The Waco,Temple,Killeen (and surrounding areas) I Dirty 5 Krew
Discussion in 'Texas' started by MattCowsmasher, Aug 3, 2014.
  1. Nov 1, 2019 at 9:03 AM
    #1961
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Parking is kinda limited, but we could fit 5-10 trucks and about 20 people, i think
  2. Nov 1, 2019 at 9:21 AM
    #1962
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Gotcha, I’ll keep lookin!
  3. Nov 1, 2019 at 11:20 AM
    #1963
    Beretta4x4
    Josh
    Temple, TX
    I meant to post it here lol
  4. Nov 1, 2019 at 8:45 PM
    #1964
    Jackwagon6
    Jackwagon6 TTC #0187
    Gordy
    Troy TX
    2015 Trd off road
    Sooo she drives straight but now runs the cab mount on the driver side. Never rubbed before so he had to jack the Castor up. They were even on the screen and print out. So where do I take it locally to us?
    Bigdaddy4760 and Beretta4x4 like this.
  5. Nov 1, 2019 at 8:47 PM
    #1965
    Beretta4x4
    Josh
    Temple, TX
    Matt uses goodyear in Belton. I haven't found a great place, but the Toyota here did my specs no problem.
    They are $100 for the alignment, though.
    @MattCowsmasher ?
  6. Nov 1, 2019 at 8:55 PM
    #1966
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    What were your specs. Is that a universal thing or tailored to each vehicle
  7. Nov 1, 2019 at 9:02 PM
    #1967
    Beretta4x4
    Josh
    Temple, TX
    Honestly it's tailored to each vehicle, but there are some specific considerations.
    For caster, you want to push the wheel as far forward as possible in the wheel well, without affecting steering at speed to ensure nimble turning at speed, but also clearing the rear of the wheel well. It's not really necessary, so i say when you start the alignment, max-out positive caster.
    Adjust camber next, because with a lift, the wheels gain positive camber pushing the top off the wheel away from the vehicle and reducing the context patch at rest and when the wheel drools, that positive camber is increased further reducing your contact patch. Camber should be set at zero, because most of your driving use on the road, so it'll even wear on your tire, but also allow better contact patch during wheel travel.
    Toe is adjust last. Ideally seeing toe at zero will mean when traveling in a straight line you'll get even tire wear as well. The spec on toe is give it take .03 degrees (I think) from zero anyways. Toe will get your wheel straight, as it's adjusted with the tie rods.
    Hope that helps.
    My specs are ? Caster, ? Camber and factory toe. I'm in your boat right, now.
    MattCowsmasher[OP] likes this.
  8. Nov 1, 2019 at 9:04 PM
    #1968
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Thanks. Just need to find a spot. It really worried about cost. Just want to done right!!
  9. Nov 1, 2019 at 9:04 PM
    #1969
    Beretta4x4
    Josh
    Temple, TX
    You will have a hard time to find many (or any) places that charge over $100 for an alignment.
  10. Nov 2, 2019 at 5:33 AM
    #1970
    TacomaInTx
    TacomaInTx Well-Known Member
    Roger
    Eddy, TX
    2012 DCLB 4x4 TRD Sport Tacoma
    Bilstein 5100 all 4 corners, OME 886 front springs, adda leaf progressive rear packs. Front upper control arms replaced also ,Group 31 battery conversion with Odyssey gel battery . Warn winch bumper and winch. Prinsu roof rack,Full grille replacement with ridgid duallys mounted behind, and 17" SCS bronze wheels with copper 255/80/17 ,
    Timely post... I used to wheel Jeeps and no place here in Waco area could ever get a lifted vehicle with larger sized tires spot on. Buddy suggested Southern Tire and have used for about 5 years now. They did an outstanding job each time so I have been going back since. They charge $75 but are first come and get busy I'd be there at 7:30 if you can. I just had my Tacoma aligned yesterday another fine job and I have lift and larger tires on it too.
  11. Nov 2, 2019 at 5:49 AM
    #1971
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Alignment specs as follows:
    1. Caster to 3.5* +/- 0.5* (more is better)
    2. Camber and Toe must be to factory spec as close to Zero as possible
    3. Torque alignment cam nuts/bolts to 130ft#'s
  12. Nov 2, 2019 at 6:25 AM
    #1972
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Do you remember when what they set your castor at. That’s the problem is that a lotta shops won’t set that as positive as they can
  13. Nov 2, 2019 at 6:31 AM
    #1973
    Bigdaddy4760
    Maner
    Poolville Texas
    Good Morning Krew
  14. Nov 2, 2019 at 6:40 AM
    #1974
    Jackwagon6
    Gordy
    Troy TX
    2015 Trd off road
    Morning!!
  15. Nov 2, 2019 at 6:44 AM
    #1975
    MattCowsmasher
    MattCowsmasher [OP] ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Ya I think so, but I always get the 3 year deal which is 170.
  16. Nov 2, 2019 at 6:44 AM
    #1976
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
  17. Nov 2, 2019 at 9:29 AM
    #1977
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Morning Matt
  18. Nov 2, 2019 at 9:33 AM
    #1978
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    :hattip:
  19. Nov 2, 2019 at 11:29 AM
    #1979
    Beretta4x4
    Josh
    Temple, TX
    Hungover lol
  20. Nov 2, 2019 at 1:06 PM
    #1980
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Same
