The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Feb 13, 2021 at 8:26 AM
    #3601
    Rascon20
    Rascon20 Well-Known Member
    Santa Teresa, NM
    2010 Tacoma Off Road
    It’s such a noticeable difference. The high beams threw me off for the longest time. I was under the impression that my lights weren’t leveled correctly.
  2. Feb 13, 2021 at 12:45 PM
    #3602
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    Installed the headlight services harness this morning along with the bulbs. What a piece of cake easy install. Now to wait and see what the difference tonight is when it gets dark. I’m hoping it’s a significant upgrade, but guess we will wait and see.
  3. Feb 14, 2021 at 8:50 AM
    #3603
    Georgeth1022
    Shaun
    West Hills CA
    Too many to list
    Well, gotta say, huge improvement. Much much brighter. Great mod, thanks op!!
  4. Feb 17, 2021 at 11:43 AM
    #3604
    Nateurboy
    Nateurboy Well-Known Member
    Nathan
    Colorado front range
    2008 DCSB 6 spd
    Hey guys,
    Been wanting to get everything ordered to do the mod, but don’t have a multimeter handy at the moment. Anyone know if an 08 TRD OR is conventional switched or ground switched? Thanks.
  5. Feb 18, 2021 at 5:50 AM
    #3605
    stimey
    stimey Well-Known Member
    nova
    tacoma t|x pro
    Which harness and bulbs did you go with, may I ask? I have essentially the same truck (2013 T|X Pro, minus the SC). Guessing I'll need the same harness?
  6. Feb 18, 2021 at 8:20 AM
    #3606
    Saffa
    Saffa Well-Known Member
    Victoria, British Columbia
    2015 TRD Sport DC 6MT
    You need the harness and Osram 100/90W Superbrights
    Georgeth1022, Norton and FastEddy59 like this.
  7. Feb 18, 2021 at 4:34 PM
    #3607
    stimey
    nova
    tacoma t|x pro
    Headlight services gives the following disclaimer. Apologies if dumb question but I should be okay using this harness with DRL's disabled (turned off)? I have DRLs off 99% of the time anyways.
    ** For the 2005-2015 Toyota Tacoma (without DRLs)use our Universal Power-Switched Premium-Plus harness found below.**
  8. Feb 18, 2021 at 4:41 PM
    #3608
    blur
    blur Well-Known Member
    They are referring to headlight DRL’s, not the amber running lights which is what most trucks are equipped with.
    Norton likes this.
  9. Feb 18, 2021 at 5:10 PM
    #3609
    stimey
    nova
    tacoma t|x pro
    Oh I see. So don't have DRLs then.
    Appreciate the help!
  10. Feb 18, 2021 at 9:40 PM
    #3610
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    As long as you don't have headlight DRLs (where you cannot turn the headlights off) you should be conventionally switched and be good with the conventionally switched harness.
    yotaTom and Nateurboy[QUOTED] like this.
  11. Feb 21, 2021 at 3:31 PM
    #3611
    Nateurboy
    Nathan
    2008 DCSB 6 spd
    Correct. My 2008 is conventionally switched, just ran the test.
    EdgemanVA likes this.
  12. Feb 21, 2021 at 4:22 PM
    #3612
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    And no, not my bottles LOL!
  13. Feb 21, 2021 at 7:46 PM
    #3613
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  14. Feb 22, 2021 at 2:35 PM
    #3614
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Your plant? :drevil:
  15. Feb 24, 2021 at 6:47 AM
    #3615
    ickthus
    ickthus Well-Known Member
    DAVID
    MOBILE,AL
    OC
    2.75BL5100'S/UNDERCOVER
    my 08 standard (non DTR) head lights are hazed again and cracking. I'm looking to replace the units complete. Whats my best option / bang for the buck / way to go for an oldman. Did i read right that i have to take most of the front off to change them out?
  16. Feb 24, 2021 at 6:57 AM
    #3616
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Recommendation is to use OEM as they last longest for glazing over and the reflector is better than any third party. But, most expensive option.
    It's not required to remove the bumper cover to change them out, but that does make HL access easiest. But I've had mine in and out several times without removing the cover. Getting to the mount bolt that is closest to the fender is a PITA, but doable.
    jarebear74 likes this.
  17. Feb 24, 2021 at 8:32 AM
    #3617
    Nateurboy
    Nathan
    2008 DCSB 6 spd
    I just bit the bullet and spent $489 on oem headlights. There’s plenty of tutorials on the YouTube to help with the process.
    jarebear74 and ARoman83 like this.
  18. Feb 24, 2021 at 9:10 AM
    #3618
    ickthus
    DAVID
    MOBILE,AL
    OC
    oh i know about you tube, blogs, forums and haynes manuals. I'm a dumbass and need all of them to be smart.
    I'm doing my leg work now. thanks for posting.
    Nateurboy likes this.
  19. Feb 26, 2021 at 4:11 AM
    #3619
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Forgot the :boink:
  20. Feb 26, 2021 at 7:36 AM
    #3620
    TegoTaco
    Ontario, Canada
    lol...the what?
    FastEddy59[QUOTED] likes this.
