Thermal paste
Discussion in 'Technology' started by bongwhisperer, Mar 25, 2016.
  1. Mar 25, 2016 at 12:54 PM
    bongwhisperer
    bongwhisperer [OP] Well-Known Member
    horn that plays "la cuka racha,"
    I was going to get some arctic silver 5 cause it seems its been getting decent reviews, but I found a few threads on toher forums that give it an okay performance. I ordered a samsung 850 evo ssd, figured i'd kill 3 birds with one stone. ssd, re-apply thermal paste to cpu/gpu.
    What is a good decently priced thermal paste?
    Dell latitude e6400d, intel dual core t9600, 2,80 ghz, copper heat sink.
    Are these normal temps?
    Under load, normal surfing and youtube.
  2. Mar 28, 2016 at 6:35 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Yep those are normal temps, most intel cpu's usually underclock when they hit 90C or so. I use arctic silver, it's good stuff, after you apply it you might see some slightly higher temps until the paste "breaks in" but thats completely normal.
  3. Mar 29, 2016 at 10:37 PM
    bongwhisperer
  4. Apr 1, 2016 at 4:49 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Those are not normal temps.
    I think you're confused, those are in Celsius, not Fahrenheit.
  5. Apr 1, 2016 at 4:56 PM
    bongwhisperer
    I know they are in C, and if it was in F why would I even question it, those would be equal to or lower than ambient temps. I ended up re-pasting my laptop cause I put in a new SSD. My temps are lower by about 10 degrees, not sure if it makes a difference but it did drop.
    https://www.tacomaworld.com/threads/anyone-ever-upgrade-to-an-ssd.417686/page-3#post-12160611
  6. Apr 1, 2016 at 5:00 PM
    Pabloeeto
    Paul
    San Diego
    I have my core 2 duo Macbook set to Celsius its normal.
  7. Apr 1, 2016 at 5:02 PM
    bongwhisperer
    I've had my comp on all day. Been surfing and doing the usual. I just took this screen shot, my fan barley even kicks on now.
  8. Apr 1, 2016 at 10:11 PM
    digitaLbraVo
    Over clocked/volted i7 4770K weighing in at 30*C. My laptop is some Celeron and it doesn't go much past that temp either. Those Core 2 Duos were supposed to run cooler than the old P4's they replaced, you guys are running hot. Real hot. That wouldn't be an acceptable processor temp on a stock cooler for any desktop/server equipment. Period.
  9. Apr 1, 2016 at 10:12 PM
    digitaLbraVo
  10. Apr 2, 2016 at 9:36 AM
    bongwhisperer
    Your first reply stated that I am mistaking the Celsius readings as Fahrenheit. If thought my laptop was running at 70-75F, which would be equal to ambient temps, why would I question my temps? Your first reply makes no sense.
    I'm not running a gaming rig and from the readings I've done, my temps are normal for the device I am using. Can I get them lower? Yes, I can, but I don't want to go through the hassle of replacing my thermal pads with copper shims, I don't game, or do any kind of media editing so I do not need anything that runs as cool as possible.
  11. Apr 2, 2016 at 9:37 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I used the Arctic Silver 5 in my April 2014 build. No issues whatsoever.
  12. Apr 2, 2016 at 9:39 AM
    bongwhisperer
    I used arctic mx-4, it got good reviews and it's working out pretty well.
  13. Apr 2, 2016 at 9:40 AM
    Biscuits
    :thumbsup:
    I think that was the alternative I was considering, but the Silver 5 I was able to receive for free from a friend. Hard to beat that.
  14. Apr 2, 2016 at 9:43 AM
    bongwhisperer
    Yeah, free is the best price. I was going to go with Silver 5 in the beginning but the Mx-4 did slightly better in the test I found, the difference is negligible though.
  15. Apr 2, 2016 at 9:51 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Quality application of the paste, giving 100% coverage in a thin layer meant to fill in the micro scratches of the two mating surfaces will have the greatest impact. All paste will still have a thermal conductivity less than that of metal to metal contact. It is not unusual to find from the factory applied paste as a 'dollop' in the middle', no even coverage, and too thick in the middle leaving just a small area of surface contact that actually can transfer heat.
  16. Apr 2, 2016 at 9:55 AM
    bongwhisperer
    When I opened up my laptop, you described it perfectly. There was an issue I believe with Dell using either really cheap thermal paste on these laptops or laptops built around the time this was. It was just a poor job altogether. There are plenty of articles and forums posts that people have posted regarding it.
  17. Apr 2, 2016 at 10:09 AM
    bongwhisperer
    Models E6400 (2.13 GHz), E6300 (1.86 GHz), E4400 (2 GHz) and E4300 (1.8 GHz): 61.4 C (143 F).
    http://mikebeach.org/2010/11/30/how-hot-is-too-hot-dont-overheat-your-computer/
    Max. Temperature 105 °C
    http://www.notebookcheck.net/Intel-Core-2-Duo-T9600-Notebook-Processor.24836.0.html
  18. Apr 2, 2016 at 10:29 AM
    bongwhisperer
    In order for me to get my laptop down to 30*C, I would have to do this. Maybe in the near future, but for now, the new paste will be just fine for me.
    http://forum.notebookreview.com/thr...and-similar-performance-cooling-guide.375889/
  19. Apr 16, 2016 at 6:07 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    30C idle? I have a 4790K that hits maybe 85C @ 4.8GHz on air under a stress test.
  20. Apr 16, 2016 at 6:09 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    if its not gmo free dont use it
