The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Jan 6, 2019 at 4:45 PM
    #1541
    norvegicus
    norvegicus Member
    12 SR5 2.7 ACLB 4x4
    My 2016 Tundra had that. Was very convenient when towing a heavy trailer, to be able to adjust the low beams down a bit, or to raise them up off road with no oncoming traffic.
  2. Jan 8, 2019 at 5:08 AM
    #1542
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    The metal clips were a PITA sometimes.
    Years ago I had a 5th gen Pontiac Grand Am. The headlight had to be removed to access the bulbs. Each headlight was held in by 2 metal clips that wouldn't line up on the first 30 tries. The 9007 bulb was held in place by the most brittle plastic ring that was guaranteed to snap when swapping a bulb. So replacing bulbs meant also replacing rings and usually involved lots of profanity. By comparison, changing a bulb on the Taco was insanely easy.
    BTW, have you ever seen this before?
    It was a high wattage bulb I had replaced in an ex's car years ago.
    bax and crashnburn80[QUOTED][OP] like this.
  3. Jan 8, 2019 at 6:22 AM
    #1543
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    looks like cheap blue "coating" that slowly burned off.
    Norton likes this.
  4. Jan 8, 2019 at 6:42 AM
    #1544
    replica9000
    2019 T4R ORP
    The glass has also bubbled out. Glad it didn't explode.
  5. Jan 8, 2019 at 7:25 AM
    #1545
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    High wattage bulbs run hot, blue coated bulbs run hot, and the darker the coating the hotter the bulb. The combo of a dark blue coating on a high wattage bulb is going to be very hot. And keep in mind the bulb is pressurized, so as it weakens it will expand outward. I’ve not seen that in person but isn’t too surprising given the combination of factors possibly paired with a cheaper manufacture.
    Norton likes this.
  6. Jan 10, 2019 at 5:54 AM
    #1546
    ChadsPride
    Sponsored by TacomaWorld.com
    I want to do this mod but not great with wiring.
  7. Jan 10, 2019 at 6:07 AM
    #1547
    Jigheadworm
    Jigheadworm Well-Known Member
    David
    2009 barcelona red trd
    The wiring is very easy i just did mine yesterday. Haven't recieved bulbs yet but looks like some improvement with stock bulbs.
  8. Jan 10, 2019 at 7:14 AM
    #1548
    Stupidkid
    Stupidkid Member
    Did this mod with the 100W bulbs mentioned at the beginning alongside new smoked housings on my 2007 double cab. Had china HID H4s in before and got tired of constant bulb failiures and bad ballasts among other things. May just be the brand new OEM housings, but I think the halogens may be brighter than the HID, while definitely having a proper cutoff. Considered doing a projector retrofit with Morimoto D2S, but didnt want to mess with the new OEM housings too much. Glad I didnt.
    Even made my own harness with Bosche Relays, Full Tefzel Wire, high end connectors/terminals from Japan, ceramic plugs, and nylon fire resistant looms, looks great and should be extremely reliable. 100% crimped/soldered. Though I wish I was aware of the new all season bulbs prior to buying the 100W.
    Would recommend 100%. After 225k miles, the truck is looking great with the new housings.
  9. Jan 10, 2019 at 7:25 AM
    #1549
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is very straight forward and all plug and play. If you can change a headlight bulb and change a car battery you can do this mod. You plug the harness into the OEM headlight socket and plug the bulbs into the harness. Then connect the harness to the battery. Done.
    Norton and ChadsPride[QUOTED] like this.
  10. Jan 10, 2019 at 7:29 AM
    #1550
    ChadsPride
    :goingcrazy:
  11. Jan 10, 2019 at 8:08 AM
    #1551
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    It's harder to change the bulbs than run the wiring!
  12. Jan 11, 2019 at 1:35 PM
    #1552
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    crashnburn80[OP] likes this.
  13. Jan 11, 2019 at 1:39 PM
    #1553
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Where did you get the new housing?
  14. Jan 11, 2019 at 4:13 PM
    #1554
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I've run Flossor 90w H11s, but not tried their H4s. Note that Bulbfacts gives them a 'Best high beam' award, but they only compared them to one other high wattage bulb. The superior lumen output of a high wattage bulb on high beam will beat all stock wattage bulbs without question. The only other high wattage bulb they compared to was from Hella, which unfortunately as a bulb brand are not what they used to be. The high wattage Hella can be purchased for about $2, and are made in Asia, not Germany anymore. So comparing it to really only one other $2 bulb and naming it best isn't exactly much of a comparison. Now I'm not saying they are not good by any means, Flosser is made in Germany, just pointing out the lack of comparison to give them a recommended rating.
    VE7OSR[QUOTED] likes this.
  15. Jan 12, 2019 at 2:40 PM
    #1555
    Stupidkid
    Stupidkid Member
    Bought from the dealer locally. Roughly $350+tax for the set. Worth it not to have to deal with low quality aftermarket housings, bade reflector design, leaks, etc.
  16. Jan 14, 2019 at 3:47 AM
    #1556
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Just got the H4 and H11 Nightbreaker Laser 150% I will be putting in over the weekend I will post output pics for all to see.
    crashnburn80[OP] and Norton like this.
  17. Jan 14, 2019 at 7:29 AM
    #1557
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What are you currently running again? I don’t recall.
  18. Jan 14, 2019 at 7:35 AM
    #1558
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Philips +130's
  19. Jan 14, 2019 at 7:41 AM
    #1559
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Try comparing them with your lux meter when you make the change, though depending on how long your +130s have been in there, they do dim over time. I was pretty disappointed in the OSRAM +150 in the H11s compared to other bulbs. I think they got a bit overzealous with the blue coating encroaching on the filament.
    Norton likes this.
  20. Jan 14, 2019 at 7:44 AM
    #1560
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You got it
