The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Mar 18, 2021 at 12:23 AM
    #3641
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    work truck spec has these funky fog lights. but the aftermarket pod lights are on the radar to. but i have to wait. my tacoma is on the verge of finally getting the engine and transmission put on its new frame. tundra is "done" for right now till thats all squared up
  2. Mar 18, 2021 at 5:45 AM
    #3642
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yeah the first gen Tundra fog light space is big. An adapter to pod style there would be awesome but probably would need to be custom built. Aftermarket bumper might be better value but changes the look. I hope to one day be facing this challenge.
  3. Mar 18, 2021 at 1:35 PM
    #3643
    Saffa
    Saffa Well-Known Member
    Victoria, British Columbia
    2015 TRD Sport DC 6MT
    Which type of bulb does it take?
    If it's halogen you could perhaps fit a second harness and use another 100/90W bulb?
  4. Mar 18, 2021 at 5:36 PM
    #3644
    Empty_Lord
    Dan
    9006 bulb. i have 9012 bulbs in it now. more than bright enough. just not happy with the fact they wont adjust down.
  5. Mar 19, 2021 at 8:16 AM
    #3645
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Dang, there is sure a lot of reading in this thread, I've read so much I'm about to go cross eyed. Hoping I can make this short & simple. I don't want to rewire, or change to new housings, nor anything. I just want to get a light that will give the best Hi beam lighting I can get without losing from the Lo beam in my stock Taco. I think I read the Phillips +200 were better on Lo, but lost a little on Hi due to blue tint, so maybe the +150's would be better for me, maybe the Osram night breaker Lasers or one of the others. Just want to do the best I can, just by changing the light bulbs. Thanks to all who have searched all this stuff out.
  6. Mar 19, 2021 at 8:39 AM
    #3646
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    anything over stock wattage really need the upgraded harness, even stock is brighter with upgraded harness
    if you do not want to do the harness upgrade IPC (I think it's IPC) is about you only option over stock
    factory wire can not supply enough current to high wattage lamps without over heating
  7. Mar 19, 2021 at 8:44 AM
    #3647
    blur
    blur Well-Known Member
    When I started looking into this I was of the same opinion and only wanted to upgrade the bulbs. I started looking into the harness and am so glad I did. It was very easy to install and the light, both high and low beam, that is produced with the recommended Osram is simply incredible.
  8. Mar 19, 2021 at 9:01 AM
    #3648
    Saffa
    I used Philips +100 for many years and they worked well, but it's no comparison to the Harness + Osrams
    The harness will cost you about $100 but it's a one-time expense
    The Osrams give much more light on low beam and are much cheaper to buy than any of the +100, +150 or +200 bulbs
  9. Mar 19, 2021 at 9:23 AM
    #3649
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    If you’re looking for upgraded light output you’re a fool not to get the harness. You could install it with a head full of mescaline while having a millennial explaining to you the pro’s of renting over owning.
  10. Mar 19, 2021 at 10:05 AM
    #3650
    daveeasa
    David
    PNW
    I got a ground switched harness off Etsy from China for $40. Took about a month. Quality was excellent. I plan to use it to build my own overpriced and sealed version. But H4 connectors aren’t sealed so it’s all pointless.
    I could post a link but don’t want to take away from Headlight Solutions. They (Headlight Solutions) are awesome and should be the first choice. Since my purchase was for a template I wanted to cheap out. I was rather surprised at how nice it was.
  11. Mar 19, 2021 at 10:39 AM
    #3651
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    OK, I guess I've got the message. Ya'll are saying there is absolutely no 60/55 lights that will do anything any better than the OEM lights from Toyota that are in my Taco now. I'm 68 yr. old & not sure I can change the bulbs, & for sure know I can't do the rewiring, mounting relays, & reconnecting stuff. Thanks for the help anyway, I do appreciate it.
  12. Mar 19, 2021 at 10:42 AM
    #3652
    daveeasa
    David
    PNW
    There are better bulbs. Just harder to find I believe.
    Do you have access to a neighbor or relative who can assist? It’s an easy task. And well worth doing. Or can you pay someone to do it?
    My father is mid 70’s and would be in a similar spot. I’d have to do this for him. He would get quite confused without me there.
    Also, make sure you have read the stock wattage bulb section of the first post (scroll way down). Nighthawk +120’s would be my pick if I had a gun to my head and couldn’t upgrade the harness.
  13. Mar 19, 2021 at 11:04 AM
    #3653
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    If you had a copy of the directions you could bring them to a local independent garage or automotive accessory install shop/auto audio install shop and ask them if you could pay them to install the harness. If someone would agree you could buy the harness and bulbs and have them install it. I would think it would take no more than an hour of labor. Not a bad solution to the problem. I am not sure if I still have a copy of the instructions but I am sure someone in this thread will. I am sure you could get a pdf of the instructions sent to you then just print it out and you are good to explore to see if there is a shop who would do the work for you.
    Edit: Or maybe there is even a TW member who lives close to you....
  14. Mar 19, 2021 at 11:43 AM
    #3654
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    That's actually not what anyone here has said in response to your question, but ok.
    Philips and Osram have several stock/standard wattage H4/9003 bulbs that offer improved performance.
    The best upgrade (assuming your headlamp reflectors and lenses are still in very good shape, otherwise start with new ones) is the Osram Rallye H4 100/90w bulb. It, however, **Requires** a relay harness because it would be at risk of damaging your OEM wiring harness and headlight switch from the amount of power they draw.
    The osram rallye 100/90 H4 results in the largest visual improvement, because the lowbeam is putting out significantly more light than the standard 60w h4 lowbeam filament. So it doesnt just improve maximum low beam distance projection, it also puts more light flux evenly throughout the entire beam pattern.
    The various performance "+Focus" rated H4/9003 bulbs do not necessarily produce *more* light, they produce a higher intensity beam, which translates into increased distance projection over a standard bulb. The tradeoff these manufacturers have to make, because their bulbs still have to fall in the legal standards for street legal bulbs, is that in order to reduce some of the higher intensity from the lowbeam, they have to shade the highbeam (or, for some bulbs they market as being "whiter" they shade the entire bulb) portion of the bulb with blue. This cuts down the performance of the highbeam.
    The osram rallye h4 is not marketed as a street legal/compliant bulb, therefore they don't shade the highbeam filament. Its the best option, by far.
    The relay harness installation is very simple, and the headlightharness guy has very clear instructions. If you can use simple hand tools, you can install this harness.
    Even if you do not use high wattage bulbs, the relay harness will result in measurably improved headlight performance with standard wattage bulbs. Halogen bulbs are voltage driven - very small increases in the voltage they are fed result in very big improvements in output. The tradeoff is lifespan. High wattage bulbs and high performance bulbs generally have shorter lifespans than stock wattage and long-life bulbs.
    There is one bulb that Crash has tested that offers improved Low Beam performance without the manufacturer stating it has a short rated lifespan. Philips Racing Vision +200 H4 is rated at an atypical 400 hrs of burn time, vs 250hours for most of the other Philips/Osram/Tungsram performance focus rated bulbs.
    If you want no bluer/whiter light, you have a few options: 1- the Osram rallye 100/90w H4 (and relay harness) or Philips Xtremevision +100 H4/9003.
    If you want maximum lifespan and improved Low Beam performance, and are willing to accept some slight increase in color temperature for both lowbeam and highbeam, Philips Racing Vision +200 H4/9003.
    Philips Xtremevision +130 or +150 will have similar low beam performance, and slightly lower color temperature, but are both rated at 250hrs lifespan.
  15. Mar 19, 2021 at 12:04 PM
    #3655
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I'm 65 and I had the Ultimate Headlight Upgrade in my 2014 Tacoma. The light output is amazing and the installation is easy. But if you don't feel comfortable running some wiring, I can understand. You did ask for better bulbs though and that will require a bulb change. Unfortunately, Toyota has made a simple exercise like changing headlight bulbs a bit of a contortionist special. So you might need some help just to change the bulbs.
    What stock wattage bulbs should you use? I've done a quick copy and paste from the Ultimate Headlight Upgrade post to make that easy for you:
    Stock wattage performance bulbs
    Stock wattage high performance bulbs do not actually put out more light, instead they use smaller high precision filaments to make the light more focused and intense for the headlight to use more efficiently and project a brighter hotspot further. You can see an short article by Philips explaining how these bulbs work here.
    These are currently the highest performing stock wattage bulbs on the market:
    Which bulb is best? Depends on your needs. The +150 bulbs are going to provide excellent low beam performance, but coat the high beam reducing performance. The Philips are rated at 200hrs. The GE +120s have a blue coating on the tip but leave both the low and high beam uncoated giving superior high beam performance with a slightly lower low beam performance over the other bulbs. You can compare lux performance over stock in the above charts.
    Philips vs Volsa:
    While Osram and Philips are constantly compared and about equal when running the latest version of each bulb, I hadn't seen any comparison with Volsa +100, which was marketed as a replacement to the outgoing 70w Osrams. So I took the opportunity to compare them on a 1st Gen later in the thread here.
    Note that Sylvania Silverstars (different than Osram Silverstars) are not on the list, as a fully coated stock wattage bulb is lower performing. The Silverstar XZE have an output of 1500/910 lumens and a life of 150hrs.
    Here is a breakdown from Candlepower.
  16. Mar 20, 2021 at 4:17 AM
    #3656
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Not sure what age has to do with any of this other than making good headlights even more important. (Says the damned-near 68 year old.)
  17. Mar 20, 2021 at 4:28 AM
    #3657
    Too Stroked
    Tom
    I'm going to go way out on a limb and suggest two things that may make it more important to a 68 year old. First, maybe his night vision isn't as good as it used to be, so he needs better lighting. Second, maybe he's not quite as able to tolerate the contortions required to swap bulbs or install an HD harness on a 2nd Gen Tacoma.
    ARoman83 likes this.
  18. Mar 20, 2021 at 7:08 AM
    #3658
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Very understandable, when I was 50 I never imagined what it was going to be like at 68. Shoot, now ya'll got me wondering if I'll be able to even change the bulbs, let alone the harness.
  19. Mar 20, 2021 at 9:20 AM
    #3659
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Man, I thought you were much younger!
  20. Mar 20, 2021 at 9:28 AM
    #3660
    Too Stroked
    Tom
    If it makes ay difference, I feel (and act) 20 years younger.
    TegoTaco[QUOTED] likes this.
