The Underland Official 96 SR5 on 35's
Discussion in '1st Gen. Builds (1995-2004)' started by Kapton, Feb 6, 2015.
  1. Feb 6, 2015 at 5:01 PM
    Kapton
    Kapton [OP] Last of a Dying Breed
    Keith
    Canada
    96 SR5 Multicolor Dream Can
    Truck Bio
    As it sits today!
    Older photos
    Current Specs
    Drivetrain
    JDM 5VZ-FE 3.4L
    Manual
    URD Short Shift Kit
    Exedy Clutch
    Homebrew Snorkel
    Axles
    Toytec Diff Drop Kit
    Rear Diff Breather Relocation Mod
    Front Diff Breather Extended
    ECGS Front Axle Bushing
    4Runner E-locker Axle Swap, Custom Wiring Harness
    4:30 Gears
    Suspension
    Bilstein 6112 Front Struts
    Eibach 14" x 650lbs Springs
    Bilstein 7100 10" Short Bodies, Relocated to Axle
    OME Dakar Leafs with Extra Leaves
    OME Geasable Shackles
    Timbren Offroad Flip Kit
    SPC Upper Control Arms
    TC Spindle Gussets
    Energy Steering Rack Bushings
    Swaybar Delete
    Wheels&Tires&Brakes
    Stealth Blue 16" SCS F5's
    315/75R16 Toyo Open Country MT
    Gorilla Lugs
    320mm Brake Swap With PowerStop Tow Brakes/Rotors
    ABS Delete/LSPV Delete
    Wilwood Proportioning Valve
    Toytec Braided Front Lines
    Trail Gear Extended Rear Line
    Lighting
    HELLA 80/100 Watt Headlight Bulb Conversion
    Baja Designs Amber LP9 Pro x2
    Diode Dynamics Amber SS3 Pro Driving x2
    Rago Ditch Light Brackets
    Diode Dynamics Amber SS3 Combo Ditch Lights x2
    Trux Scene Lights
    Baja Designs S1 Chase Lights
    Baja Designs Rock Lights
    Armour & Body
    Advanced Fiberglass 4.5 Front Fenders
    Advanced Fiberglass 4 Bedsides
    Rago Bed Stiffeners
    Raider Canopy
    Prinsu Xtra Cab Rack
    Prinsu 6' Canopy Top Rack
    Coastal Offroad Rear Bumper - Modified for Fiberglass
    Coastal Offroad Closed-Top Bumper with Full Hoop
    Smittybilt X02 10K Winch
    Factor55 Flat Link Expert
    Beefed up bumper mounts
    RA Motorsports Full Moab Aluminum Engine, Trans, Transfercase Plates
    RA Motorsports Aluminum Gas Tank Skid
    Demello Rear Frame Reinforcement Plates
    Trail Gear Frame Box Kit
    Trail Gear Rear Diff Armour
    1990 Honda CRX Seat Swap
    RAD Rubber Splash Guards
    Audio Goodies
    4 X Alpine Type R 6.5" Speakers
    Alpine MRX-F65 4 Channel Amp
    Alpine Headunit
    105Ah BMW AGM Battery Swap, with Custom Cradle
    105Ah BMW AGM Dual Battery
    Camping Stuff/Storage
    Treeline Outdoors Tamarack
    Treeline Outdoors 2m Awning
    Bed/Storage System in Box
    Custom Molle Rear Seat Organizer
    HomeBrew Diesel Heater
    Empty Bank Account -> Soon
  2. Feb 9, 2015 at 6:56 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Nice build man. I loved my 95. Just sold it a couple weeks ago
  3. Mar 17, 2015 at 6:40 PM
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    How do you like those Rancho 9000XL shocks? I just put a set on the rear of my 4Runner. MUCH better than the AutoZone brand I had on. Wish I could compare them to Bilstein since they seem to be one of the favorites.
  4. Mar 19, 2015 at 11:52 AM
    Kapton
    Keith
    Canada
    The Rancho's are not to bed on the street. When I bought the truck it had some pretty shitty Monroe shocks/struts with lift spacers under the leafs and on top of of the struts. I swapped them out for the Rancho's after a year or so and it was much much better. I run them a little stiffer. The only argument against them is that the front have a nasty top out on the trails. I plan on swapping them out in the future with some Fox shocks.
  5. Mar 19, 2015 at 12:09 PM
    LSC15
    Logan
    2008 TRD D-Cab
    I got a set of retrofitted headlights if you ever want them
  6. Apr 8, 2015 at 10:10 AM
    Kapton
    Keith
    Canada
    Picked up my rack and tend last week. Got the rack welded and painted over the weekend! Everything is on the truck now!
    Chopped the All Pro rack 3" so it sits right below the brake light, but I can still see out the back window.
    Doing a final tack before we pulled it off to finish the welding.
    Cleaned and ready to add some primer and paint.
    Paint on and drying.
    Kept the AP clean and raw, just a little clear on it to keep it shining :cool:
    And finally everything installed! :)
    Oh and.... Lights!
    chrslefty likes this.
  7. Mar 21, 2016 at 9:03 PM
    Kapton
    Keith
    Canada
    North Ghost/Wiaparous Falls today. The new additions to the fender flares really helped out.
  8. Mar 29, 2016 at 10:27 AM
    Kapton
    Keith
    Canada
    I decided the truck need more sway and way less bar. Sway bar is now out. We shall see how it goes.
  9. Mar 12, 2018 at 4:41 PM
    Kapton
    Keith
    Canada
    FFUUUUUUUU....... Well I think I have a problem....
    Been looking into JDM options. does anyone have any experience with a JDM 5vz? I hear you have to swap some sensors but any fitment issue stuff. There is not a whole lot on this.
  10. Mar 17, 2018 at 7:05 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    If I were you id find a wrecking yard engine its close and easy.
  11. Mar 17, 2018 at 9:20 PM
    Kapton
    Keith
    Canada
    There is an importer in my area with stock so that makes it tempting. I have been trying to track down another option but they are rare here and generally high millage
  12. Mar 28, 2018 at 8:23 PM
    Kapton
    Keith
    Canada
    Completely deleted the ABS and rear LSBV. Installed a Wilwood valve next to the master and bent some custom lines.
  13. Oct 28, 2019 at 5:47 PM
    Kapton
    Keith
    Canada
    Short story long, The truck has been running for 1.5 years again, Lots of work gone into it since my last post, I will try to keep this a little bit more up to date.
  14. Dec 1, 2020 at 6:49 PM
    Kapton
    Keith
    Canada
  15. Mar 21, 2021 at 3:19 PM
    Kapton
    Keith
    Canada
  16. Mar 21, 2021 at 5:11 PM
    mlcc
    Oregon
    Its been awhile since ive peeked in here, trucks come a long way.
  17. Mar 21, 2021 at 6:17 PM
    Kapton
    Keith
    Canada
    Its been quite the driveway queen all winter, figured I might put my head down and get some work done!
  18. Dec 5, 2021 at 2:09 PM
    Kapton
    Keith
    Canada
  19. Dec 5, 2021 at 4:20 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Truck looks awesome.
    Got any more pics of how you mounted your rear shock relocation?
    Still using the factory top mounting points?
  20. Dec 6, 2021 at 5:48 AM
    Kapton
    Keith
    Canada
    Ill try to take some pictures soon for you, I used the stock upper mounts and welded mounts to the axle when I did the swap. I will likely be doing a 3rd Gen shock retro fit pretty soon here.
