These are real tie downs toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by husqvarna 530rr, Mar 14, 2013.
  1. Mar 16, 2013 at 5:02 AM
    #61
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    OP, nice install. Yes the fasteners are quality NAS stuff. They definitely are not brass with the coin slotted head style.
    The 7075 will be fine to double it up, but I hope you anodized, or alodined the plates plus primed and painted them.
    I like the rings, are they from a 53?
    As for aerospace fasteners being almost the same as Grade 8 except for traceability...I say no way. Quality aerospace hardware has a lot more details in adding radius under the fastener head, better thread forming and will pass a magnetic particle inspection.
    I have inspected brand new GR8 bolts with mag particle and they are loaded with cracks from manufacturing.
    OP, send me a PM with the PN or what helicopter they are used on. Maybe I can obtain some locally.
    PK
  2. Mar 16, 2013 at 8:39 AM
    #62
    Swordknives
    Swordknives mmm Tacos
    South OC CA
    2013 Dbl cab LB v6 SR5
    Looks good where did you get them?
  3. Mar 16, 2013 at 9:58 AM
    #63
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Pretty sure that's what I was getting at. Thanks tips.
  4. Mar 16, 2013 at 10:57 AM
    #64
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Regardless of the flaws, if you buy a bunch of Gr 8 bolts from a branded mfr like Spaenaur or Fastenal, they will exceed the 160 ksi tensile strength requirement. The other properties like fracture toughness and better dimensional tolerancing separate the MS/NAS bolts from commercial bolts.
    Don't put much faith in the paper traceability. I've seen idiot MS/NAS bolt mfrs who heat treat the bolts after thread rolling, but that's another story for another day...
  5. Mar 16, 2013 at 11:35 AM
    #65
    bullaculla
    bullaculla IKA fabrications
    Honolulu HI
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Specialty fasteners, yes very different. You cant get buttress threads from home depot, But normal bolts are really no different from good grade 8.
    I've seen lots of mil spec material that were supposedly tested from the factory fail our inspections. More than half of the helo tie downs we receive get sent back to peck and hale because they fail NDT.
    But you are probably right. My experience is in the shipyard, I'm sure the aviation side is nothing but specialty fasteners and with much more specifications and tighter tolerances.
  6. Mar 16, 2013 at 12:09 PM
    #66
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
  7. Mar 16, 2013 at 8:40 PM
    #67
    husqvarna 530rr
    husqvarna 530rr [OP] Well-Known Member
    oahu hawaii
    sport
    none
    Yes they came from a 53d, however the 53e uses them as well.
  8. Mar 16, 2013 at 8:40 PM
    #68
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    ^^^ Why are you selling them?
  9. May 16, 2013 at 6:57 AM
    #69
    DoorDing
    Bodie, CA
    yes
  10. May 16, 2013 at 11:13 PM
    #70
    kumz
    kumz Well-Known Member
    well hello mr steve
  11. May 17, 2013 at 6:35 AM
    #71
    husqvarna 530rr
    oahu hawaii
    sport
    none
    Haha what up menehune
  12. May 17, 2013 at 9:35 AM
    #72
    ruggedT
    ruggedT The Sticker Guy Vendor
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I think the only people who have trouble are the ones that dont know how to properly secure a load... Namely bikes/4-wheedlers.
