Thermometer
Discussion in 'Technical Chat' started by coffeesnob, Jan 26, 2013.
  1. Jan 26, 2013 at 5:26 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Thinking of adding inside outside thermometer to truck. Anyone know where the thermocouple is mounted? Saw one where it is in the door jamb but that seems kind of hokey.
  2. Jan 26, 2013 at 12:51 PM
    jth523
    jth523 Member
    albany,ny
    2011 4x4 double cab
    Forward of the radiator; near the hood latch.
  3. Feb 2, 2013 at 5:38 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Won't that pick up a lot of heat from the engine?? Maybe mount it lower?
  4. Feb 2, 2013 at 5:43 PM
    monoman
    Dave
    I have one with the sensor mounted in the door jam & it works great. The only bad thing about mounting it there is when the sun is hitting on that side of the truck. Other than that, it works well.
  5. Feb 3, 2013 at 5:54 PM
    jth523
    jth523 Member
    albany,ny
    2011 4x4 double cab
    (Forward of the radiator; near the hood latch.)
    It will pick up heat when the truck is not moving and the engine has been running, but reads correctly soon after the truck gets moving.
    With the sensor forward of the radiator, it is not affected by heat from the sun as it would if in the door jam with the sun beating down on that side.
  6. Feb 3, 2013 at 6:00 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I have this less than $20.00 and senser is mounted in door jam on outside of rear door.
  7. Feb 3, 2013 at 9:21 PM
    monoman
    Dave
    Ah, ok. If or when I have to redo this I'll have to give this a try. Thanks!
  8. Feb 4, 2013 at 3:37 PM
    169.254.255.201 Well-Known Member
    Interwebs
    What brand and model is that? I want a clock, but a temp gauge sounds pretty nice too. Those darn clocks that you can't see from the steering wheel!
  9. Feb 9, 2013 at 4:45 PM
    Tiedie
    David
    WFOY
    I do believe it is a roadpro (truckstop special).Just do the search on the net,this one plugs into the outlet and has a battery back up.It is held on with velcro but I am always open for other options.
  10. Feb 9, 2013 at 9:34 PM
    BamaToy1997
    Bill
    Navarre, FL
    Factory outside temp sensors that are located in the front grill area are read differently than a normal temp sensor is. On first key-up, if the engine off time has reached a predetermined point (this is decided upon in software development) then the displayed temperature will be exactly what was measured at that time. If the engine is running, the outside temp sensor signal will be ignored until the vehicle is moving above a predetermined speed (Usually faster than 30 mph) What this does is prevents the "radiated" temperature coming from the radiator from causing inaccuracies for the sensor.
