The Waco,Temple,Killeen (and surrounding areas) I Dirty 5 Krew
Discussion in 'Texas' started by MattCowsmasher, Aug 3, 2014.
  1. Oct 26, 2019 at 6:37 PM
    #1661
    Bigdaddy4760
    Maner
    Poolville Texas
    I would drive that
  2. Oct 26, 2019 at 6:37 PM
    #1662
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Same. I posted the video on my original post
  3. Oct 26, 2019 at 6:55 PM
    #1663
    Jackwagon6
    Jackwagon6 TTC #0187
    Gordy
    Troy TX
    2015 Trd off road
    My buddy just put a two post lift in his shop.
  4. Oct 26, 2019 at 7:31 PM
    #1664
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Anyone have a spring compressor that won’t explode my face holes
  5. Oct 26, 2019 at 7:32 PM
    #1665
    Beretta4x4
    Josh
    Temple, TX
    Closest one to us is Chris @Texoma . You can bring him your spring/shock setup and he can put it together for you for cheap. Local shops can assemble the assembly, too
    If you have access to Fort Hood, the Auto skills center has what you need. That's where I did my lift.
  6. Oct 26, 2019 at 7:37 PM
    #1666
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    I try to stay off hood. I don’t like cleaning all the bullets and stuff out of my truck
  7. Oct 26, 2019 at 7:39 PM
    #1667
    Beretta4x4
    Josh
    Temple, TX
    I get that lol. Ammo isn't a problem coming on post unless its AP.
  8. Oct 26, 2019 at 7:40 PM
    #1668
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    I may take em over to McGuire’s and see if they have one. Guess I could chance it with autozone ones lol.
  9. Oct 26, 2019 at 7:40 PM
    #1669
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Where did you get your truck aligned after the lift josh
  10. Oct 26, 2019 at 7:44 PM
    #1670
    Beretta4x4
    Josh
    Temple, TX
    I took it to the Firestone on post after I did my lift at Sprockets. Got the lifetime alignment and I've been getting aligned there when I was still active, now at the Firestone in Temple. @MattCowsmasher , where do you get yours aligned? It's at Tires 2 You or at Goodyear?
    Firestone in Temple kinda sucks and won't do custom specs. The Toyota dealer in Temple has done custom spec alignments for me in the past.
  11. Oct 26, 2019 at 7:51 PM
    #1671
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Temple use to do my Jeep for me. I don’t know enough to tell them to do custom stuff for the alignment.
  12. Oct 26, 2019 at 7:54 PM
    #1672
    MattCowsmasher
    MattCowsmasher [OP] ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I’ve been using Goodyear in Belton by heb those guys have been awesome and got the specs I asked for without issue.
  13. Oct 26, 2019 at 7:55 PM
    #1673
    Beretta4x4
    Josh
    Temple, TX
    They won't do it anyways. I tried to explain the reasons for my suspension alignment and they didn't understand lol. Tech also said he wouldn't do it because he wasn't going to be liable lol :rofl:.
    I went to trade school and did that stuff for a living before the Army.
    The dudes there are grease monkeys, not techs lol. They know what to do, but not the science behind it. They can barely get my car properly aligned with the steering wheel straight, so I periodically have them toe-and-go. If I need custom alignment specs, I'll go to the Toyota dealer first then Tandem off-road near Dallas.
  14. Oct 26, 2019 at 7:55 PM
    #1674
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I don’t but I have a set of 886s you can borrow if one of your fronts has blown out to get you by.
  15. Oct 26, 2019 at 7:56 PM
    #1675
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Lmao. Wait a minute. How do you figure out what you need your alignment to be? In order to tell them what ya want?
  16. Oct 26, 2019 at 7:58 PM
    #1676
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Thanks bud. Got parts on the way. My driver front shock is leaking. Also have to replace my 600# pound springs with 650s. Do to all that armor!!!
  17. Oct 26, 2019 at 7:58 PM
    #1677
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Then I can wire my winch up
  18. Oct 26, 2019 at 8:02 PM
    #1678
    Beretta4x4
    Josh
    Temple, TX
    I told them to max out caster first, then adjust camber to zero, then adjust toe to zero. They wouldn't do it because of factory specs and i explained to them it's to
    1. Clear 35s
    2. Moving camber to zero allows the wheel at it's current lift to remain in the center of the camber range as the suspension compresses and extends and
    3. Because I said so lol.
  19. Oct 26, 2019 at 8:05 PM
    #1679
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Dang dude I’ll be leaving temple about 1030am to Waco I can meet you and drop them off if you’d like.
    Bigdaddy4760 and Beretta4x4 like this.
  20. Oct 26, 2019 at 8:06 PM
    #1680
    Beretta4x4
    Josh
    Temple, TX
    886 coils are rated at 660 lbs. :boink:
