The way I understand this.. [all wheel drive]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wawuzit, May 8, 2019.
  1. May 8, 2019 at 3:55 PM
    #61
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    I always thought that 4wd was more robust than awd. 4wd is better on the rough stuff. Here in the northwest Indiana the roads are often icy or snowy in spots and awd is better because it comes on when needed on the paved roads we have. 4wd is not a bad thing to have on snowy roads but it has to be turned off and on too much unless there is a couple of inches on the pavement. I turn to the Murano more in winter.
    DavesTaco68 likes this.
  2. May 8, 2019 at 5:08 PM
    #62
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    I had a wrx (all wheel drive) and now have a tacoma or (2h/4h/4l). I live in Connecticut and we see a lot of crappy weather including plenty of black ice. It really comes down to personal preference on drive type but neither is immune to black ice. Best bet for your situation might be studded tires on that Lexus for the season.
  3. May 8, 2019 at 5:24 PM
    #63
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    How do you classify a 4 Wheel Dr. sprinter? It has part time all wheel drive with a center differential ( Nonlocking, viscous coupling) With an optional low range transfer case. It is also not shift on the fly.
  4. May 8, 2019 at 5:28 PM
    #64
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    I think the most basic definition is: if it doesn’t require any driver intervention it is AWD; if it offers any type of interface it is 4WD.
  5. May 8, 2019 at 5:29 PM
    #65
    eon_blue
    Azusa, CA
    Sounds like a variation on full time 4wd
  6. May 8, 2019 at 8:35 PM
    #66
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    Then there is also the "Subaru Symetric System" -that is if you do not class them with one of your three. I own a 15 Outback -- trust me these are great especially with the "X-mode"
  7. May 8, 2019 at 8:45 PM
    #67
    markmizzou
    Mark
    Missouri
    Most AWD vehicles automatically turn into a FWD vehicle at speeds around 25-35 mph. Subaru keeps driving all 4 wheels all the time -under ideal conditions 60/40 split at highway speeds. I think the 19 RAV4 on the sport model and optional on the limited is using a "Subaru like" system for its drive.
  8. May 8, 2019 at 8:53 PM
    #68
    dbbowen2
    dbbowen2 Former Rock Crawler.
    TN
    2017 TRD OR Taco/2001 Land Cruiser/ 1976 FJ40
    too many to list
    Subaru's awd is still awd. I used to drive a STI for a while. I think the X mode is a more sophisticated computer controlled awd. My sti didnt have that, it had a selectable center diff kind of where you could split the lockup more favorable to the front or the rear. Subarus are pretty neat little cars
  9. May 8, 2019 at 9:20 PM
    #69
    markmizzou
    Mark
    Missouri
    Actually you need to read up on Subaru's "X-mode" -- I really think Toyota's "crawl control" was modeled after the X-mode . You take your foot off the brake and the accelerator and the car will walk you down a steep slick hill -- all the driver does is steer. BTW Toyota owns 16% of Subaru, which probably explains why there are so many similarities between the two.
    We had a CRV in 08 and believe me the Subie would blow the CRV away in a traction competition -- so the Subie system IS vastly Different -- do your research -you'll see.
  10. May 8, 2019 at 10:03 PM
    #70
    dbbowen2
    TN
    too many to list
    Isnt that just downhill assist? Toyota built crawl control loosly based on Marlin Crawlers dual transfer case set up. thats where the name crawl control came from.
    It looks like X mode is a combination of things its a delayed throttle, with computer controlled transmission shifting, front bias of the center diff, torque vectoring, and downhill assist.
    My sti had the torque vectoring (used for high speed instead of low speed), and full driver selection of bias of the center diff from front to rear... but everyone in a sti puts the bias in the rear because its fun. It didnt have the computer controlled transmission stuff because of the manual
    Its a neat system for sure. Still AWD though
  11. May 8, 2019 at 10:58 PM
    #71
    bensonxj
    bensonxj Well-Known Member
    2016 DCSB TRD Sport
    I loved the transfer case on my old Jeep Grand Cherokee. It had full time 4x4, part time 4x4, and 4low. My Tahoe has the same set up. It is the best of all worlds. Especially in the situations like you described with intermittently covered roads, if find in the tacoma I end up switching in and out of 4x4 often so I am not turning on dryish pavement. For example at my work there is a incline with a badge reader that I have to stop at. Then in the garage it is a hard right or left. In the Jeep I can pull up, badge in and go in full time. In the tacoma I can't move in 2 wheel drive, and it is hard to time in perfectly to drive forward, switch to 2 wheel drive before turning and binding on the drive inside pavement.
    Also, for the wife who no matter how many times I explain the differences, the auto or full time 4x4 on her tahoe is the best!
  12. May 8, 2019 at 11:22 PM
    #72
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    I’d consider it a pickup, but not a truck. A pickup car, perhaps?
  13. May 9, 2019 at 3:48 AM
    #73
    wawuzit
    wawuzit [OP] Well-Known Member
    steve
    Clinton, Tennessee
    2019 gray 4dr Tacoma TRD
    none
    I should have worded that better.:)
  14. May 9, 2019 at 4:52 AM
    #74
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The 2nd gen Sequoia comes with the ability to run in any of the modes previously discussed.
    Having swapped a Land Cruiser AWD case into my old 2008 Tundra, I can say w/o a doubt, my Taco will be receiving a similar upgrade. Price and mileage concerns (minimal on a stock truck) are likely the reasons behind the lack of offerings. The increased in ability on multiple fronts, from the OP's point of safety, to successfully backing a trailer up a grassy hill, never mind the fun factor... it simply needs to be.
  15. May 9, 2019 at 6:33 AM
    #75
    dbbowen2
    TN
    too many to list
    Haha the irony here is that lots of people, myself included wanted to or have done part time swaps on 80 series cruisers. I never got around to doing it personally, but I know a few people that did it. Different strokes haha
  16. May 9, 2019 at 6:52 AM
    #76
    markmizzou
    Mark
    Missouri
    No, as you can read in the attached article, it is for both uphill and downhill situations. And trust me if you have never used it -you will be impressed when you activate the system.
    https://www.subaru.ca/WebPage.aspx?WebPageID=20185
  17. May 9, 2019 at 7:07 AM
    #77
    dbbowen2
    TN
    too many to list
    Im sure its great, in the context of this thread though. Still classifies as awd. Ill take this any day over a computer controlled program.
  18. May 9, 2019 at 7:39 AM
    #78
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    fwd is superior in winter conditions and ice btw, awd can kick out your rear end, if that's really what your worried about. or just man up and get the truck? black ice really isn't that hard to counter in rwd awd or fwd.
  19. May 9, 2019 at 8:16 AM
    #79
    markmizzou
    Mark
    Missouri
    You are probably correct as to what the "industry" classifies as AWD . The main point I am trying to make with the "classification" in mind , is that not all "AWD's" are created (and perform) equally. Ask any person that really know and understand how different AWD systems work, and they will know that most of them shut down the drive to the rear wheels at a speed around 20-30 MPH. Subaru's system does not. Most people don't know this -- including myself.
    For this reason alone - I feel a whole lot better when my wife is driving the Subaru vs say our old (gone now) CRV. BTW we are septuagenarians.
  20. May 9, 2019 at 8:39 AM
    #80
    dbbowen2
    TN
    too many to list
    What this whole conversation is about is awd/part time/full time systems. The Subaru system is an awd system. All of the different models use AWD. The x mode you are talking about is a software inside the ecu and is not a direct part of the drivetrain. Just like my STI had a driver controlled center differential, it was still an AWD vehicle. My buddies Forester is still AWD and his wifes outback is also AWD. Lots of other companies use different types of AWD. Subaru isnt the only company with awd operating at normal highway speeds. AWD systems just like 4wd systems use differentials to determine wheel slip and apply power accordingly. Your forester I believe uses a clutch back in the center. Engineering explained has a great video on it.
    https://www.youtube.com/watch?time_continue=173&v=WBQlK89PyxQ
    AWD systems are generally front biased, but do not just randomly shut power to the rear unless there is wheel spin or loss of traction. These splits vary from manufacturer and im sure older systems are different. Kind of arguing semantics at this point... but if you watch the video you can get a loose idea on how awd systems work.You can argue that the x drive and subaru system is a different type of awd but its like making the argument that Navy blue is not blue, its a different type of blue.
