The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Feb 19, 2022 at 1:00 AM
    #4281
    Chocolates
    Chocolates Well-Known Member
    Seattle or Bellingham
    05 DCLB
    Unicorns and glitter
    Anyone purchased the Osram bulbs recently? Seem to be sold out most places online.
  2. Feb 19, 2022 at 7:40 AM
    #4282
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Headlight Services has them in stock domestically last I heard.
    Chocolates[QUOTED] likes this.
  3. Feb 19, 2022 at 8:46 AM
    #4283
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I got some osrams from my eBay dude. Who I get Toshibas from.
  4. Feb 21, 2022 at 9:21 AM
    #4284
    dirtfilter
    dirtfilter New Member
    1998 1st Gen SR5 V6 @ 360K, Stock AF
    Signed up today just to say I found this thread from a general internet search for my paltry dimming headlight situation on my 1st gen tacoma. I invested/installed in the Headlight Services harness and a fresh set of "Hella 9003 2.0TB, 60/55W High Performance Bulbs" (very easy job as stated). Absolutely fantastic improvement! Wish I had looked into this years and years ago! Thanks to the OP for all of his thorough research and reporting. Incredibly helpful information!
    Also, I ordered a set of the Osrams from e-bay and will looking forward to seeing the difference with those halogens as well.
  5. Feb 21, 2022 at 3:08 PM
    #4285
    Silva1181
    Silva1181 Well-Known Member
    Marc
    Houston
    2013 Tacoma Double Cab, 2.7L, Silver Streak Mica
    Well it took me 3 days to read through all 215 pages. Definitely lots of great information Crashburn80. Thank you!
    I was initially going for a projector retrofit and/or the XBs but have steered away from these options. I currently run the Philips GTracing +200 and they are good bulbs for my needs.
    My truck is a 2013 and based on what I read throughout this thread from others with the same year, I plan to purchase the conventional harness and use it with the the +200 Philips bulbs.
    I will consider higher wattage bulbs in the future but for now, I will use these. I know this won't be a dramatic improvement since I am not using higher wattage bulbs, but based on what I read it will still be an improvement. My OEM headlights are still in good condition but I eventually plan to purchase the OEM sport headlights. My truck is stock height/suspension and the current headlights are set at a stock alignment but I noticed the height of the passenger side is slightly above the driver side and I am guessing this is standard in order to see road signs. Any reason I shouldn't aim lower to be aligned vertically with the passenger side to have a more even cutoff ?
    thanks,
    crashnburn80[OP] likes this.
  6. Feb 28, 2022 at 8:40 AM
    #4286
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    A big shoutout to @HLS for his great customer service! Helped and guided me sorting out the harness issue I was having. Thanks again man!!!
    Finally got around to installing the OSRAM Super Bright Premium High Wattage bulbs. Super impressed with them, big upgrade to the old OSRAM BILUX H4 RALLYEYE bulbs. Has a nice clean cut off, amazing distance and amazing spread. Paired with the DD SS3 MAX fogs, talk about a perfect set up! No need for a retrofit. :)
    outdoorgb, Toy_Runner and Too Stroked like this.
  7. Feb 28, 2022 at 11:23 PM
    #4287
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The cut off plane should be the same for both lights.
  8. Mar 1, 2022 at 2:06 AM
    #4288
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    http://www.danielsternlighting.com/tech/aim/aim.html
    Best article on how to properly aim your headlamps, fog lamps, driving lights, etc. Believw it or not there is no standard that requires correct aim from a vehicles lamps before it leaves the factory or the dealers lot. Most peoples headlamps are horribly misaimed from the factory and never touched.
  9. Mar 1, 2022 at 5:10 AM
    #4289
    Silva1181
    Marc
    Houston
    Thanks for the responses. I will work on adjusting the passenger side.
  10. Mar 1, 2022 at 6:17 AM
    #4290
    TegoTaco
    Ontario, Canada
    It’s pretty easy to adjust, just make sure you’re on level ground, and the bulbs are seated right. Took me a couple of tries to get it right. :)
  11. Mar 1, 2022 at 6:14 PM
    #4291
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Make sure to use the vertical adjuster and not the horizontal one.
    [​IMG][​IMG]
    Norton and dborrer like this.
  12. Mar 1, 2022 at 7:04 PM
    #4292
    Silva1181
    Marc
    Houston
    Thanks Crashnburn. I used these instructions from your headlight upgrade thread and only adjusted the vertical for passenger side which is now aligned with driver side.
  13. Mar 1, 2022 at 7:23 PM
    #4293
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    What’s the reason for not touching the horizontal adjustments?
  14. Mar 1, 2022 at 7:36 PM
    #4294
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Very rarely do the lights need horizontal adjustment. And if you horizontally adjust both so they no longer point straight ahead, it can be a very frustrating process to recenter the beam.
    Norton and Steelhead Bum[QUOTED] like this.
  15. Mar 1, 2022 at 8:13 PM
    #4295
    Steelhead Bum
    Mitchell
    Eastern WA
    Thanks crash.
  16. Mar 3, 2022 at 7:25 AM
    #4296
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Norton, lococacho and Toy_Runner like this.
  17. Mar 3, 2022 at 9:54 PM
    #4297
    DaleRS
    DaleRS Well-Known Member
    Dale
    Cleveland, Ohio
    2015 Black DCSB SR5 w/ Snugtop
    Just swapped the OEM housings back in! Complete difference! They're actually BETTER than the aftermarket Spec D projectors I had! So glad I happened upon this and went back to the stock housings. Ordered the harness kit!
    Too Stroked and crashnburn80[OP] like this.
  18. Mar 3, 2022 at 9:56 PM
    #4298
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    ^This is the way.
    Norton, 08BajaBoy and DaleRS[QUOTED] like this.
  19. Mar 3, 2022 at 9:57 PM
    #4299
    DaleRS
    Dale
    Cleveland, Ohio
    This is the way.
    08BajaBoy likes this.
  20. Mar 4, 2022 at 8:40 AM
    #4300
    KetoClutch
    KetoClutch Well-Known Member
    Whit
    Borger, TX
    2012 DCLB
    Bilstein 6112/5100, OME heavy springs, SPC UCAs, Sumimoto bumpstops, Ultimate headlight upgrade, Grille, Raptor lights, Sound deadening, foam insulation, Speakers, Sub, Head unit, Power rear sliding window, Locked center console & bed cubbies, Shark fin delete, Hood struts, Bug visor, Window visors
    Ordered the wiring harness and OSRAM bulbs from Headlight Services and they showed up relatively quickly (within a week or so). Thanks Mike! Just waiting for the weather to cooperate and a day off to do the install.
