The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Aug 27, 2025 at 6:46 PM
    #5561
    menoarenoniceguy
    menoarenoniceguy Well-Known Member
    SoCal
    2013 Spruce Mica AC
    You don't need a harness unless you're trying to run bulbs that are higher than stock wattage. What is it that you're trying to accomplish, are you currently running the oem headlamp housings and are they in good condition?
    Norton likes this.
  2. Aug 27, 2025 at 7:04 PM
    #5562
    Wpperry83
    Wpperry83 Member
    07 Tacoma
    I’m currently running faded old stock head lamps. I need to purchase a new set and want more light output.
  3. Aug 27, 2025 at 7:27 PM
    #5563
    menoarenoniceguy
    SoCal
    2013 Spruce Mica AC
    There are 2 separate things to address then, the housings themselves and then the bulbs. A lot of this is dependent on what your budget is.
    As far as the housings go, you could try and use a headlight restoration kit like the Cerakote or the 3m kit and see if you're able to bring those stock housings back to life or not. It's difficult to say without seeing how far gone they are, but IMO it's worth a try since worst case scenario you're only out like $20.
    If they're just completely cooked and can't be restored then get out the wallet and buy a new set of OEM housings. Toyota dealerships are running a 15% off sale right now and free shipping for labor day.
    As far as bulbs go, you have a number of options, all are significant upgrades over stock and it's just a matter of what your budget is and how bright you want to go.
    Best budget option are a set of Osram night breaker +220's. These are stock wattage bulbs (60/55), will run you about $30 for a pair and are a very noticeable upgrade over stock. Beware there are MANY variants of Osram bulbs in h4, you want the night breaker 220's (64193NB220-2HB).
    Next option, if you want more output and more importantly significantly better high beam performance are the DSL +250's. These will run you twice as much $ as the night breaker +220's but perform better across the board, especially the high beams. These are the best stock wattage h4 bulbs available on the planet.
    Still want to go brighter and have the budget for it? Then you want to get a set of Osram Super Brights (100/90). While these are also h4 bulbs they are significantly higher wattage than stock which requires you to run a custom harness in order to power them. The harnesses are covered in detail in the OP but are not cheap compared to the previous 2 options.
    Wpperry83[QUOTED] likes this.
  4. Aug 27, 2025 at 7:33 PM
    #5564
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Step 1 should be to replace your faded old stock head lamp (housings?) with new OEM new ones - do not go aftermarket. Whether you go with Pro housings is a purely personal choice.
    Step 2 should be to decide whether you want to simply replace old bulbs with stock wattage, higher output ones; or you want higher wattage, higher output ones.
    If you go with stock wattage, higher output bulbs Step 3 is to install them on stock wiring and enjoy better illumination.
    If you go with higher wattage, higher output bulbs, Step 3 is to install an upgraded wiring harness, followed by the upgraded bulbs. and enjoy much better illumination.
  5. Aug 27, 2025 at 7:54 PM
    #5565
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    First, take a look at the condition of your current lamps. If the lenses are hazed, or starting to haze over, the factory UV hardcoat has failed. Lots of options to clean that up. Wetsanding with 400, 800, 1k grit sandpaper in that order should remove the rest of the hardcoat and get the lens clear enough to assess the reflective coating. If you see signs of flaking or cracked reflector coating, its time for new lamps. If the reflector surface is good, not blotted, burned, flaking or visibly corroded, then re-coat the lenses with a clearcoat. I have used clear gloss outdoor polyurethane on a few vehicles with good success. But there is also "Light Rite" which is a UV hardcoat which should be on par eith the oem clearcoat once allowed to cure, or you could use clear gloss 2k clearcoat, or a ceramic coat for headlight lenses. 2k and ceramic should last a few years depending in your climate/uv exposure levels, poly is the easiest to apply and remove if you mess it up, but should also last at least a few years before it hazes (I've re-coated my sisters scion twice using poly in the past 5 years, she lives on the coast and parks outside year round).
    You *can* go aftermarket. They will not be made as well as OEM, and the beam pattern will likely not be as good. CAPA certified just means they will fit, not that the lamps are equivalent.
    Any halogen bulb will both perform better, and not last as long, when paired with a quality relay harness. The harness shortens the length of the wire run power must travel to reach the bulbs from the battery.
    Wpperry83 likes this.
  6. Aug 28, 2025 at 3:48 AM
    #5566
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Any OEM housing will do just fine. Skip the aftermarket junk.
  7. Aug 28, 2025 at 3:53 AM
    #5567
    Wpperry83
    Wpperry83 Member
    07 Tacoma
    Thanks for the reply’s. These headlights are cooked for sure. They have been sanded and buffed and rebuffed many times throughout their lifespan. I like the idea of the projector headlights but I don’t there’s any worth the money out there. The definitive line they create when on is simply awesome.
    Is there a “pro” headlight housing for the 2nd gen? I have a 2007 so it’s the older style and not the 2.5 I will purchase the brightest bulbs listed above and see what happens! Probably the one’s right below the ones that require a harness.
