Thermometer issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewRider, Dec 17, 2013.
  1. Dec 17, 2013 at 10:25 PM
    NewRider
    NewRider [OP] Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    So I've recently noticed that my temp gauge isn't reading correctly. Don't direct me to the temp gauge/compass fix thread here.. The display is working but the gauge isn't easing right. I'm at least 5-7* high no matter what.
    I thought maybe the problem was it reading hot cuz of the engine heat somehow so I built a bracket for it tonight to hold it further away (toward the front bumper) but that didn't seem to affect it at all..
    It is dirty right now from the last time I went wheelin and tomorrow im gonna clean it off to see if that helps.. Other than that, any ideas? Anyone else had this issue?
  2. Dec 18, 2013 at 5:16 AM
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    I've been noticing the exact same thing. I don't have any help for you, but you are not the only one. I thought about taking it back and having a new one put in under warranty.
  3. Dec 18, 2013 at 6:10 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Same issue here on my 2010 but min seems to read 7-10 degrees colder than ambient temps. Gotta be the sensor...keep us updated on what the dealer says...
  4. Dec 18, 2013 at 9:06 AM
    NewRider
    Travis
    '87 4runner
    ^x2 on the dealer.... I'm thinking about swapping in my brothers sense his console isn't working and testing it that way
  5. Dec 18, 2013 at 12:03 PM
    CtTaco
    Eric
    Connecticut
    that sounds like a great place to start! Let us know if you see any changes
  6. Dec 18, 2013 at 10:45 PM
    NewRider
    Travis
    '87 4runner
    Daily Bump for anyone that might have info...?
  7. Dec 19, 2013 at 5:04 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I see you've got a brand new truck. Yours is always off or just when you first get in? Mine reads high when I first get in after the truck has been sitting in the sun but cools off to normal temps once I start driving. That's normal behavior in my opinion. Not much you can do about that.
  8. Dec 19, 2013 at 7:28 AM
    cstallings
    Arkansas
    It's high when I get in, but starts to drop some as I drive. I have a 42 mile commute to work, so it has plenty of time to get to the normal temp. Today it settled in at 6 degrees above outside temp. I checked it via multiple bank signs and my weather app on my phone.
  9. Dec 19, 2013 at 8:23 AM
    mollyg
    mollyg Well-Known Member
    Canada
    13 tacoma
    3" lift
    My new truck is very high 5 degrees more and takes about 10 minutes too read proper my Jeep is only off a degree at any time.
  10. Dec 19, 2013 at 6:01 PM
    NewRider
    Travis
    '87 4runner
    Mine also start high and cools off as I'd expect from bein in the sun or sittin next to a hot engine but it never cools down to where it should, always about 5-7* high..
  11. Sep 22, 2014 at 2:19 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Did anybody ever get a fix for this? My wife's Acura is spot on. My Tacoma, not so much.
