground switched. The test procedure is not difficult, could easily walk you through it if you have a multi-meter, or even a bulb voltage detector. The harness will also add efficiency which will get more power to your bulbs causing them to burn brighter.
  12. Feb 17, 2016 at 1:45 PM
    #332
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    Thank you for the help, multi-meter ordered from Amazon so I will be asking for you assistance in about a week when it gets here. Thanks again.
  13. Feb 17, 2016 at 1:47 PM
    #333
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No problem. Shoot me a PM or post in here with your questions when you are ready.
    PVT Pablo[QUOTED] likes this.
  14. Feb 17, 2016 at 4:01 PM
    #334
    mahaloTaco
    Max
    Los Angeles
    I don't have my stock bulbs anymore. I had LEDs before
  15. Feb 17, 2016 at 4:03 PM
    #335
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    Care to show us anyway just out of curiosity? LED vs Upgraded Halogens.
  16. Feb 17, 2016 at 4:18 PM
    #336
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Crap.
  17. Feb 17, 2016 at 4:29 PM
    #337
    Subway4X4
    Lloyd
    NY/NJ
    The light output of your previous LED's undoubtedly was the same or even greater than the Osram halogens that you just installed. But that was not the point of doing this Halogen Mod.
    From the Original Post:
    "Why not HID/LED?:
    LEDs have recently become popular, but most that improve light output over stock use microprocessor cooling fans to cool the LED circuit. Not a very durable design for off-road use, or any use. The cooling fan versions also require cutting of the rear headlight boot to fit, meaning the seal is shot and condensation inside the lens could become an issue. The optics may be questionable as LED light is directional vs Halogen being omni-directional, though some respectable manufacturers have claimed to recently solve the issue. The LED bulbs will also have lower CRI than Halogens. Numerous threads on TW have had people go to LEDs only later to return to Halogen due to the lack of reliability, the incorrect optics, and superior spectrum of the Halogens."
  18. Feb 17, 2016 at 4:34 PM
    #338
    mahaloTaco
    Max
    Los Angeles
    Yeah I had to cut my boot and I did get water inside
  19. Feb 17, 2016 at 11:58 PM
    #339
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 to ALL of this. Now that I've got a fair amount of night-time driving with my "ultimate headlight upgrade," I want to say thanks (again) to crashnburn80 for posting and advising on it. I've tried a number of other upgrade options (including LEDs). While this one was the most expensive, it also provided the best results. IMO, a great example of getting what you pay for. Highly recommended.
  20. Feb 18, 2016 at 12:09 AM
    #340
    mahaloTaco
    Max
    Los Angeles
    FOR SALE:
    $30.00 Shipped to your Door.
    Brand New.
    I installed these lights to test the quality and decided its not for me.
    Screen Shot 2016-02-18 at 12.07.51 AM.jpg Screen Shot 2016-02-18 at 12.07.44 AM.jpg
