the woes of a prerunner owner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cromag27, Jul 17, 2019.
  1. Jul 19, 2019 at 10:14 AM
    #41
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    If you knew you were going to off road then 4X4 should have been at the top of your list.
    Trade it in and get a 4X4. It will nag you till you do. Its a contentious thought, but as to why someone would buy a truck without 4X4 bogles my mind.
    cromag27[OP] likes this.
  2. Jul 19, 2019 at 11:07 AM
    #42
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    I agree. I don’t off-road, but I was sold at “better to have it and not needing it than not have it and needing it” when I was looking for a Tacoma.
  3. Jul 20, 2019 at 12:51 PM
    #43
    CanyonBoy
    CanyonBoy Member
    2018 Dblcab 4x4 trd
    By time you change out spring s, shocks, and of course a lift.... then you have to ensure the vsc systems werent jeopardized,,, better off starting w a vehicle built as a 4x4.
    A certified mechanic i know wont attempt a conversion unless it is like on a pre 1995 or earlier preferred.
  4. Jul 20, 2019 at 1:13 PM
    #44
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    I don't understand that argument at all. Why would you have a 4wd truck if you don't ever use it, or just use it a cpl times a year? It's just more cost, parts that need maintaining, or can fail etc.
    cookiedough and tacom08 like this.
  5. Jul 20, 2019 at 1:34 PM
    #45
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Correct. Need a fj front diff tube or arb/spool as well to eliminate needing anything electrical
    Agreed. Convert it and end up without the nanny front diff actuator/transfer case
    You dont know what youre talking about
    Please stop spreading bs
    Cause you can :lalala:
  6. Jul 20, 2019 at 1:47 PM
    #46
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Because everybody wants to be a 4x4 fanboy.
    tacom08 likes this.
  7. Jul 20, 2019 at 1:49 PM
    #47
    lynlan1819
    Tacoma
    Lifted
    Do a SAS conversion ,why waste money on the junk IFS.
    Boyk1182 likes this.
  8. Jul 20, 2019 at 2:02 PM
    #48
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    SAS is a lot more involved with a lot more custom fab involved. The cost is much higher. Most of the IFS 4x4 conversion is bolt on and the parts can be found used for reasonably cheap.
  9. Jul 20, 2019 at 2:06 PM
    #49
    lynlan1819
    Tacoma
    Lifted
    True,but SAS is a lot more reliable than any IFS garbage.
  10. Jul 20, 2019 at 2:39 PM
    #50
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Like others have said, if you truly NEED a 4x4, it’s much easier to just buy than convert. Not to mention, you won’t have the headache of trying to troubleshoot any issues you have with the conversion. I still use my 07 prerunner as a daily driver and it serves me well. The majority of people say they “need” 4x4 to go offroad when in reality they don’t. A good set of tires, airing down, and choosing good lines are important. I’ve only gotten stuck once in sand when off-roading with some 4x4 Jeeps. I was lazy and decided not to air down, so it wasn’t even the truck’s fault. Prerunners get bashed, but with patience and a good understanding of their limits, they perform exceptionally well. I say buy it and if it doesn’t serve you well, sell it. The resale value on these trucks are amazing.
  11. Jul 20, 2019 at 2:39 PM
    #51
    jowybyo
    Joe
    Baltimore, MD
    Yea. When is your SAS gonna be done?
    6 gearT444E likes this.
  12. Jul 20, 2019 at 8:05 PM
    #52
    6 gearT444E
    Deep South
    Herculiner Hootus
    it's not any more reliable than IFS. Whether it's a solid axle or independent, they will have a ball joint or kingpin of sort and wheel bearings which are a wear item. As long as they are taken care of they should all last thousands of miles without issue.
  13. Jul 20, 2019 at 8:14 PM
    #53
    jkuniverse
    Arlington TX
    Because it’s cool :headbang:
  14. Jul 20, 2019 at 8:22 PM
    #54
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    The argument of “why buy a 4x4 if you only use it a couple time a year” is bizarre to me. There’s a dozen or more things we all own that we either use rarely or never use but it’s just better to have them around for if you need it.
    Either way, I’ll never own a SUV or truck that isn’t 4x4. That’s just my standard, doesn’t have to be yours
    Wattapunk, Boyk1182 and jkuniverse like this.
  15. Jul 20, 2019 at 8:26 PM
    #55
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Just my two cents having bought a Prerunner.
    If I NEEDED or wanted a 4x4, I would’ve sucked it up and got one. Couple thousand extra on a loan isn’t a deal breaker since I keep vehicles until they are scrap ready.
    I got a Prerunner because I don’t need nor would often use 4WD, and for the same money I got a newer truck with less miles than the 4wd’s I was looking at.
    But, if I needed it, 4WD would top my priority list, with double cab being a close second.
    seanb06, tacom08, Gritto and 2 others like this.
  16. Jul 20, 2019 at 8:29 PM
    #56
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Exactly how I ended up with a PR. It wasn't a mistake. I wasn't trying to save money. I wasn't trying to avoid additional maintenance. Just don't need 4WD. 35 years of driving and I've never owned a 4x4. So I bought a vehicle that serves me perfectly 99.5% of the time.
    If I need a bit more bite from time to time...especially in the winter...then on go my extra rims with Duratracs. That setup along with the LSD turned on, gets me another .25%. That takes me to 99.75% of all the things I encounter. The remaining .25%? I just avoid. :thumbsup:
  17. Jul 21, 2019 at 5:50 AM
    #57
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    OP, sell the PR and get what you really want. Conversion is not worth the costs of just buying a 4WD that you know was done properly from the factory. As for those using extra maintenance as arguments against owning a 4WD, changing diff and transfer case fluids at the recommended 60K is hardly extra costs. Fuel costs, blah blah blah.. is dependent on type of driving, usage, added mods etc.. regardless of PR vs 4WD.
    cw4nicholson likes this.
  18. Jul 24, 2019 at 5:01 PM
    #58
    cw4nicholson
    cw4nicholson Oatman
    oatman
    PNW
    2009 grey Tacoma pre-runner double cab long bed
    ...wait? you can actually convert a pre-runner to a 4x4??? sounds costly!
  19. Jul 24, 2019 at 5:05 PM
    #59
    jowybyo
    Joe
    Baltimore, MD
    How much do you think it costs?
  20. Jul 24, 2019 at 5:19 PM
    #60
    tacom08
    tacom08 Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    It is, it’s ridiculously expensive
