The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Jan 9, 2024 at 8:02 PM
    #5141
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    As others mentioned that aim is too low. 4" drop at 25' is a fog light aim. Headlights should be aimed 2-3" drop at 25'. Using the center of the headlights as the marking point will also result in an aim that is too low, combined with too much drop will be way too low of an aim. I'd suggest pulling the truck right up to the wall and marking your cut off line on the wall, it will be higher than the center point, the bottom of low beam is typically at the center point on the assembly in an 9003/H4 due to the low beam cut off shield on the bulb. Using the wall for the cut off line at near zero distance will be most accurate. From there, measure down 2-3" drop, and back the truck up 25' and adjust accordingly. No need for additional dip on the driver side, left and right should have the same cut off plane. That should give you much better aim than where you are at with significantly improved illumination distance.
    TRDSport10 and llibrm like this.
  2. Jan 9, 2024 at 9:13 PM
    #5142
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    Hmm I must’ve misunderstood the article you linked lol so would I still follow the same steps you listed even though I’m adjusted far down? Or should I try and redo them to where they were at, and do what you said from there?
  3. Jan 9, 2024 at 11:37 PM
    #5143
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If your bumper is near zero distance from the wall, the aim should have minimal/negligible effect on the cut off height at that close of distance to the wall, so you could start with where you are currently at and fine tune accordingly once you’ve got them close to dialed in.
  4. Jan 10, 2024 at 2:44 AM
    #5144
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    @crashnburn80 I did this mod on my 05 years back, couple months ago headlights stopped working so I changed out the relays and now one the passenger side headlight stays on no matter what, ignition on or off.
    I checked all fuses/relays/grounds/connections. Only possible thing I think it could be is the headlight switch by the steering wheel.. contacts must be stuck. For now I've just been keeping the relays unplugged and plugging them in if I need headlights lol.
    That switch looks like a royal PITA to change, any ideas on what it could be?
  5. Jan 10, 2024 at 5:49 AM
    #5145
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    If your '05 is power switched (my '05 RC PreRunner is) then note that Mike uses dual 87 relays for that harness. They fit a traditional socket so it is possible to replace with a regular 5 pin relay with 87 and 87a by mistake which would lead to the symptoms you describe. The trigger in his harness only comes from one side so the chances of anything wrong with the trigger itself seem minimal as you would experience problems with both headlights if so.
    I'd assume you may not have known this, it wasn't until I had hands on one and checked out the relays that I noticed it. It's a convenient way to avoid two large wires meeting on a single relay terminal to provide output to the headlight.
    An alternative is 4 relays, one per filament per side, which is how I did my '02 Tundra since I ordered a ground switched but my truck was actually power switched (given that mine is a DRL model and I was too lazy to test it). So I swapped to 4 micro relays in a GEP and also took triggers independently from each side after cutting off the OEM H4's and changing them to sealed OEM connectors.
    TLDR: Get new relays from HS and make sure to tell him which harness you have.
  6. Jan 10, 2024 at 5:50 AM
    #5146
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    Made a quick adjustment this morning. Much better. I appreciate the quick responses and help!!
  7. Jan 11, 2024 at 5:24 PM
    #5147
    timbobzimbob
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    Dude... THANK YOU SO MUCH
    This is 100% the problem... god I love this place :D
  8. Jan 13, 2024 at 9:56 AM
    #5148
    dannyzim
    dannyzim Active Member
    SoCal
    08 White DCSB PreRunner
    17x8.5 Method NVs wrapped with 265/70r17 KO2s 2020 TRD OR suspension take-offs Ultimate headlight upgrade Sylvania - Fog Vision lights Low mount license plate bracket Talons Garage catalytic converter shield Rough Country bed mat SaBellCo Tailgate Lock Super white/black mesh grill swap Short Antenna WeatherTech window deflectors & floor mats Coverking Neosupreme Seat Covers AudioBaxics Aux Audio Input Adapter
    Just popping in to say HOLY SH*T this is a great upgrade. I recently installed the harness and the Osram bulbs recommended, as well as getting the early 2nd gen smoked headlight's and it made a huge difference. This was exactly what I was looking for. I'm glad I returned those shitty spyder headlights I received for Christmas. They look cosmetically great but I found out they were horrible in performance after coming across this thread and researching all the aftermarket headlights. Thank you man!
    wdb, Norton, dborrer and 7 others like this.
  9. Jan 13, 2024 at 6:35 PM
    #5149
    whiteknight4x4
    whiteknight4x4 Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    Which part # did you go with for your smoked lights and what did you pay?
    TacoLolz likes this.
  10. Jan 14, 2024 at 9:13 AM
    #5150
    dannyzim
    SoCal
    According to Toyota, the part numbers listed in this thread are right but are previous versions. Here are the current part numbers: Headlight (Right) Part Number: 81110-04173 & Headlight (Left) Part Number: 81150-04173. I paid $554.05 local pickup at the stealership.
  11. Jan 14, 2024 at 12:49 PM
    #5151
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Careful. Those are actually the pre-TSB (old melting DRL) part numbers. Toyota replaced those with the new fixed part numbers to solve the melting DRL issue. Then inventory ran out and now they list the old (melting DRL) part numbers as superseding the newer fixed part numbers. So they are selling the flawed old parts as the newest version, when the “previous version” was actually the newest. Part numbers are listed in the TSB linked in the original post.
    TacoLolz, BenMara, Norton and 2 others like this.
  12. Jan 14, 2024 at 5:44 PM
    #5152
    dannyzim
    SoCal
    Oh shoot I see. Damn, thanks for clarifying. They make it so confusing. I was a bit confused when buying them locally. When I searched the part numbers you provided in your thread on Toyotas online store, the only headlights that came up were the part numbers I mentioned. In their description, it listed Right: 81110-04210 & Left: 81150-04210 as "Previous versions". I assumed these had to be it. Welp, hopefully they still live up since I don't have DRL.
  13. Jan 15, 2024 at 1:18 PM
    #5153
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    This is a great upgrade. I just did it. I had purchased some LED lights from Amazon when one of my H4 bulbs had gone out a few weeks ago-
    OXILAM H4/9003/HB2 LED Bulbs, 18000 Lumens with LED Chips, Halogen Replacement for tacoma/tuntra/cvr/civic/fit, Pack of 2
    They worked but I noticed light going above the cutoff (a term I learned here when searching for problem).
    This upgrade produces what seems to be a similar amount of light as the LED bulbs, and vastly improves the illumination over stock. It also keeps all the light were it is supposed to be using the same technology that the headlight housing was designed for.
    Not a difficult install, took me about an hour to get everything routed and didn't remove the battery. I mounted my relays in the sheet metal and looks pretty clean.
    Most importantly, I don't appear to be having any effect on oncoming drivers.
    BatteredTaco likes this.
  14. Jan 15, 2024 at 5:06 PM
    #5154
    Devilfan
    Devilfan Well-Known Member
    Thanks for writing all this up. I did the harness upgrade with the new bulbs and it is a massive difference. Restoring the headlight covers helped a lot, too.
    crashnburn80[OP] likes this.
  15. Jan 16, 2024 at 9:36 PM
    #5155
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    I bought the same part numbers as you because as mentioned, the TSB units were not available. I installed the below DRLs to avoid the melting issue.
    https://www.vleds.com/shop-application/daytime-running-lights/3157ck/v6-triton-kit-a-3157ck.html
    18 months later and no problems.
  16. Jan 17, 2024 at 3:57 PM
    #5156
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    @crashnburn80, so I did the harness and bulb mod a few years back and had decent results( really miss the older osrams- originals you recommended that aren't available any longer) but never got around to resurfacing/ polishing or replacing the headlight housings and now that one will require replacement thanks to an unfortunate incident due to the ice and snow here in middle TN this past week I was wondering if it would be best to replace with the oem smoked trd housings that came on my 09 tacoma or go with the alpharex tacoma PRO series halogen projectors and put a good led bulb in it in your opinion? In the trucks defense I had an HID system in the original housing prior to me finding this thread and throwing all that out and putting the overdriven osrams in there with the harness and probably never quite got the aim quite right. Always seemed dim though and fairly low until I hit the brights and then they were BRIGHT!!! any thoughts or opinions are greatly appreciated. Thanks
  17. Jan 17, 2024 at 4:20 PM
    #5157
    daveeasa
    David
    PNW
    You guys think there might be an alternate universe where antimatter crash raves about Alpharex and led bulbs in halogen projectors? And maybe even makes fun of SAE standards and CRI measurements?
  18. Jan 17, 2024 at 4:39 PM
    #5158
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Bazaro Crash maybe
  19. Jan 18, 2024 at 6:20 PM
    #5159
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Bummer on the incident taking out your headlights. OEM is the way to go by far, no comparison whatsoever. AlphaRex is just cheap white-labled Chinese product sold at dumb markups to American consumers that don't know better on the promise that they are something special when they are anything but. AlphaRex doesn't make anything at all and is not a manufacture. They are an importer. The products they sell are consistently awful and don't even have legitimate headlight patterns, they are typically short range flood lights with no hot spot, or hot spots so far down in the beam pattern the headlight isn't useable and again not a legitimate headlight pattern. Putting a PnP LED bulb in their already awful headlights is only going to make it worse. Definitely not advised. Several have gone down this road only to realize they wasted money and have to buy headlights a second time to go with OEM.
    Proper aim is critical. If your headlights are aimed too low, you won't get the down-road projection for good illumination and seeing things with surplus time to react. If your headlights were not in great condition to begin with, then a fresh set of OEM units should make it noticeably better.
    super g[QUOTED] likes this.
  20. Jan 19, 2024 at 2:15 PM
    #5160
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I've had mine for so long now o forgot how good the headlights are. I bought a new vehicle for work and the headlights SUCK. I need to find some kickass h11 bulbs now
