Thermostat or Temp Gauge
Discussion in '1st Gen. Tacomas (1995-2004)' started by BigCharllie44, Oct 7, 2023.
  1. Oct 7, 2023 at 10:30 AM
    BigCharllie44
    BigCharllie44 [OP] Member
    Charlie
    2004 Tacoma 3 RZ FE 4WD
    none
    Now that weather is cooler, nights 30 - 40 degrees, After the truck is cranked when cold, the temp gauge goes to the full hot position and stays there for 5 to 6 miles then quickly goes back to average temperature reading. What do you think is happening here ?
  2. Oct 7, 2023 at 10:43 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    sounds electrical in nature
    I'd start with checking the temp probe wire for damage
    then find the test procedure for the probe
    and welcome
  3. Oct 7, 2023 at 10:52 AM
    BigCharllie44
    Charlie
    none
    Craig, Thanks for your response. Where would I find the temp probe wire?
  4. Oct 7, 2023 at 10:57 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    You could also get a scan gauge or ultra gauge so you can see what actual running temperature is.
  5. Oct 7, 2023 at 11:05 AM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    IDK the placement, you will need to look that up in a service manual from someplace.
    given that resistance rises with temperature I'd speculate that the prob is failing. it has an open connection when cold that closes when warm and giving a normalish reading
    but rodent damage to the wire is also a possibility
  6. Oct 7, 2023 at 8:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm betting it's the sender.
    Your gauge is a dummy gauge in that, it's "kind of" accurate based on a single wire probe or resistor that it works off of.
    These trucks have a sensor, and a sender.
    The sensor communicates with your computer to tell it how it's running, and this information is available via your OBDII port.
    The sender is located separate from that of the sensor, and its sole purpose is to move the needle on your temp gauge.
    You can have a bad sender telling you you're overheating, whereas your vehicle could be in perfect health.
    The opposite can happen where your truck is overheating, but the gauge could be faulty and not warning you.
    phoenix ray likes this.
  7. Oct 8, 2023 at 8:29 AM
    Glamisman
    Glamisman Well-Known Member
  8. Dec 4, 2024 at 11:50 AM
    BigCharllie44
    Charlie
    none
    I have replaced both the sender and sensor and the problem has not changed. I do not have access to a vehicle computer device.
