These or these?
Discussion in 'Suspension' started by Tacomanator, Jan 10, 2011.
  1. Jan 10, 2011 at 6:32 PM
    Tacomanator
    Tacomanator [OP] Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  2. Jan 10, 2011 at 7:02 PM
    Tacomanator
    Clam Slammer
    Southern Cali
  3. Jan 10, 2011 at 7:10 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    DSMS has more options for lengths depending on you specific application
  4. Jan 10, 2011 at 7:20 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    yeah i was looking at the 22.80" length shock from DSM since im still running my stock leafs, but are they a direct bolt on? DSM's site dosnt exactly specify if they will work on the Tacoma. also, is there any real diff between DSM's and ORW's shocks? or is it just the reservoir? just wondering since the ORW shocks are a bit more expensive.
  5. Jan 10, 2011 at 7:30 PM
    08pretaco
    az
    For the DSMS looks like you will have to get the eye to pin adaptor which runs about 45 bucks IIRC
  6. Jan 10, 2011 at 7:31 PM
    08pretaco
    az
  7. Jan 10, 2011 at 7:40 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    alright cool. thanks bro
  8. Jan 10, 2011 at 9:30 PM
    CaptMorgan
    CaptMorgan Well-Known Member
    Tempe
    Lift, tires, aux-in, LED Taillights, Flowmaster
    Another thing to consider with the DSMS shocks is that I don't believe they have a mounting bracket and you would need to figure that out.
    edit: just thought I would mention it, with the Tacoma shocks vs the FJ's I got, you run the shock upside down so the reservoir is on the bottom.
