The White Fighter
Discussion in 'Street Trucks' started by Beefed Taco, Apr 30, 2013.
  1. Apr 30, 2013 at 12:05 AM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I've worked on so many trucks I have no idea how many. Recently, I started naming them. STEQ's "Black Bullet", black S-runner with it's V6 and QA1 setup...had no idea these trucks could do what his did. Also his son Dean's, the "Black Widow", black S-runner that had a black widow living under the bed that I was afraid was going to bite me while I lowered, notched, and did cross member work, and finally...The White Fighter, pictured here.
    I've had trucks try to fight, but this one had some training. It had some bad signs going on.. lifted with fabtech coils, a previous off road life, and the worst part (yes, even worse than those fabtech coils) people that have been in there before.
    Corrosion, ball joints bolts that needed to be heated and pounded out, and just an all out hex that came with this truck. I've had 'em fight before, but never like this one. All in all, this truck robbed me of a few precious years of life thanks to all the stress I had to go through to finally get to see The White Fighter bow it's head, leave the boxing ring and drive away.
    FRONT
    b-j flip & 1-1/8" coil chop from stock 04 coils (a bit too low imo)
    KYB Monomax shocks
    Fender lip trim & no liners above tires, just behind where you can see
    REAR
    5 lug leafs with both leafs / no overload leafs / 4-1/2" Streetacos block kit
    Monroe air shocks w/ Air Lift pump system
    Fender lip trim, fender brace removal, & no liners above tires, just in front & behind where you can see.
    C-Notch
    Carrier Bearing flip
    1st pic = 20psi
    2nd pic = 100psi
    3rd pic = 5 lug leafs with no overload & 4-1/2" blocks for 6" rear drop
  2. May 1, 2013 at 10:00 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Thanks Seth. How is your truck doing?
  3. May 1, 2013 at 10:03 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I think your suspension broke! That truck is almost on the ground!
    :dancingbacon:
    JK JK Not my thing, but looks good! I actually prefer the second gens lowered, than the first gens, but hey to each their own! There's nothing better than getting a job done after fighting it hard! Except doing the same thing with no fighting, but then it wouldn't be worth it! :D
  4. May 1, 2013 at 8:37 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    :eek: good thing I still have my stock leaf packs :D:p
