The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Feb 15, 2017 at 2:44 PM
    #601
    wlandrum
    wlandrum Member
    Pasco, WA
    '12 Tacoma DC/LB, Mag Gray, TRD Sport
    Looks great, I am going to make it happen!! Thanks for the info.
    crashnburn80[OP] likes this.
  2. Mar 7, 2017 at 10:55 AM
    #602
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Last night I installed my harness. Currently running factory bulbs. The cutoff line is sharper than before and the output looks alittle brighter.
    Definitely worth the upgrade. I may stick to the factory bulbs for now.
  3. Mar 7, 2017 at 3:00 PM
    #603
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I'm kind of struggling to figure out how / why installing the HD harness (whilst leaving the OEM bulbs in) would lead to a sharper cutoff line. The optics and the illumination source are still the same. Am I missing something here?
  4. Mar 7, 2017 at 3:52 PM
    #604
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    It appears sharper because it is more obvious due to more light output.
  5. Mar 7, 2017 at 5:00 PM
    #605
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    I've read through the whole thread and want to do this upgrade. However, the rally lights credit card issues has me concerned. Has anyone ordered from them lately and can say that there wasn't an issue?
  6. Mar 7, 2017 at 5:08 PM
    #606
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    @ARB1977 just ordered recently, within the last 2 weeks.
    Rally Lights did switch credit card processing companies after getting reports of the issue.
    Edit: BTW that is a lot of reading!
    Norton likes this.
  7. Mar 7, 2017 at 6:39 PM
    #607
    ARB1977
    North Texas
    I don't know. I'm assuming I'm getting less current drop with the thicker gauge wire, more current to the bulbs.
  8. Mar 7, 2017 at 6:41 PM
    #608
    ARB1977
    North Texas
    It took about a week to get my harness. No issues with payment.
  9. Mar 9, 2017 at 5:39 PM
    #609
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    which harness did you need?
  10. Mar 14, 2017 at 8:34 PM
    #610
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    This thread is one of the reasons why I like tacomaworld. Highly informative, educational and pretty regularly updated.
    This is a great, functional modification that is a legitimate upgrade with measurable results.
    Thought I should commend OP since I'm using this post as bookmark for later reference...
  11. Mar 14, 2017 at 8:38 PM
    #611
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    You are likely conventionally switched. PM me if you need help walking through the test procedure. You can pick up a multi-meter at Harbor Freight for $5 to run the test.
    RedTaco2134[QUOTED] likes this.
  12. Mar 14, 2017 at 8:56 PM
    #612
    RedTaco2134
    Scott
    Portland, Or
    Copy that, thank you!
  13. Mar 15, 2017 at 2:45 PM
    #613
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    I just finished this upgrade about a month ago, I am more than impressed! I was planning on an LED light bar; spread pattern and Light Force HID Mod for spots. I'm not really interested in doing anything else with lighting until I am done with other stuff at this point. I just drove 2000 miles to Montana and back, with the beams properly adjusted, you really do not need anymore light, even for most off-road applications! Every sign on the road was glowing like crazy! IMO, these things outperform any other light option available without compromising light pattern.
  14. Mar 15, 2017 at 4:26 PM
    #614
    ARB1977
    North Texas
    Which bulbs do you have?
  15. Mar 15, 2017 at 8:33 PM
    #615
    mjohn617
    Petaluma, CA
    The Osram 85W, I used everything referenced in the OP.
    CORRECTION
    Osram 100W
  16. Mar 17, 2017 at 2:59 PM
    #616
    ARB1977
    North Texas
    How long have you had them?
  17. Mar 17, 2017 at 7:28 PM
    #617
    mjohn617
    Petaluma, CA
    A month maybe.
  18. Mar 17, 2017 at 7:37 PM
    #618
    mjohn617
    Petaluma, CA
    I have had experience with both LED and HID in the past with other cars. The light can be a high quality output if done right, but it has never seemed the same as halogen. I had an HID diving light maybe 10 years ago, after spending $400 on it, I ended up selling it cause I hated the light effect, it just didn't seem like the right application. If I stick with this setup and add the other lights as planned in the future, the HID will be great for 800m range, but I am going to be dealing with an amperage issue. That's kind of the only downside I see with using these.
  19. Mar 20, 2017 at 4:45 PM
    #619
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    Installed my harness today. My fuse wasn't seated very well apparently. I just plugged in the drivers side and tested. It worked. Then plugged in the passenger side and then they didn't work. Pulled the fuse and reseated and they worked again. Just figured I'd post incase someone had the same issue and it freaked them out.
    medjah, airwhen and crashnburn80[OP] like this.
  20. Mar 24, 2017 at 6:34 AM
    #620
    aestheticbrah
    aestheticbrah Well-Known Member
    I did this upgrade about a year ago and it's still going strong. Thanks, OP; you're amazing. If I hadn't seen this thread, I would have spent so much unnecessary cash on retrofits.
