Thermo Quiet pads?
Discussion in 'Technical Chat' started by Y0TA, Sep 25, 2010.
  1. Sep 25, 2010 at 7:40 AM
    Y0TA
    Y0TA [OP] Well-Known Member
    Zac
    Central MT
    05 BLK TRD Sport 4X4
    So I changed my pads a couple weeks ago and these pads are supposed to be quiet. Th parts guy said the pads didn't need the old shims or the gel that goes on the back of the pad. So why are they squeaking when I press the brake. I even got on the interstate a few times and stopped from about 75 to 10. They stop squeaking after that for a little while but then shortly after they're back at it. Any thoughts guys?
  2. Sep 25, 2010 at 7:49 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    No gease or Shims = Squeak,shouldve have stayed with the OEM pads they come with new shims and you can apply a little anti squeak grease yourself=no squeak,no dust,long life,durability,no hassles
  3. Sep 27, 2010 at 8:10 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I've had the Thermo Quiet's on 2 vehicles before. One was an 02 Dakota, where they worked just fine, no squeal. The other was an 02 Mazda Tribute, and on it, had the same problems as you. They squealed. Took 'em apart and applied some disk brake quiet, no love, tried a different product, no love. Just had to live with it.
  4. Sep 27, 2010 at 12:17 PM
    Y0TA
    Zac
    Central MT
    Thanks for the input. Even the grease didn't work for you then? I'm about to take them off and get some different ones if I can't any way of fixing it. The sqeak is driving me crazy.
  5. Sep 27, 2010 at 12:38 PM
    got_titan
    got_titan Well-Known Member
    sevierville, tn
    2010 trd sport dc 4x4
    I have had good luck with the thermo quiet pads, sounds like the pads are glazed. Did you turn the rotors when changing the pads?
  6. Sep 27, 2010 at 12:59 PM
    Y0TA
    Zac
    Central MT
    The rotors looked good so I didn't bother with turning them.
