The V6 lurch when A/C is on, do they all do this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pool Runner, Sep 16, 2014.
  1. Sep 17, 2014 at 3:15 AM
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    My 2000 cherokee did it as well, feels exactly the same as the Tacoma. Lurch when the AC clutch engages.
  2. Sep 17, 2014 at 3:43 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I don't feel it but I don't have an auto.
  3. Sep 17, 2014 at 4:00 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Mine does it too. Better have a firm foot on the brake when in the drive through!!! Come on Toyota you can do better than this.
  4. Sep 17, 2014 at 6:29 AM
    oldstick
    oldstick Medicare Member
    GA
    AC hardly ever kicks off around here, not with me in it, not gonna let that happen. So I never noticed it but I thought all cars did that. Idle goes up slightly so car wants to start moving. Some more so than others.
    :notsure:
  5. Sep 17, 2014 at 6:42 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Was your 2.7 an automatic, or a standard?
    Every automatic I've ever owned or driven has done it, because you leave it in drive at a stoplight and therefore when the AC compressor kicks on and the engine revs increase slightly, it transfers some additional torque to the transmission and causing the truck to lurch.
    No manual transmission does it, because you push the clutch in and therefore completely disengage the engine from the transmission.
    Even if it was exclusive to the Toyota's, it wouldn't be related to the AC compressor (unless it was a constantly engaged compressor instead of the clutched design that every automaker uses). It'd be related to the torque converter design, since that's what transmits the power from the engine.
  6. Sep 17, 2014 at 6:01 PM
    Yota1
    Yota1 Well-Known Member
    Mine does it. Annoying as hell.
  7. Sep 17, 2014 at 6:05 PM
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    Mine does it as well.
  8. Sep 17, 2014 at 6:07 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    your ac compressor is actually a torque multiplier, so your brakes have a harder time holding on
  9. Sep 17, 2014 at 6:40 PM
    walkerkm
    walkerkm Well-Known Member
    Kirby
    Kapolei, Hawaii
    14 DCSB TRD offroad 4x4
    my 2010 did and so does my 2014
  10. Sep 17, 2014 at 7:04 PM
    mindleak
    mindleak Active Member
    Devin
    San Antonio, TX
    2014 V6 DC 4x4 TRD Off Road
    Fog light mod!
    My 2006 PreRunner did it pretty hard, I either don't notice it as much or my 2014 doesn't do it near as bad, but it's still there.
  11. Sep 17, 2014 at 7:57 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    This is completely normal. Many cars and trucks do this. My 2001 Dodge Dakota did.
    When the AC compressor clutch engages, the idle speed is increased to prevent the engine from bogging down or stalling.
  12. Sep 17, 2014 at 9:26 PM
    oceanslide
    oceanslide Well-Known Member
    Erik
    Oceanside, CA
    2006 Access Cab
    5100s, OME 885
    My 06 does this too
  13. Sep 18, 2014 at 8:47 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    My 2.7L 99 prerunner does this lurch. Pretty sure my 3.4L 98 4runner does it also. Both are automatics.
