The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Jan 4, 2024 at 6:19 PM
    #5121
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    Ohhh I see. Well glad to see it worked out!
  2. Jan 5, 2024 at 12:06 PM
    #5122
    Shamal
    Shamal Active Member
    BC
    SR5 4X4
    I installed my new headlights and the wiring kit. Bought the lights online from Seattle Toyota dealership, on sale in the Black Friday period, considerably cheaper than anything I could find in BC
    The wiring harness from Headlight Services is excellent quality, if anyone wants a review. It seems expensive in $C and we thought about building a set. It goes in easily, excellent instructions, high quality parts.
    New lights are excellent,,,
    I waited too long ,, just the enormous price of new housings in Canada held me back.
  3. Jan 6, 2024 at 12:35 AM
    #5123
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    If you're dead set on keeping the spider housings... TRS ( the retrofit source) has/ had at one point much better projectors that replaced the crappy ones that came in those housings as a kit. Not sure how much work is involved and if it keeps the h1 bulb or goes to different bulb type, but just an option.
  4. Jan 6, 2024 at 6:00 AM
    #5124
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I’ve lived the spider headlight projector life in my old truck - 96 Dodge. Even changed over to Morimoto projectors from TRS. My recommendation is don’t do it. Scrap the headlights and get stocks. The spider lights had the bowl molded into the light and changing to new projectors involved dremeling and epoxying the new lights in. The morimoto lights suck - great illumination but such a sharp cutoff that stop signs aren’t illuminated. Go down a dip in the road and the cutoff comes right in front of the truck. Absolute garbage.
    crashnburn80[OP] and Too Stroked like this.
  5. Jan 6, 2024 at 9:07 AM
    #5125
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, no uplight, typical of most all aftermarket retro projectors. Not a legitimate low beam and downgrade from stock.
  6. Jan 6, 2024 at 9:09 AM
    #5126
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    So the proper cutoff still leaks “some” light upwards?
  7. Jan 6, 2024 at 9:20 AM
    #5127
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    All OEM lights have uplight, which is reduced intensity light above the cut off. This allows you to see beyond your low beam without blinding other drivers and illuminate things light street signs. Without uplight you are completely blind beyond your low beam cut off in areas without ambient light due to the high contrast at the cut off line where anything beyond it appears as absolute darkness, which as mentioned above in areas with dips or short hills you may find yourself unable to see very far at all. It is unsafe and not compliant. It is much cheaper though to make projectors without uplight, it’s less complicated and no need for optical engineers.
    vssman and Too Stroked like this.
  8. Jan 7, 2024 at 4:46 PM
    #5128
    Devilfan
    Devilfan Well-Known Member
    Are these wiring harnesses still available from Headlight Services?
  9. Jan 7, 2024 at 4:50 PM
    #5129
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Yes they are. Follow the links in first post.
  10. Jan 7, 2024 at 5:12 PM
    #5130
    Devilfan
    Thank you. Just placed an order for one
    crashnburn80[OP] likes this.
  11. Jan 7, 2024 at 5:56 PM
    #5131
    TacoLolz
    TacoLolz Well-Known Member
    Portland, OR
    2010 TRD Sport
    I'm just noticing the OEM 2010 smoked headlights are $227 each right now. Is that a pretty typical price or they actually on sale?
  12. Jan 7, 2024 at 6:03 PM
    #5132
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    were? just the housing of full assembly with new dust caps?
  13. Jan 7, 2024 at 6:08 PM
    #5133
    TacoLolz
    Portland, OR
    2010 TRD Sport
  14. Jan 7, 2024 at 6:43 PM
    #5134
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    well that's auspicious, I just changed my lamps and discovered that the latch is broken and missing on my drivers side
    I'd be tempted to just get housings but they don't have the left smoked listed
  15. Jan 7, 2024 at 9:12 PM
    #5135
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  16. Jan 9, 2024 at 11:49 AM
    #5136
    Chapman
    Chapman Well-Known Member
    Bay Area, CA
    2013 SW DCLB TRD Sport 4x4
    Bought 4 of the 100/90W from BulbAmerica, along with the Headlight Services Harness. Installation was simple as everyone mentioned. Wish I had done this sooner as I was running the standard 60W in my pro headlamps.
    Total spend was $33 for the 4 bulbs and $150 for the harness.
    Much thanks to this thread!
    Shamal, crashnburn80[OP] and Tiedie like this.
  17. Jan 9, 2024 at 6:54 PM
    #5137
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    Just got everything installed. Wow what a difference, I can’t believe I was driving like that before lol the high beams are insane! Anyways, I adjusted my lights to the best of my ability following the article @crashnburn80 posted, after driving the cutoff seems pretty low. The center of my lights are roughly 44” from the ground and that’s what I went off of. I set the driver side at 40” and passenger at 41” while 25’ from a wall, flat ground, half a tank of gas, etc. I took a ride on a dark road with no street lights and could see everything my lights shined on extremely well, but I feel as if I couldn’t see far out from me. I don’t want to be blinding any other drivers. Does it sound like I did anything wrong?
  18. Jan 9, 2024 at 7:08 PM
    #5138
    Sharpish
    Brian
    That sounds like they are adjusted too far down. Maybe 2” at 25’ would be better.
  19. Jan 9, 2024 at 7:12 PM
    #5139
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    I suppose I could have adjusted too far down. It just seemed right on my tape line on the wall.
  20. Jan 9, 2024 at 7:19 PM
    #5140
    Sharpish
    Brian
    4” low at 25’ turns into 24” low at 50 yards
