The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Nov 30, 2023 at 1:15 PM
    #5041
    kyruuuu
    kyruuuu Active Member
    No turn signals light up, no DRL. Thanks!
    Excellent thank you.
    Tacoma13_NC[QUOTED] likes this.
  2. Nov 30, 2023 at 3:11 PM
    #5042
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I have new housings also. But your light housings are like mine 05-11 are the same you should have no issues whatsoever.
    Me on the other hand have DRL in the turn signals being an 09. And I think the 10's had them too. But drl's have nothing to do with the harness or lights .
  3. Nov 30, 2023 at 5:07 PM
    #5043
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Right, the signal DRLs have nothing to do with the headlights or harness. The Canadian style DRLs where the headlights are always on as a DRL and you cannot turn the headlights off is what causes an issue with this mod. If you can turn your headlights off while driving, you do not have headlight DRLs and it is a non-issue.
  4. Nov 30, 2023 at 5:10 PM
    #5044
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    My Canadian 09 used the indicators before i swapped to a us non drl module
    Tiedie likes this.
  5. Nov 30, 2023 at 6:34 PM
    #5045
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Might have been just 1st Gen that used headlights as DRLs in Canada. Unsure. But Canada mandates all vehicles have DRLs, so if they were not equipped as stock they got headlight DRLs instead.
  6. Nov 30, 2023 at 6:41 PM
    #5046
    Darthyota
    Alberta
    Blown BSP X-Runner
    My 90 pickup was like that. Yes thats why i swapped to a us non drl module so that i could sit in the truck without turning it off and be able to kill all the lights as with the drl module even if you reapplied the parking brake (my 09 was a mt) the drls wouldn't go off
  7. Dec 1, 2023 at 3:12 AM
    #5047
    Tiedie
    David
    WFOY
    Tell me more about the module and how to get rid of the indicator DRL please.
  8. Dec 1, 2023 at 10:19 AM
    #5048
    Darthyota
    Alberta
    Blown BSP X-Runner
    Its just a module under the dash by the fuse panel. You just need to swap the drl one for the non drl one. I cant remember part number as it was 14 years ago now and i no longer have the truck.
  9. Dec 1, 2023 at 11:41 AM
    #5049
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  10. Dec 1, 2023 at 12:17 PM
    #5050
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    The jumper block is part #82671-30360. It's kind of a bitch to get the module out to remove the dtrl bits and put in the jumper. I did it for that smart tap relay, which I really like.
    BenMara likes this.
  11. Dec 1, 2023 at 3:18 PM
    #5051
    Tiedie
    David
    WFOY
    Thanks for the info gonna have to look into this.
  12. Dec 5, 2023 at 9:59 PM
    #5052
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Almost 4 years in, one of my Osram 85/80 bulbs has given up the ghost. Now onto the aforementioned Phillips bulbs.
    BenMara and crashnburn80[OP] like this.
  13. Dec 5, 2023 at 10:02 PM
    #5053
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Coming from the 85/80s I think you’re more likely to be happier with the Osram 100/90 Superbrights. Nothing will perform to the level of the 85/80w Hypers unfortunately.
  14. Dec 6, 2023 at 3:47 AM
    #5054
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Thought of something interesting last night. All of you folks replacing your worn out / oxidized 2nd gen headlight housings have a great opportunity. Before you bin the old housings, remove and save the headlight bulb retention clips. You know, those things you love to use bad words on when you change headlight bulbs because they tend to fall out and instantly get lost? Not many people know that they're apparently made of Unobtanioum and cost a fortune - if you can even find them.
    So, save your clips and keep them in case one of your fellow TW members happens to need one. I did.
  15. Dec 6, 2023 at 4:14 AM
    #5055
    Tiedie
    David
    WFOY
    Yes but losing them you might need yourself :D.
    This is a great idea.
  16. Dec 6, 2023 at 9:29 AM
    #5056
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    That's a great idea. I think I'm going to try to solder a little piece of metal to bridge the opening where the clip sits into so it wont't fall out again.
    Toy_Runner and Tiedie like this.
  17. Dec 6, 2023 at 2:03 PM
    #5057
    Too Stroked
    Tom
    Hint: A drop of RTV is much easier. Ask me how I know that.
    Tiedie and Tacoma13_NC[QUOTED] like this.
  18. Dec 6, 2023 at 4:28 PM
    #5058
    Tacoma13_NC
    Good to know :thumbsup:
  19. Dec 12, 2023 at 9:48 AM
    #5059
    kyruuuu
    Where are you guys buying your 100/90w OSRAM's? Powerbulbs? Is there something more convenient in the USA?
    Just ordered the headlightservices harness.
  20. Dec 12, 2023 at 10:30 AM
    #5060
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    The price is up, but they're still available from Bulb America.
    crashnburn80[OP] likes this.
