The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Mar 24, 2017 at 8:27 AM
    #621
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
    Are you running the harness for the fog/driving lights too? I have retrofits, but my fogs are the Flosser bulbs and harness. (Ultimate Fog Light Upgrade) Nothing on the market right now that has the output, correct beam and price tag than this set up.
    Norton likes this.
  2. Mar 24, 2017 at 2:24 PM
    #622
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Got 4 months of use out of my second set of Osram CP64206 - 85/80W. I really like the output, but might have to switch to a cheaper alternative...
    airwhen likes this.
  3. Mar 24, 2017 at 2:48 PM
    #623
    airwhen
    Seattle, WA
    Too much to list!
    That's not much time at all. I had those exact bulbs in mine for 13 months. The night before I was going to switch to my retrofits, the bulb dies. Fitting. There must be some other factor. How many hours do you approximate you got out of them? If you drive several hours with them on a day, that can change things.
  4. Mar 24, 2017 at 3:07 PM
    #624
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Got 10 months out of the first set, reasonable. No idea on lamp hours, but we have been getting more rain and we are required by law to have headlights on if using wipers. These look like a contender at a much lower price.
    airwhen[QUOTED] likes this.
  5. Mar 24, 2017 at 3:35 PM
    #625
    airwhen
    Seattle, WA
    Too much to list!
    That's actually a nice thing, having to run your lights when it rains. I always do mine here. In lots of traffic in the city, its a lot safer to see the cars that are moving with their lights on.
  6. Mar 24, 2017 at 5:00 PM
    #626
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Note that while the H4 Hella 100/80w bulbs are a lower price, they are also much shorter life. The Hella's are rated at 100 hours vs 200 hours for the Osrams.
    Norton and EDDO[QUOTED] like this.
  7. Mar 26, 2017 at 4:05 AM
    #627
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Having an issue with my low beams now. My passenger light went out and replaced it a silvania extra vision bulb...same wattage as factory. Everything worked. The next day decided to replace the driver side with the same bulb...everything worked. Got in the truck this morning...no low beams. High beams work. Shouldn't the harness be safe with any wattage bulb? With the factory harness I usually get 2 years with the same bulb.
    When I replaced the passenger side it was black on the inside of the bulb. Usually the filament breaks loose. The first time I seen this in a light bulb. Any help would be great. Thanks.
  8. Mar 26, 2017 at 7:08 AM
    #628
    ARB1977
    North Texas
    Alittle up date. I connected the factory harness and the low beams now work. Decided to remove the upgraded harness and water came out of one of the relays. I'm now wondering if that was my issue. Later today I'll reconnect everything and see if that works.
  9. Mar 26, 2017 at 7:52 AM
    #629
    TRDfarmerTN
    TRDfarmerTN Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    Thinking of getting these osram bilux h4's but I can't seem to find them in h11 for my fogs???
  10. Mar 26, 2017 at 7:57 AM
    #630
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    PMed you.
    They do not make them in H11. Check out my H11 foglight upgrade:
    https://www.tacomaworld.com/threads/the-ultimate-foglight-upgrade-not-led-or-hid.435419/
  11. Mar 26, 2017 at 8:00 AM
    #631
    ARB1977
    North Texas
  12. Mar 26, 2017 at 3:59 PM
    #632
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  13. Apr 3, 2017 at 9:52 AM
    #633
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    The link in the OP to the osram 100/90w says they're not available. Has anyone found them at another location?
    airwhen likes this.
  14. Apr 3, 2017 at 9:59 AM
    #634
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
  15. Apr 3, 2017 at 10:08 AM
    #635
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    crashnburn80[OP] likes this.
  16. Apr 3, 2017 at 10:11 AM
    #636
    airwhen
    Seattle, WA
    Too much to list!
  17. Apr 5, 2017 at 11:18 AM
    #637
    aestheticbrah
    aestheticbrah Well-Known Member
    I am not. I have a first gen. From my understanding, the fogs are only for 2nd gen+?
    Norton and airwhen[QUOTED] like this.
  18. Apr 5, 2017 at 11:37 AM
    #638
    airwhen
    Seattle, WA
    Too much to list!
    If you have factory fog lights then I imagine you could, you would just have to make the harness to fits the connectors.
    On the other side the increase wattage and decreased resistance hasn't been tested on a first gen like the second gen.
  19. Apr 5, 2017 at 4:36 PM
    #639
    ARB1977
    North Texas
    After having issues with water getting into my relays. I took the harness out to let dry for about a week. Today I slaved the harness back in. The headlights don't work.
    If you guys decide to get the harness or already have it I highly recommend protecting the relays from water.
    At this point I maybe sol.
  20. Apr 5, 2017 at 10:29 PM
    #640
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    I don't think additional protection from water is necessary for the normal use so much as being careful to not directly spraying it with a pressure washer when cleaning the engine bay. I've cleaned my engine bay several times with a pressure washer and been careful to avoid the electronics and never had an issue. I've run the harnesses for close to 10 years on many vehicles and never had one fail.
    Norton likes this.
