These Damn Wheel Bearings...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco93, Apr 9, 2011.
  1. Apr 9, 2011 at 1:59 PM
    Taco93
    Taco93 [OP] Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    These things are crap...!!!!
    I just found out that both of mine are failing....almost a 800 dollar job for both up here in Canada at Midas :(
    I'm going to attempt this myself, but I just want to clarify what I need in order to do this..
    I know I need two bearing assemblys: Would these do or should I get different ones? http://cgi.ebay.com/ebaymotors/ws/e...50519118195&ssPageName=ADME:X:RTQ:MOTORS:1123
    Also, I think I need the oil seals and O rings that go along with it...Is that correct? Does anyone have the toyota part numbers for these?
    This I know is going to be a PITA.....
    Thanks
  2. Apr 9, 2011 at 2:03 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  3. Apr 9, 2011 at 3:09 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Pick up a haynes manual man... best $20 you can spend.
  4. Apr 9, 2011 at 3:15 PM
    tinker_troy
    T R O Y
    WY/SD
    Does the Haynes manual have it in there? I know the Chilton's doesn't! All it says is "take it to a professional". Damn a-holes.
  5. Apr 9, 2011 at 3:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Oil seals. No. O-rings. Yes
    They should come with the o-ring and dust seal
  6. Apr 9, 2011 at 3:23 PM
    98tacoma27
    Ben
    Not Beech Creek
  7. Apr 9, 2011 at 3:23 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    Also, you need a large press to pop out the old and press in the new ones. I had to take mine to a local shop and have them do the pressing part. Just fyi.
  8. Apr 9, 2011 at 3:23 PM
    tinker_troy
    T R O Y
    WY/SD
    Uhhh... I think your bag is on too tight
  9. Apr 9, 2011 at 3:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    :confused:
  10. Apr 9, 2011 at 3:26 PM
    tinker_troy
    T R O Y
    WY/SD
    :gossip: they no come with seal and o ring.
  11. Apr 9, 2011 at 3:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    Well that's just stupied.
  12. Apr 9, 2011 at 3:28 PM
    tinker_troy
    T R O Y
    WY/SD
    Si, Senior Bag, Si.
  13. Apr 9, 2011 at 3:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    Parts from the dealer no have o-ring? I guess that's expected.
  14. Apr 9, 2011 at 3:36 PM
    tinker_troy
    T R O Y
    WY/SD
    I don't think so (it's been a few months since I did this).
    I got my bearings from CarQuest and had to go to the dealer to get the o-rings. I pretty sure you can just re-use the ones you have if they are not torn or cracked.
  15. Apr 9, 2011 at 3:51 PM
    98tacoma27
    Ben
    Not Beech Creek
    We did that with Fred's. Just cleaned them up and greased them. Some of the bearings shown on Rockauto show o-rings.
  16. Apr 9, 2011 at 5:27 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Do you know where to buy these?
  17. Apr 9, 2011 at 5:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    Here is a better option and it's free.
  18. Apr 9, 2011 at 5:33 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    what is the mileage on your truck OP
  19. Apr 9, 2011 at 5:51 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    74000
  20. Apr 9, 2011 at 5:55 PM
    AK27
    AK27 Well-Known Member
    i got my front wheel bearings replaced with skf parts (hub and bearing) for 197 bucks each.
    i'm in ontario OP
