The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Nov 13, 2016 at 11:56 AM
    #501
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    huh that's weird, same thing happened to my credit card a few days after i bought from them too, i do use it online but only with paypal, this was the first time i had entered it manually in months... fortunately I caught it right away ($400 bill to some weird online website) was a pain in the ass to sort out tho... this was like a month ago
  2. Nov 13, 2016 at 12:04 PM
    #502
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    DId you contact the vendor to let them know? it could be almost anything, a trojan/virus on the person's PC inside the company that processes the charges, OR a hacked server, or whatever.
  3. Nov 13, 2016 at 12:49 PM
    #503
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I had the same thoughts as LeftCoastNerd. Contact the vendors and let them know.
    I highly doubt either company is being malicious. I've purchased plenty from Rallylights (susquehanna motorsports) in the past without issue and worked with them in developing the H11 harness, standup guys. It could even be the the 3rd party credit card processing company has been hacked, completely independent of the company.
    But bring attention to the issue is a key line of defense. If two independent people contact them and tell them the same thing, they will take it seriously.
    timbobzimbob[QUOTED] likes this.
  4. Nov 14, 2016 at 10:29 AM
    #504
    tazmoe
    tazmoe Member
  5. Nov 29, 2016 at 10:45 AM
    #505
    JHsieh_3
    JHsieh_3 Well-Known Member
    Jeff
    City of Angels
    2018 Tacoma TRD Sport
    I just want to make sure I order the right things. I'm planning on ordering the Osram 100/90W, but do I need to also order the relay harness? Can I not just order the bulbs and plug & play? Thanks!
  6. Nov 29, 2016 at 7:35 PM
    #506
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    YES, you NEED the upgraded harness w/relays to run those bulbs.
    NO, you should NOT just "plug & play" on the stock harness, unless you want to roast marshmallows over the vehicle fire likely to ensue.
    crashnburn80[OP] likes this.
  7. Nov 29, 2016 at 8:50 PM
    #507
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    As @Norton mentioned, you will want the harness for the 100w bulbs. If you wanted to go with just bulbs only, look at the Volsa bulbs I listed in the original post.
    Even if you were to run the original 85w bulbs without the harness, output will be restricted, noticeably impacting the performance of the upgrade. The standalone harness is just as much a part of the upgrade as the bulbs.
    Norton likes this.
  8. Nov 30, 2016 at 8:39 AM
    #508
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Has anyone installed the Volsa 65/70w bulbs wit factory wiring? is there a noticeable improvement? any heat issues?
    THANKS For The Wealth Of Knowledge Crash!
  9. Nov 30, 2016 at 9:14 AM
    #509
    jet123
    jet123 Well-Known Member
    Ft Collins
    2013 DCLB
    Not the same bulb you asked about, but I am using the Vosla 60/55w +100 H4 (from Candlepower) with an OEM harness (for now) and feel it was worth it with my 2013. No heat issues either.
    I searched Google as well as Candelpower.com and didn't see the exact bulb you referenced, so maybe you are referring to the Vosla 60/55w +100 H4?
  10. Nov 30, 2016 at 9:23 AM
    #510
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    You are correct. I am no good typing on touchscreens! :) Thanks for the feedback. I think I will try them out.
  11. Nov 30, 2016 at 10:23 AM
    #511
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Do the higher wattage bulbs cause any melting of the harness or headlight housing?
  12. Nov 30, 2016 at 10:27 AM
    #512
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I have a projector retrofit on my truck, but I think I need to apply a lot of the lessons from this thread to my dad's Dodge Ram. The headlights on his truck are useless!
  13. Nov 30, 2016 at 11:33 AM
    #513
    jet123
    Ft Collins
    2013 DCLB
    Can... go to the 1st page of this thread for some info
    Norton likes this.
  14. Nov 30, 2016 at 1:06 PM
    #514
    wedgemoose
    wedgemoose Well-Known Member
    Wedge
    Worcester,MA
    2014 TRD Sport
    Going to put mine in this Weekend Crash. I've been holding out because my life on the original upgraded bulbs has been perfect. I remember I burnt one out rather quickly when I first did your Mod(more a fluke than life span problem). But the second set is still going strong. But I can't hold out any longer. Time to get the 100 Watters in there. My reasoning is more night time driving due to winter. But I was looking for any excuse I could find to be truthful.
    Norton and spiralout462 like this.
  15. Nov 30, 2016 at 2:59 PM
    #515
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    This is the route I decided to go. Retaining factory wiring. A "stage 1" upgrade if you will. Headlights and fogs. I will have the Pro headlights as well.
    Name Code Qty Each Options
    Osram Rallye Lamp 27481 2 16.50
    Discontined - INTRODUCING
    VOSLA H4 +100
    Philips Xtreme Vision H11 H11_XTV 1 33.00
    XTV Lamp (2-Pack)
    Subtotal 66.00
    Shipping 4.63
    Tax 0.00
    Total 70.63
  16. Nov 30, 2016 at 3:10 PM
    #516
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I discovered something that I did not like when I ordered the harness for the ultimate fog light upgrade before thanksgiving. When I was ordering it with Ray they still had my credit card number on file from when I ordered this harness over a year ago.
    I think if you have ordered from them in the past you should call them and ask them to delete your private info.
    99TacoDriver likes this.
  17. Nov 30, 2016 at 3:17 PM
    #517
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    Is PayPal an option?
  18. Nov 30, 2016 at 3:43 PM
    #518
    Backt
    Oregon
    I don't think so. It wouldn't stop me from ordering though. Just ask them to delete your info.
  19. Nov 30, 2016 at 10:29 PM
    #519
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    I'm pretty sure holding a credit card number is illegal
    Bravisimo likes this.
  20. Nov 30, 2016 at 10:42 PM
    #520
    Norton
    LOTS of companies do it so, in the absence of an authoritative reference, I doubt there's anything illegal happening.
    We're also wandering far afield from this thread's subject. Recommend we :stayontopic:
