THE "YETI" Build (my little white monster)
Discussion in '2nd Gen. Builds (2005-2015)' started by GarrettZ71, Feb 17, 2016.
  1. Feb 17, 2016 at 10:04 AM
    GarrettZ71
    GarrettZ71 [OP] Member
    Garrett
    San Diego
    2013 White Tacoma TRD Sport 4x4 Double Cab
    Hey TW, I recently came into ownership of a 2013 white double cab, extended bed TRD Sport 4x4. [​IMG] [​IMG] From searching through the forums myself I decided to order ARB OME 886, ARB 90000, ARB CS047R, ARB 60091, and ARB FK29. I also ordered OMEU53A(ubolt), OMESB108(spring bush kit). Everything should be here in about a week and I'm pumped.
    I plan on getting a arb bumper and winch with the tax return soon as well, hence I went with the 886's.
    I've seen posts where people get 3 degree axle shims and spacers in the front, I don't care about fitting 33's but I do want the driver and passenger side to sit even. Are the shims a good investment? Maybe thinking about UCA's but from what I understand that what I'm using won't be needed. Input is greatly appreciated and this is a San Diego truck! HMU!:fistbump:
    JDawg562 likes this.
  2. Feb 17, 2016 at 7:42 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  3. Feb 17, 2016 at 8:48 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Install the lift first, with the trim packer if you want to get rid of the Taco lean, and then decide if you need the FK29 and/or the axle shims. Plenty of threads on getting your driveline angles right, and only necessary if you get vibrations. Also look into getting a swaybar relocate kit (Wheelers Off-Road has one) because your swaybar will likely scrape up against your 886 coils. Mine had a little wear mark after only ~6k miles.
    FWIW I ended up with no trim packer (I don't care too much about Taco lean...it's gangster) and the FK29 plus 3 degree axle shims.
    Good choice on the suspension, though. I went the same route but switched to 887 coils because no bumper and 886s were way too stiff. You should be OK with a bumper and winch though. It's gonna look awesome.
    What are you thinking for tires?
  4. Feb 17, 2016 at 8:52 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    Baller. Sounds like an awesome setup.
  5. Feb 17, 2016 at 11:01 PM
    GarrettZ71
    Garrett
    San Diego
    When it comes to tires I'm a BFG fan. I'm running 285/75/16 all terrains on my silverado now, just transitioned from 315 KM2's(which have been the best I've owned so far). So right now I'm leaning towards BFG KM2's on the YETI. I'm really digging the look of the Bronze TRD wheels, granted I haven't looked for a set long, I'm feeling they must be somewhat scarce.
  6. Feb 17, 2016 at 11:17 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    If you're looking towards a mud terrain tire, I'd recommend the Goodyear MTR with Kevlar. I hear nothing but good from that tire. If it's all terrains, I'd stick with BFG or Cooper. Ultimately it's your choice, I just wanted to throw out my opinion.
  7. Feb 21, 2016 at 5:56 PM
    GarrettZ71
    Garrett
    San Diego
    Just picked these up, hopefully by next Sunday I'll have the time to install it.[​IMG]
    JDawg562 and DustStorm4x4 like this.
  8. Feb 22, 2016 at 9:58 AM
    GarrettZ71
    Garrett
    San Diego
    Are you saying you did or didn't go with the FK29 and 3 degree axle shims?
  9. Feb 22, 2016 at 10:14 AM
    Irongrave
    Irongrave Well-Known Member
    Drew
    Knoxville TN
    1998 T4R Limited
    Wheeling out west I would go with an MT-R over the KM2. the KM2s don't have a super stong side wall. The MT-Rs are a great tire until they get wet/muddy and you need to climb a rock they have almost no grip. At least that has been my experience.
  10. Feb 24, 2016 at 12:01 PM
    GarrettZ71
    Garrett
    San Diego
    Good to know about the MTR's, I've actually ripped wide open the side wall on my KM2 front diver before I think on a curb...
  11. Jun 1, 2017 at 9:29 AM
    GarrettZ71
    Garrett
    San Diego
    It's been a while, but here it is![​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  12. Jun 1, 2017 at 9:35 AM
    GarrettZ71
    Garrett
    San Diego
    After 2 short(well shorter) deployments the wife and I decided to finally PUT THAT OME ON!
    Well the front was a huge pain in the neck but it rides great even without the plate bumper yet! Love the height increase, not too high where the wife can get in and out easily without steps (until I can swing the cash for a new set of wheels and tires).
    I haven't had any vibrations while driving, I didn't use axle shims or the FK29?!? Anybody else have that experience?
