There's a cricket under my bed
Discussion in 'Technical Chat' started by Goosedog, Aug 25, 2013.
  1. Aug 25, 2013 at 6:14 PM
    Goosedog
    Goosedog [OP] Well-Known Member
    It sure sounds like a cricket and it seems to be coming from under the bed or at least the rear of the truck. When I start out in first, you hear this chirp, chirp, chirp that increases its rate with the speed of the truck. It won't do it coasting and it stops as soon as you depress the clutch. Once I'm up to speed in 3rd or 4th, it may still be doing it but it's drowned out by the tire roar. Any ideas?
  2. Aug 25, 2013 at 6:16 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Does it chirp at wheel speed or driveshaft speed?
  3. Aug 25, 2013 at 6:17 PM
    Tacoma Mike
    Southern Maine
    Poss u joint
  4. Aug 25, 2013 at 7:12 PM
    Goosedog
    Driveshaft speed.
    I hit all the grease zerts a couple days ago and its still chirping.
  5. Aug 25, 2013 at 7:15 PM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    it could be your throw out bearing. Mine is in the shop under warranty for what sounds like a cricket chirping and it goes away once i step on the clutch.
  6. Aug 27, 2013 at 4:24 AM
    Goosedog
    Yeah the throw-out bearing sounds possible but wouldn't that be unusual at only 110K miles?
  7. Aug 27, 2013 at 4:40 AM
    gunner76137
    gunner76137 Xrunner Junkie
    Johnson City Tennessee
    Radiant red
    8K HID's and foglights, Pioneer HU,Boston acoustics amp,2.o farad cap,12 in Kenwood ,fog light mod, Doug Thorley long tube headers Jardine cat back exaust, Kool View cai, 7 color LED underbodies. Carbon fiber roof and evo mod, Custom Graphics ,URD S/S,QA1 18 way adjustable rear shocks, led interior lights and license plate lights and many more mod's
    Its the Tacoma curse. Throw out bearing sucks.
    My first Xrunner only did it when sitting still when out of gear and clutch out , my 07 does It when in gear driving down the road.
    If your under warranty the stealership should replace it free.
  8. Aug 27, 2013 at 4:56 AM
    Goosedog
    No warranty, I'm the second owner and it's an '06.
    But damn, ad that to the list of Tacoma curses huh.
    That list is getting pretty long...rusting frame, under-sized rear leafs, poor fuel milage, drivers side lean, early failure throw-out bearing, etc.
  9. Aug 27, 2013 at 10:30 AM
    Papa Taco
    Jared
    Socal
    My truck is a 2011 and it only has 27k miles. Yay warranty!!!
  10. Aug 27, 2013 at 10:39 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    My rear u-joint made that exact sound with driveshaft speed.
    Stop the truck on level ground, throw it in neutral, take off the parking brake, climb underneath and shake the driveshaft from side to side. If there's any play in the U-joint bushings, it needs to be replaced. I did mine at 80k.
    EDIT: didn't read the full post, if it stops when you depress the clutch then it's definitely the TOB.
  11. Aug 27, 2013 at 10:48 AM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    I am not sure about your throw-out bearing as I have not researched that much but I had a chirping sound come from under my truck not so long ago. I replaced all the U-joints & the Carrier Bearing. Needless to say, the chirping is gone.
    See my thread if you'd like. I posted videos and such.
  12. Aug 27, 2013 at 9:35 PM
    Papa Taco
    Jared
    Socal
    Got a call from my dealer today and they did te throw out bearing and clutch assembly and now my chirp is gone. U joints make noise but my money is on your throw out bearing too
  13. Aug 30, 2013 at 9:49 AM
    Goosedog
    The rear U-joint. I never would have thought it since it quit with the clutch in but apparently it made the chirp only while under load.
    Simple cheap fix, hope others with this symptom have it just as easy.
