The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Dec 1, 2015 at 10:21 PM
    #161
    Sean73T
    Sean73T Well-Known Member
    Sean
    SoCal
    17 Pro
    Any idea if this upgrade is possible on a 16?
  2. Dec 1, 2015 at 10:26 PM
    #162
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I was thinking of the back from the engine bay.
    The 10-15 degrees lower seems inline with the hand touch feel on the lens.
    The harness upgrade is definitely doable. I'm not framiliar with the 2016 headlight bulb, but if it is a 9003/H4 the 85w Osram is definitely doable.
  3. Dec 1, 2015 at 10:26 PM
    #163
    airwhen
    airwhen "You done messed up A.A.Ron!!!!
    Seattle, WA
    2015 TRD Sport DCSB 4X4
    Too much to list!
    The 2016 has Projectors, at least on the TRD Sport I was looking at. I have a Highlander that has the projectors and H11 bulbs. That I did a 55W 4300K AC HID retro fit. It works very well. Without looking into that truck further I can only guess you could do the same as I have with my Highlander.
  4. Dec 1, 2015 at 10:29 PM
    #164
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If it has H11s bulb upgrade options are terrible. I'd look at LED/HIDs since it is in a projector and not a halogen reflector.
  5. Dec 1, 2015 at 10:31 PM
    #165
    airwhen
    Seattle, WA
    Too much to list!
    The Projector in the Highlander work very well with a very clean horizon and no scatter at all. If you use a 4300K bulb, it looks definitely factory. I would like to think the Tacoma uses the same projector as a 2013 Highlander.
  6. Dec 2, 2015 at 6:01 PM
    #166
    airwhen
    Seattle, WA
    Too much to list!
    It seems the Postal Service surprised me today. No, not in shooting everyone in the local office, but in delivering my lights a day earlier. I dropped everything and began to install them the moment that magical Priority Box appeared.
    Output is brighter, that's a proven. It's the correct light pattern, also proven. And it is hotter, but by what I would consider an inconsequential amount. Although warmer, it's still cool enough to the touch.
    Same as yesterday, light on for 30 minutes taking the average of 5 tests, which was 135.9 degrees.
    As for light color, it is greater than a standard halogen. I inserted my H11 HID 4300K bulbs and AC ballasts into my fog lights for reference.
    Garage Door Test.
    Todays weather during testing was only 3 degrees warmer, so likely insignificant difference.
    My final thoughts: This is a fantastic upgrade. The lumens are vastly improved, little to no consequences for the conversion, (ie light scatter, improper light color, poorly angled beam). We have reflectorized lights on the 2nd Gen Tacoma. HID/LED upgrades are nice in theory, but poor in execution.
    I would attribute this upgrade as to entering a room with a light switch potentiometer (dimmer). Regular bulbs are 1/2 way turned up, this turns them all the way up.
    Crom and crashnburn80[OP] like this.
  7. Dec 2, 2015 at 6:54 PM
    #167
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Great data, thanks for posting. Now I'll have to find another use for the new IR temp gun.
  8. Dec 2, 2015 at 7:11 PM
    #168
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    photos dont work
  9. Dec 2, 2015 at 7:29 PM
    #169
    GuroKC
    GuroKC Member
    Kendal
    2015 Tacoma Access Cab TRD Sport
    I went with the LED replacements from XenonHIDs.com and am very happy. Much less light scatter, good color, and super bright.
    Before Stock
    and with the LEDs
    No change in the ammount of flashing I got before or after.
  10. Dec 2, 2015 at 7:40 PM
    #170
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Work for me.
    That LED beam pattern looks disastrous. Note how the Halogens are flat cut off, the LED are all over the place.
    iyapysnf and ndcmack like this.
  11. Dec 2, 2015 at 7:46 PM
    #171
    FawkQ
    FawkQ Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    if that LED pic is with lo's... I agree... disaster!
    if they're hi's, acceptable (ish) ?
  12. Dec 2, 2015 at 8:17 PM
    #172
    airwhen
    Seattle, WA
    Too much to list!
    Um.....That looks pretty scattered to me. Not quite a solid horizon. I just went out for gas and this is what my horizon from about 40 feet away looks. It should be more solid like this.
    Also I dragged my wife into having her drive behind me while I look at the lights. They don't seem different from stock at all, until...... I went down a hill and my position was under the horizon. They are bright!
  13. Dec 2, 2015 at 8:59 PM
    #173
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct, it should be a flat clean horizontal cut off line just like that. If it is not, the optics are wrong and you are likely blinding others.
    Stay above the horizon! They are super bright!
  14. Dec 2, 2015 at 9:00 PM
    #174
    airwhen
    Seattle, WA
    Too much to list!
    You will find many uses. Here is one you requested that I forgot about. The back of the housing. Sorry about it being upside down.
  15. Dec 2, 2015 at 9:08 PM
    #175
    airwhen
    Seattle, WA
    Too much to list!
    OMG!! They are. I am really loving this upgrade. I have to play with it a lot more, but so far so great! Thanks again Crashburn80, great idea and setup!
    Along with this, I also did my outside temperature mirror with sensor.
  16. Dec 2, 2015 at 9:44 PM
    #176
    airwhen
    Seattle, WA
    Too much to list!
    Interesting. I tried this is another browser (usually Chrome) but tried Safari and not being logged in and the pictures did not come up.
  17. Dec 2, 2015 at 10:21 PM
    #177
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    I'm logged in and using Safari. I'll try Firefox and see what happens. Interesting as photos from other posters come up just fine. Damn technology.
  18. Dec 2, 2015 at 11:55 PM
    #178
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Not getting photos either on safari logged in
  19. Dec 3, 2015 at 12:01 AM
    #179
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Just tried on my MacBook, me neither. Were they uploaded to TW or remotely hosted? Works fine on IOS.
  20. Dec 3, 2015 at 12:22 AM
    #180
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    Can't see them on my phone using IOS but I haven't upgraded to 9 yet.
